xcp-ng
McHenry
Sat Dec 20, 2025 3:50 am
I am wondering if it is possible to use StawWind vSAN with xcp-ng?
https://docs.xcp-ng.org/
I see a lot of mentions of Proxmox and Hyper-V, but nothing about xcp-ng
I am looking for an HA storage solution for VMs. We currently use TrueNAS via NFS, but we need HA.
Sat Dec 20, 2025 9:20 am
For now, the scenario has not been officially tested.
We are working on integration.
Theoretically, you can connect VSAN iSCSI or NVMe-oF targets to an XCP-NG host as external storage. I am not sure about the converged scenario.
tribebeauties
Wed Jan 07, 2026 8:42 am
It’s a bit surprising that StarWind doesn’t have a flashy dedicated page for XCP-ng like they do for Proxmox or Hyper-V, but it’s definitely possible! Since XCP-ng is based on Xen, you can connect to StarWind vSAN via iSCSI, which is one of StarWind's native delivery methods. You'd basically run StarWind in a VM on each host (or on dedicated hardware), and then present that storage back to your XCP-ng pool as an iSCSI Software SR.
Wed Jan 07, 2026 10:00 am
Converged setups are still there.
Just stay tuned.
