VSAN Proxmox 1GB
alexandru.mateescu
Thu Oct 23, 2025 7:21 pm
Hi
I have just deployed the vSAN Free and my network interfaces on the proxmox hosts are 10GB, however the Vsan appliance only shows 1GB links.
I am deploying it on a two node Proxmox and using the below interface:
Settings for ens5f0np0:
Supported ports: [ FIBRE ]
Supported link modes: Not reported
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: No
Supported FEC modes: Not reported
Advertised link modes: Not reported
Advertised pause frame use: No
Advertised auto-negotiation: No
Advertised FEC modes: Not reported
Speed: 10000Mb/s
Duplex: Full
Auto-negotiation: off
Port: Direct Attach Copper
PHYAD: 0
Transceiver: internal
Supports Wake-on: g
Wake-on: g
Current message level: 0x00000007 (7)
drv probe link
Link detected: yes
Any ideas?
Fri Oct 24, 2025 7:28 am
This issue relates to how the network is configured inside the StarWind VSAN VM.
Please see if VIRTIO or VMXNET3 are used.
richardwvm
Tue Nov 11, 2025 11:04 pm
I have this issue also. I spotted the VMXNET3 driver being used in the guide and changed mine from VirtIO, but still shows as 1Gbps.
Any help much appreciated.
Wed Nov 12, 2025 4:06 am
That's an issue with the driver on the Proxmox side.
Test the network performance with iperf3 to clear this concern.
Sorry for any inconvenience.
