VSAN Free Update
JULDSI
Mon Sep 29, 2025 3:24 pm
I've installed two VSAN Free nodes and one witness.
But when I try to run an update through the web GUI, I get the error: "Update Failed: Bad Gateway."
I don't know what happened or what the problem is.
Can anyone help me?
dmytro (staff)
Mon Sep 29, 2025 4:13 pm
Hello JULDSI,
Thank you for choosing StarWind VSAN Free.
Could you please generate a support bundle and submit it using the following form: https://www.starwindsoftware.com/support-form.
For the subject, please use "VSAN Free Update". We will review it and investigate if there are any issues.
Cheers,
Product Manager, StarWind Virtual SAN
JULDSI
Mon Sep 29, 2025 4:20 pm
thanks for your answer.
Done (with another mail because my forum account mail not work.... " maybetoo long :| :| "
Tue Sep 30, 2025 9:22 am
What is the current StarWind VSAN version in use? According to the release notes, the latest one is 19551 https://www.starwindsoftware.com/release-notes-build. If you are running 19551, the update might not work.
Also, can you please see if your network allows downloading the software? Try to wget something (e.g., sudo wget https://ovf.starwind.com/tmplink/starwi ... 551.tar.gz --no-check-certificate) into the VM.
JULDSI
Tue Sep 30, 2025 10:44 am
Thanks for you reply i use the 1.6.580.7361 version.
And i can download this link : https://ovf.starwind.com/tmplink/starwi ... 551.tar.gz
Tue Sep 30, 2025 10:58 am
Thanks for your update.
Please navigate to the logs of /opt/starwind/starwind-virtual-san/drive_c/starwind/logs and open the latest file. The top line should highlight on the VSAN build.
Also, did you try downloading a file from our website in the CVM?
JULDSI
Tue Sep 30, 2025 12:27 pm
The result of /opt/starwind/starwind-virtual-san/drive_c/starwind/logs and open the latest file
StarWind Virtual Storage Appliance v8.0.0 (Build 19551, [SwVSA], Win64)
and i can download from your website (i've updated my reply) :D
Tue Sep 30, 2025 1:11 pm
Thanks for your cooperation! :D
You are running the latest build for now.
JULDSI
Tue Sep 30, 2025 8:02 pm
Ok, thanks
I have another question, when i make apt update and apt upgrade, i have a lot of packets can be updated, can i make this update without any risk ?
Same question i see it can be possible to make a dist upgrade ? it's more risky ???
Updates must only done with web gui ?
Thanks for your "lights" about the process.
Wed Oct 01, 2025 3:56 am
You are welcome :)
Honestly, I won't do that as there's a chance to update to a not stable kernel version. Also, the updates can pile up and fill /, leading to an unbootable VM.
JULDSI
Mon Nov 03, 2025 2:53 pm
I see on the change log there is a new version (22/10/2025), so when check update with gui i also have Bad gateway.
Besides in settings sotware update installed version is empty ? it's normal with the free version ??
Thanks for your answer.
Best regards..
Mon Nov 03, 2025 5:20 pm
The repo is available and I was able to run the updates recently. I guess there might be some restriction on your network.
JULDSI
Tue Nov 04, 2025 4:09 pm
Thanks for your answer, so it's normal that on the GUI installed version is empty ?
Tue Nov 04, 2025 4:41 pm
Ifthe issue happens if you have network issues (e.g., dns or gateway), or you have restriction that blocks the 80 and 443 ports for internet access in CVM.
JULDSI
Wed Nov 05, 2025 2:23 pm
So i have an appliance has a witness and update is good (i see installed version and i can check the update)
When i check the starwind_updater.log on the witness i see some good info like ip adress gateway and logs which ask about the update "compare version..."
On a Vsan Node the starwind_updater.log the log loop on :
[OpenSSLHelper]: Start gets IP addresses.
2025-11-05 08:43:45.277 00007 INFO | [OpenSSLHelper]: IP address was found: 169.xxx.xxx.xxx
2025-11-05 08:43:45.277 00007 INFO | [OpenSSLHelper]: IP address was found: 192.xxx.xxx.xxx. (Management)
2025-11-05 08:43:45.277 00007 INFO | [OpenSSLHelper]: IP address was found: 192.xxx.xxx.xxx. (Replication)
2025-11-05 08:43:45.277 00007 INFO | [OpenSSLHelper]: IP address was found: 192.xxx.xxx.xxx. (Data)
2025-11-05 08:43:45.277 00007 INFO | [OpenSSLHelper]: End gets IP addresses.
2025-11-05 08:43:45.277 00007 INFO | [NetworkConfigurationLinux]: Setup VM current IP address is: 169.xxx.xxx.xxx
2025-11-05 08:43:45.277 00007 INFO | [NetworkConfigurationLinux]: Setup VM IP address is from Zero Config (Bonjour) pool. Can't use it.
2025-11-05 08:43:45.277 00007 INFO | [NetworkConfigurationLinux]: Correct Setup VM IP address is not available yet. Waiting for IP (30 seconds)..
So if it use the 169.... and not he management ip.... :roll: :roll:
=> the witness has only one ip.
Thanks for your help.
