issue connecting to host
ehinkle29
Mon Sep 22, 2025 1:24 pm
I am running starwind VHCA on a two node proxmox cluster, this all was working fine up until yesterday when a network adapter failed in one of my proxmox servers (pv02), even though it failed the vm's were still running there were just no connectivity on the host. I have 2 adapters on each host 1 single port 1g port that is used for mgmt of the proxmox as well as the vca appliance. The other nic is a dual port 10g adapter that was used for the data and replication on the host. I was able to get into the web interface of the appliances because those run off the 1gig interface (in the below it is the 10.35.15 network) and could see that the cluster was out of sync, on proxmox 2 it was showing the storage from the vhca was unavailable but on proxmox1 it was still showing available. So i shutdown the proxmox2 eventually replaced the nic and then noticed on proxmox1 it was showing the disk are offline. I have been trying several things to get this back up at this point i have shutdown the vhca on proxmox2 and is just working on the vhca on proxmox1 which should have been working fine, but I have the issue where the disk in proxmox show offline and look like it is not connecting via iscsi. If I try logging into the vhca on the proxmox host it is showing below and failing to login, which nothing has changed on this host, other then I created a [iface: iscsi-eth1] to see if that would work but it stopped working prior to that.
Any idea how I get these back connected? Also in the vhca 01 is listed as priority 1 and I have not rebooted or done anything to vhca01.
Below is the output of trying to login to the target.
root@pve01:~# iscsiadm -m node -T iqn.2008-08.com.starwindsoftware:10.35.15.14-lun0 -p 192.168.10.14 --login -d 8
iscsiadm: Max file limits 1024 1048576
iscsiadm: exec_node_op: : node [iqn.2008-08.com.starwindsoftware:10.35.15.14-lun0,192.168.10.14,3260] sid 0
iscsiadm: searching iqn.2008-08.com.starwindsoftware:10.35.15.14-lun0
iscsiadm: found 10.35.15.14,3260
iscsiadm: updated 'node.name', '' => 'iqn.2008-08.com.starwindsoftware:10.35.15.14-lun0'
iscsiadm: updated 'node.tpgt', '-1' => '-1'
iscsiadm: updated 'node.startup', 'manual' => 'automatic'
iscsiadm: updated 'node.leading_login', 'No' => 'No'
iscsiadm: updated 'iface.iscsi_ifacename', 'default' => 'default'
iscsiadm: updated 'iface.prefix_len', '0' => '0'
iscsiadm: updated 'iface.transport_name', 'tcp' => 'tcp'
iscsiadm: updated 'iface.vlan_id', '0' => '0'
iscsiadm: updated 'iface.vlan_priority', '0' => '0'
iscsiadm: updated 'iface.iface_num', '0' => '0'
iscsiadm: updated 'iface.mtu', '0' => '0'
iscsiadm: updated 'iface.port', '0' => '0'
iscsiadm: updated 'iface.tos', '0' => '0'
iscsiadm: updated 'iface.ttl', '0' => '0'
iscsiadm: updated 'iface.tcp_wsf', '0' => '0'
iscsiadm: updated 'iface.tcp_timer_scale', '0' => '0'
iscsiadm: updated 'iface.def_task_mgmt_timeout', '0' => '0'
iscsiadm: updated 'iface.erl', '0' => '0'
iscsiadm: updated 'iface.max_receive_data_len', '0' => '0'
iscsiadm: updated 'iface.first_burst_len', '0' => '0'
iscsiadm: updated 'iface.max_outstanding_r2t', '0' => '0'
iscsiadm: updated 'iface.max_burst_len', '0' => '0'
iscsiadm: updated 'node.discovery_address', '' => '10.35.15.14'
iscsiadm: updated 'node.discovery_port', '0' => '3260'
iscsiadm: updated 'node.discovery_type', 'static' => 'send_targets'
iscsiadm: updated 'node.session.initial_cmdsn', '0' => '0'
iscsiadm: updated 'node.session.initial_login_retry_max', '4' => '8'
iscsiadm: updated 'node.session.xmit_thread_priority', '-20' => '-20'
iscsiadm: updated 'node.session.cmds_max', '128' => '128'
iscsiadm: updated 'node.session.queue_depth', '32' => '32'
iscsiadm: updated 'node.session.nr_sessions', '1' => '1'
iscsiadm: updated 'node.session.auth.authmethod', 'None' => 'None'
iscsiadm: updated 'node.session.auth.chap_algs', 'MD5' => 'MD5'
iscsiadm: updated 'node.session.timeo.replacement_timeout', '120' => '15'
iscsiadm: updated 'node.session.err_timeo.abort_timeout', '15' => '15'
iscsiadm: updated 'node.session.err_timeo.lu_reset_timeout', '30' => '30'
iscsiadm: updated 'node.session.err_timeo.tgt_reset_timeout', '30' => '30'
iscsiadm: updated 'node.session.err_timeo.host_reset_timeout', '60' => '60'
iscsiadm: updated 'node.session.iscsi.FastAbort', 'Yes' => 'Yes'
iscsiadm: updated 'node.session.iscsi.InitialR2T', 'No' => 'No'
iscsiadm: updated 'node.session.iscsi.ImmediateData', 'Yes' => 'Yes'
iscsiadm: updated 'node.session.iscsi.FirstBurstLength', '262144' => '262144'
iscsiadm: updated 'node.session.iscsi.MaxBurstLength', '16776192' => '16776192'
iscsiadm: updated 'node.session.iscsi.DefaultTime2Retain', '0' => '0'
iscsiadm: updated 'node.session.iscsi.DefaultTime2Wait', '2' => '2'
iscsiadm: updated 'node.session.iscsi.MaxConnections', '1' => '1'
iscsiadm: updated 'node.session.iscsi.MaxOutstandingR2T', '1' => '1'
iscsiadm: updated 'node.session.iscsi.ERL', '0' => '0'
iscsiadm: updated 'node.session.scan', 'auto' => 'auto'
iscsiadm: updated 'node.session.reopen_max', '0' => '0'
iscsiadm: updated 'node.conn[0].address', '' => '10.35.15.14'
iscsiadm: updated 'node.conn[0].port', '3260' => '3260'
iscsiadm: updated 'node.conn[0].startup', 'manual' => 'manual'
iscsiadm: updated 'node.conn[0].tcp.window_size', '524288' => '524288'
iscsiadm: updated 'node.conn[0].tcp.type_of_service', '0' => '0'
iscsiadm: updated 'node.conn[0].timeo.logout_timeout', '15' => '15'
iscsiadm: updated 'node.conn[0].timeo.login_timeout', '30' => '15'
iscsiadm: updated 'node.conn[0].timeo.auth_timeout', '45' => '45'
iscsiadm: updated 'node.conn[0].timeo.noop_out_interval', '5' => '5'
iscsiadm: updated 'node.conn[0].timeo.noop_out_timeout', '5' => '5'
iscsiadm: updated 'node.conn[0].iscsi.MaxXmitDataSegmentLength', '0' => '0'
iscsiadm: updated 'node.conn[0].iscsi.MaxRecvDataSegmentLength', '262144' => '262144'
iscsiadm: updated 'node.conn[0].iscsi.HeaderDigest', 'None' => 'None'
iscsiadm: updated 'node.conn[0].iscsi.DataDigest', 'None' => 'None'
iscsiadm: updated 'node.conn[0].iscsi.IFMarker', 'No' => 'No'
iscsiadm: updated 'node.conn[0].iscsi.OFMarker', 'No' => 'No'
iscsiadm: match session [iqn.2008-08.com.starwindsoftware:10.35.15.14-lun0,192.168.10.14,3260][ ,,]:0
iscsiadm: to [iqn.2008-08.com.starwindsoftware:10.35.15.14-lun0,10.35.15.14,3260][default tcp,,]:0
iscsiadm: found 192.168.10.14,3260
iscsiadm: updated 'iface.ipaddress', '' => '192.168.10.18'
iscsiadm: updated 'iface.iscsi_ifacename', 'default' => 'iscsi-eth1'
iscsiadm: updated 'iface.net_ifacename', '' => 'vmbr2'
iscsiadm: updated 'node.discovery_address', '' => '192.168.10.14'
iscsiadm: updated 'node.conn[0].address', '' => '192.168.10.14'
iscsiadm: to [iqn.2008-08.com.starwindsoftware:10.35.15.14-lun0,192.168.10.14,3260][iscsi-eth1 tcp,,192.168.10.18]:0
iscsiadm: searching iqn.2008-08.com.starwindsoftware:10.35.15.14-lun1
iscsiadm: updated 'node.name', '' => 'iqn.2008-08.com.starwindsoftware:10.35.15.14-lun1'
iscsiadm: to [iqn.2008-08.com.starwindsoftware:10.35.15.14-lun1,10.35.15.14,3260][default tcp,,]:0
iscsiadm: to [iqn.2008-08.com.starwindsoftware:10.35.15.14-lun1,192.168.10.14,3260][iscsi-eth1 tcp,,192.168.10.18]:0
iscsiadm: iscsi-eth1: Creating session 1/1
Logging in to [iface: iscsi-eth1, target: iqn.2008-08.com.starwindsoftware:10.35.15.14-lun0, portal: 192.168.10.14,3260]
Mon Sep 22, 2025 2:53 pm
Proxmox2 was out of sync, this is expected because of node priority when th eplication link fails viewtopic.php?t=5731.
What you can do is try re-discovering the storage over iSCSI in both proxmox hosts using iscsiadm discovery and login commands from the guide https://www.starwindsoftware.com/resour ... ng-web-ui/.
Also, please install windows-based console (starwindsoftware.com/tmplink/starwind-v8.exe), connect to both CVMs and see if any device is synchronized.
If none synchronized, try marking 01 as synchronized (follow this guide https://knowledgebase.starwindsoftware. ... -blackout/ and use this method viewtopic.php?f=5&t=7257&p=40082&hilit=Uncomment#p40082).
Try also pinging the IPs inside the VM.
Good luck!
ehinkle29
Mon Sep 22, 2025 6:30 pm
Thanks for the response, I have tried the discovery and have been able to discover the nodes running the discover but still unable to connect when trying to login. None of the devices were in sync, even when I had both up and the sync and data paths reconnected so that is why i just shutdown vhca2 to see if I can get connect to that host. I do have the windows management software installed and this is what the logs show from the single node that is currently up and running. If I power back up the other node how can I have it start replicating or force it I have not been able to do that which is why I shut it down.
9/22 18:26:31.657647 43 Common: *** MountTarget: (session(0000000000986B78), local(0.0.0.0), peer(192.168.10.15), port(3260), target(iqn.2008-08.com.starwindsoftware:10.35.15.15-lun0).
9/22 18:26:33.055813 3a HA: *** HAPartnerISCSIChannelManager::sendCustomControlScsiCommand: EXITing with failure(failed), valid channel is not found!
9/22 18:26:33.055838 3a HA: *** CHAPartnerNode::SendPartnerNodeVersionRequestCommand: SendCustomControlScsiCommand(HA_CHANNEL_TYPE_SYNC) failed, error code 0x490, scsi status = 0x0!
9/22 18:26:33.055842 3a HA: CHAPartnerNode::SendPartnerNodeVersionRequestCommand: Try to get partner node version through heartbeat channel.
9/22 18:26:33.055845 3a HA: *** HAPartnerISCSIChannelManager::sendCustomControlScsiCommand: EXITing with failure(failed), valid channel is not found!
9/22 18:26:33.055849 3a HA: *** CHAPartnerNode::SendPartnerNodeVersionRequestCommand: EXITing with failure, SendCustomControlScsiCommand(HA_CHANNEL_TYPE_HEARTBEAT) failed, error code 0x490, scsi status = 0x0!
9/22 18:26:33.055852 3a HA: *** CHAPartnerNode::SendGetPartnerNodeInfoCommand: EXITing with failure, partner node version update failed!
9/22 18:26:33.235956 50 HA: *** HAPartnerISCSIChannelManager::sendCustomControlScsiCommand: EXITing with failure(failed), valid channel is not found!
9/22 18:26:33.235968 50 HA: *** CHAPartnerNode::SendPartnerNodeVersionRequestCommand: SendCustomControlScsiCommand(HA_CHANNEL_TYPE_SYNC) failed, error code 0x490, scsi status = 0x0!
9/22 18:26:33.235972 50 HA: CHAPartnerNode::SendPartnerNodeVersionRequestCommand: Try to get partner node version through heartbeat channel.
9/22 18:26:33.235975 50 HA: *** HAPartnerISCSIChannelManager::sendCustomControlScsiCommand: EXITing with failure(failed), valid channel is not found!
9/22 18:26:33.235978 50 HA: *** CHAPartnerNode::SendPartnerNodeVersionRequestCommand: EXITing with failure, SendCustomControlScsiCommand(HA_CHANNEL_TYPE_HEARTBEAT) failed, error code 0x490, scsi status = 0x0!
9/22 18:26:33.235981 50 HA: *** CHAPartnerNode::SendGetPartnerNodeInfoCommand: EXITing with failure, partner node version update failed!
9/22 18:26:33.599400 42 Common: *** ConnectTCP: An attempt to connect failed with error code 10065.
9/22 18:26:33.599400 58 Common: *** ConnectTCP: An attempt to connect failed with error code 10065.
9/22 18:26:33.599591 42 HA: *** CNIXInitiator::MountTarget: unable to mount the target (10065)!
9/22 18:26:33.599612 58 HA: *** CNIXInitiator::MountTarget: unable to mount the target (10065)!
9/22 18:26:34.719418 43 Common: *** ConnectTCP: An attempt to connect failed with error code 10065.
9/22 18:26:34.719418 59 Common: *** ConnectTCP: An attempt to connect failed with error code 10065.
9/22 18:26:34.719618 43 HA: *** CNIXInitiator::MountTarget: unable to mount the target (10065)!
9/22 18:26:34.719639 59 HA: *** CNIXInitiator::MountTarget: unable to mount the target (10065)!
9/22 18:26:38.601327 42 Common: *** MountTarget: (session(0000000000985DC8), local(0.0.0.0), peer(192.168.20.15), port(3260), target(iqn.2008-08.com.starwindsoftware:10.35.15.15-lun0).
9/22 18:26:38.601327 58 Common: *** MountTarget: (session(0000000000987148), local(0.0.0.0), peer(192.168.20.15), port(3260), target(iqn.2008-08.com.starwindsoftware:10.35.15.15-lun1).
9/22 18:26:39.721329 59 Common: *** MountTarget: (session(0000000000984388), local(0.0.0.0), peer(192.168.10.15), port(3260), target(iqn.2008-08.com.starwindsoftware:10.35.15.15-lun1).
9/22 18:26:39.721329 43 Common: *** MountTarget: (session(0000000000986B78), local(0.0.0.0), peer(192.168.10.15), port(3260), target(iqn.2008-08.com.starwindsoftware:10.35.15.15-lun0).
9/22 18:26:41.663417 42 Common: *** ConnectTCP: An attempt to connect failed with error code 10065.
9/22 18:26:41.663417 58 Common: *** ConnectTCP: An attempt to connect failed with error code 10065.
9/22 18:26:41.663618 42 HA: *** CNIXInitiator::MountTarget: unable to mount the target (10065)!
9/22 18:26:41.663641 58 HA: *** CNIXInitiator::MountTarget: unable to mount the target (10065)!
9/22 18:26:42.783494 43 Common: *** ConnectTCP: An attempt to connect failed with error code 10065.
9/22 18:26:42.783494 59 Common: *** ConnectTCP: An attempt to connect failed with error code 10065.
9/22 18:26:42.783691 43 HA: *** CNIXInitiator::MountTarget: unable to mount the target (10065)!
9/22 18:26:42.783715 59 HA: *** CNIXInitiator::MountTarget: unable to mount the target (10065)!
9/22 18:26:46.665912 42 Common: *** MountTarget: (session(0000000000985DC8), local(0.0.0.0), peer(192.168.20.15), port(3260), target(iqn.2008-08.com.starwindsoftware:10.35.15.15-lun0).
9/22 18:26:46.665912 58 Common: *** MountTarget: (session(0000000000987148), local(0.0.0.0), peer(192.168.20.15), port(3260), target(iqn.2008-08.com.starwindsoftware:10.35.15.15-lun1).
9/22 18:26:47.785668 59 Common: *** MountTarget: (session(0000000000984388), local(0.0.0.0), peer(192.168.10.15), port(3260), target(iqn.2008-08.com.starwindsoftware:10.35.15.15-lun1).
9/22 18:26:47.785873 43 Common: *** MountTarget: (session(0000000000986B78), local(0.0.0.0), peer(192.168.10.15), port(3260), target(iqn.2008-08.com.starwindsoftware:10.35.15.15-lun0).
9/22 18:26:49.727404 42 Common: *** ConnectTCP: An attempt to connect failed with error code 10065.
9/22 18:26:49.727404 58 Common: *** ConnectTCP: An attempt to connect failed with error code 10065.
9/22 18:26:49.727633 58 HA: *** CNIXInitiator::MountTarget: unable to mount the target (10065)!
9/22 18:26:49.727669 42 HA: *** CNIXInitiator::MountTarget: unable to mount the target (10065)!
9/22 18:26:50.847438 59 Common: *** ConnectTCP: An attempt to connect failed with error code 10065.
9/22 18:26:50.847444 43 Common: *** ConnectTCP: An attempt to connect failed with error code 10065.
9/22 18:26:50.847623 59 HA: *** CNIXInitiator::MountTarget: unable to mount the target (10065)!
9/22 18:26:50.847670 43 HA: *** CNIXInitiator::MountTarget: unable to mount the target (10065)!
9/22 18:26:54.729524 58 Common: *** MountTarget: (session(0000000000987148), local(0.0.0.0), peer(192.168.20.15), port(3260), target(iqn.2008-08.com.starwindsoftware:10.35.15.15-lun1).
9/22 18:26:54.729524 42 Common: *** MountTarget: (session(0000000000985DC8), local(0.0.0.0), peer(192.168.20.15), port(3260), target(iqn.2008-08.com.starwindsoftware:10.35.15.15-lun0).
9/22 18:26:55.849175 43 Common: *** MountTarget: (session(0000000000986B78), local(0.0.0.0), peer(192.168.10.15), port(3260), target(iqn.2008-08.com.starwindsoftware:10.35.15.15-lun0).
9/22 18:26:55.849177 59 Common: *** MountTarget: (session(0000000000984388), local(0.0.0.0), peer(192.168.10.15), port(3260), target(iqn.2008-08.com.starwindsoftware:10.35.15.15-lun1).
9/22 18:26:57.791411 42 Common: *** ConnectTCP: An attempt to connect failed with error code 10065.
9/22 18:26:57.791409 58 Common: *** ConnectTCP: An attempt to connect failed with error code 10065.
9/22 18:26:57.791628 42 HA: *** CNIXInitiator::MountTarget: unable to mount the target (10065)!
9/22 18:26:57.791649 58 HA: *** CNIXInitiator::MountTarget: unable to mount the target (10065)!
9/22 18:26:58.911394 43 Common: *** ConnectTCP: An attempt to connect failed with error code 10065.
9/22 18:26:58.911397 59 Common: *** ConnectTCP: An attempt to connect failed with error code 10065.
9/22 18:26:58.911595 43 HA: *** CNIXInitiator::MountTarget: unable to mount the target (10065)!
9/22 18:26:58.911618 59 HA: *** CNIXInitiator::MountTarget: unable to mount the target (10065)!
9/22 18:27:02.793488 42 Common: *** MountTarget: (session(0000000000985DC8), local(0.0.0.0), peer(192.168.20.15), port(3260), target(iqn.2008-08.com.starwindsoftware:10.35.15.15-lun0).
ehinkle29
Mon Sep 22, 2025 6:46 pm
If I have both nodes on, this is what the logs show.
Node 1
9/22 18:32:29.736850 1ef FileBrowser: CFileBrowser::command: Return param: 'DiskSize' = 'Failed: Specified file can not be opened'
9/22 18:32:29.737200 1ef FileBrowser: CFileBrowser::command: Return param: 'DiskSize' = 'Failed: Specified file can not be opened'
9/22 18:32:29.737447 1ef Srv: ControlConnection::processConnection: finish 10.35.15.15:47242
9/22 18:32:29.737454 1ef Srv: ControlConnection::stop: 10.35.15.15:47242
9/22 18:32:29.737775 5e Srv: TelnetListener::listenConnections: Accepted control connection from 10.35.15.15:47264.
9/22 18:32:29.738043 1ea Srv: ControlConnection::processConnection: start processing 10.35.15.15:47264
9/22 18:32:29.739138 1ea Srv: ControlConnection::processConnection: finish 10.35.15.15:47264
9/22 18:32:29.739146 1ea Srv: ControlConnection::stop: 10.35.15.15:47264
9/22 18:32:29.739491 5e Srv: TelnetListener::listenConnections: Accepted control connection from 10.35.15.15:47280.
9/22 18:32:29.739741 1f0 Srv: ControlConnection::processConnection: start processing 10.35.15.15:47280
9/22 18:32:29.743461 1f0 Srv: ControlConnection::processConnection: finish 10.35.15.15:47280
9/22 18:32:29.743470 1f0 Srv: ControlConnection::stop: 10.35.15.15:47280
9/22 18:32:29.764568 5e Srv: TelnetListener::listenConnections: Accepted control connection from 10.35.15.15:47290.
9/22 18:32:29.764836 1e9 Srv: ControlConnection::processConnection: start processing 10.35.15.15:47290
9/22 18:32:29.765940 1e9 FileBrowser: CFileBrowser::command: Return param: 'DiskSize' = '30837178368'
9/22 18:32:29.766291 1e9 FileBrowser: CFileBrowser::command: Return param: 'FreeSpace' = '18644226048'
9/22 18:32:29.768510 5e Srv: TelnetListener::listenConnections: Accepted control connection from 10.35.15.15:47294.
9/22 18:32:29.768777 1d4 Srv: ControlConnection::processConnection: start processing 10.35.15.15:47294
9/22 18:32:29.772569 1d4 Srv: ControlConnection::processConnection: finish 10.35.15.15:47294
9/22 18:32:29.772580 1d4 Srv: ControlConnection::stop: 10.35.15.15:47294
9/22 18:32:29.772841 1e9 FileBrowser: CFileBrowser::command: Return param: 'DiskSize' = 'Failed: Specified file can not be opened'
9/22 18:32:29.773144 1e9 FileBrowser: CFileBrowser::command: Return param: 'DiskSize' = 'Failed: Specified file can not be opened'
9/22 18:32:29.773420 1e9 Srv: ControlConnection::processConnection: finish 10.35.15.15:47290
9/22 18:32:29.773428 1e9 Srv: ControlConnection::stop: 10.35.15.15:47290
9/22 18:32:29.773778 5e Srv: TelnetListener::listenConnections: Accepted control connection from 10.35.15.15:47308.
9/22 18:32:29.774025 1f6 Srv: ControlConnection::processConnection: start processing 10.35.15.15:47308
9/22 18:32:29.775189 1f6 Srv: ControlConnection::processConnection: finish 10.35.15.15:47308
9/22 18:32:29.775197 1f6 Srv: ControlConnection::stop: 10.35.15.15:47308
9/22 18:32:29.775572 5e Srv: TelnetListener::listenConnections: Accepted control connection from 10.35.15.15:47320.
9/22 18:32:29.775839 1ec Srv: ControlConnection::processConnection: start processing 10.35.15.15:47320
9/22 18:32:29.779739 1ec Srv: ControlConnection::processConnection: finish 10.35.15.15:47320
9/22 18:32:29.779749 1ec Srv: ControlConnection::stop: 10.35.15.15:47320
node2
9/22 18:32:31.419386 3b func: <<< HANode::reportEvent
9/22 18:32:31.419389 3b HA: HADeviceEventTask::execute: Event: HA_NN_ALL_CHANNELS_BECOME_VALID, Partner node: 'iqn.2008-08.com.starwindsoftware:10.35.15.14-lun0', ulChannelManagerId = 2.
9/22 18:32:31.463629 57 HA: HAPartneriScsiChannel::permanentConnectionPollingThread: Event: Established connection - Device(0x00000000012A3378), IP(192.168.20.14), InitiatorName(iqn.2008-08.com.starwindsoftware:10.35.15.15-lun1), Target(iqn.2008-08.com.starwindsoftware:10.35.15.14-lun1)!
9/22 18:32:31.463684 51 func: >>> HANode::reportEvent
9/22 18:32:31.463698 51 func: >>> iScsiServer::sendNotification
9/22 18:32:31.463702 51 func: >>> CEventDataBase::AddRecord
9/22 18:32:31.463705 51 EventDB: CEventDataBase::AddRecord: Code 777, severity 1, additional strings: 4
9/22 18:32:31.463717 51 func: <<< CEventDataBase::AddRecord
9/22 18:32:31.463721 51 Srv: iScsiServer::sendNotification: Send reaction start (reaction type 2, msg code 777).
9/22 18:32:31.463727 51 Srv: iScsiServer::sendNotification: Send reaction finish.
9/22 18:32:31.463730 51 Srv: iScsiServer::sendNotification: Send reaction start (reaction type 1, msg code 777).
9/22 18:32:31.463832 51 Srv: iScsiServer::sendNotification: Send reaction finish.
9/22 18:32:31.463838 51 func: <<< iScsiServer::sendNotification
9/22 18:32:31.463842 51 func: <<< HANode::reportEvent
9/22 18:32:31.463845 51 HA: HADeviceEventTask::execute: Event: HA_NN_CHANNEL_BECOME_VALID, Partner node: 'iqn.2008-08.com.starwindsoftware:10.35.15.14-lun1', ulChannelManagerId = 1, ulChannelId = 1.
9/22 18:32:31.464510 51 HA: HADeviceEventTask::execute: Event: HA_NN_FIRST_VALID_CONNECTION_ESTABLISHED, Partner node: 'iqn.2008-08.com.starwindsoftware:10.35.15.14-lun1', ulChannelManagerId = 1, ulChannelId = 1.
9/22 18:32:31.464778 51 func: >>> CHAPartnerNode::SetSyncStatus
9/22 18:32:31.464788 51 HA: CHAPartnerNode::SetSyncStatus: Params(new status = 3, old status = 3) ENTERed for partner 'iqn.2008-08.com.starwindsoftware:10.35.15.14-lun1'.
9/22 18:32:31.464791 51 func: <<< CHAPartnerNode::SetSyncStatus
9/22 18:32:31.464795 51 func: >>> HANode::reportEvent
9/22 18:32:31.464799 51 func: >>> iScsiServer::sendNotification
9/22 18:32:31.464803 51 func: >>> CEventDataBase::AddRecord
9/22 18:32:31.464806 51 EventDB: CEventDataBase::AddRecord: Code 837, severity 1, additional strings: 3
9/22 18:32:31.464816 51 func: <<< CEventDataBase::AddRecord
9/22 18:32:31.464819 51 Srv: iScsiServer::sendNotification: Send reaction start (reaction type 2, msg code 837).
9/22 18:32:31.464825 51 Srv: iScsiServer::sendNotification: Send reaction finish.
9/22 18:32:31.464828 51 Srv: iScsiServer::sendNotification: Send reaction start (reaction type 1, msg code 837).
9/22 18:32:31.465058 51 Srv: iScsiServer::sendNotification: Send reaction finish.
9/22 18:32:31.465064 51 func: <<< iScsiServer::sendNotification
9/22 18:32:31.465068 51 func: <<< HANode::reportEvent
9/22 18:32:31.465071 51 HA: HADeviceEventTask::execute: Event: HA_NN_ALL_CHANNELS_BECOME_VALID, Partner node: 'iqn.2008-08.com.starwindsoftware:10.35.15.14-lun1', ulChannelManagerId = 1.
9/22 18:32:31.472190 58 HA: HAPartneriScsiChannel::permanentConnectionPollingThread: Event: Established connection - Device(0x00000000012AB7A8), IP(192.168.10.14), InitiatorName(iqn.2008-08.com.starwindsoftware:10.35.15.15-lun1), Target(iqn.2008-08.com.starwindsoftware:10.35.15.14-lun1)!
9/22 18:32:31.472234 51 func: >>> HANode::reportEvent
9/22 18:32:31.472241 51 func: >>> iScsiServer::sendNotification
9/22 18:32:31.472245 51 func: >>> CEventDataBase::AddRecord
9/22 18:32:31.472252 51 EventDB: CEventDataBase::AddRecord: Code 777, severity 1, additional strings: 4
9/22 18:32:31.472263 51 func: <<< CEventDataBase::AddRecord
9/22 18:32:31.472266 51 Srv: iScsiServer::sendNotification: Send reaction start (reaction type 2, msg code 777).
9/22 18:32:31.472272 51 Srv: iScsiServer::sendNotification: Send reaction finish.
9/22 18:32:31.472276 51 Srv: iScsiServer::sendNotification: Send reaction start (reaction type 1, msg code 777).
9/22 18:32:31.472480 51 Srv: iScsiServer::sendNotification: Send reaction finish.
9/22 18:32:31.472485 51 func: <<< iScsiServer::sendNotification
9/22 18:32:31.472489 51 func: <<< HANode::reportEvent
9/22 18:32:31.472492 51 HA: HADeviceEventTask::execute: Event: HA_NN_CHANNEL_BECOME_VALID, Partner node: 'iqn.2008-08.com.starwindsoftware:10.35.15.14-lun1', ulChannelManagerId = 2, ulChannelId = 1.
9/22 18:32:31.472495 51 HA: HADeviceEventTask::execute: Event: HA_NN_FIRST_VALID_CONNECTION_ESTABLISHED, Partner node: 'iqn.2008-08.com.starwindsoftware:10.35.15.14-lun1', ulChannelManagerId = 2, ulChannelId = 1.
9/22 18:32:31.472498 51 func: >>> HANode::reportEvent
9/22 18:32:31.472502 51 func: >>> iScsiServer::sendNotification
9/22 18:32:31.472505 51 func: >>> CEventDataBase::AddRecord
9/22 18:32:31.472508 51 EventDB: CEventDataBase::AddRecord: Code 837, severity 1, additional strings: 3
9/22 18:32:31.472516 51 func: <<< CEventDataBase::AddRecord
9/22 18:32:31.472519 51 Srv: iScsiServer::sendNotification: Send reaction start (reaction type 2, msg code 837).
9/22 18:32:31.472524 51 Srv: iScsiServer::sendNotification: Send reaction finish.
9/22 18:32:31.472527 51 Srv: iScsiServer::sendNotification: Send reaction start (reaction type 1, msg code 837).
9/22 18:32:31.472605 51 Srv: iScsiServer::sendNotification: Send reaction finish.
9/22 18:32:31.472610 51 func: <<< iScsiServer::sendNotification
9/22 18:32:31.472614 51 func: <<< HANode::reportEvent
9/22 18:32:31.472617 51 HA: HADeviceEventTask::execute: Event: HA_NN_ALL_CHANNELS_BECOME_VALID, Partner node: 'iqn.2008-08.com.starwindsoftware:10.35.15.14-lun1', ulChannelManagerId = 2.
9/22 18:42:23.804360 60 Srv: TelnetListener::listenConnections: Accepted control connection from 10.35.5.54:63512.
9/22 18:42:23.804868 89 Srv: ControlConnection::processConnection: start processing 10.35.5.54:63512
ehinkle29
Mon Sep 22, 2025 6:50 pm
would upload log file but don't see where and i noticed node2 log files is 23m versus node 1 which is 131k.
Tue Sep 23, 2025 6:01 am
Check sync status. It looks like none of them is synchronized.
Please check it, and mark as synchronized if needed.
ehinkle29
Tue Sep 23, 2025 2:31 pm
I am running the appliances and it shows this via the management console. How would I mark as synchronized, i can't do that via the web gui?
https://i.postimg.cc/zDdm7BF7/node1.jpg
https://i.postimg.cc/PrBRV8pW/node2.jpg
Tue Sep 23, 2025 3:53 pm
Check this out.
ehinkle29
Tue Sep 23, 2025 11:02 pm
I tried that against the primary first and got the below error. How can I shutdown one node and get it running so i can connect to it via my Iscsi clients, that is the main thing I am trying to do? I can always look at just killing one and then rebuilding it, but I need to get to the disk that were on the cluster.
I see on node 1 it talking about a CFileBrowser can't be found in the logs but not in node 2, could that be a problem on node1?
PS C:\Program Files\StarWind Software\StarWind\StarWindX\Samples\powershell> C:\Program Files\StarWind Software\StarWind\StarWindX\Samples\powershell\SyncHaDeviceAdvanced_cust.ps1
HAImage1
Device not synchronized. Synchronize current node from partner 'iqn.2008-08.com.starwindsoftware:10.35.15.15-lun0'
Failed to perform synchronization (1) from iqn.2008-08.com.starwindsoftware:10.35.15.15-lun0
control 0x0000000001186A00 -Synchronize: -SynchronizationType:"1" -SynchronizerTargetName:"iqn.2008-08.com.starwindsoftware:10.35.15.15-lun0"
200 Failed: synchronizer has invalid state..
I ran it a second time and got this message.
PS C:\Program Files\StarWind Software\StarWind\StarWindX\Samples\powershell> C:\Program Files\StarWind Software\StarWind\StarWindX\Samples\powershell\SyncHaDevice_cust.ps1
Synchronize device HAImage1
control 0x000000000118FFC0 -Synchronize: -SynchronizationType:"1"
200 Failed: can't find available or valid partner for synchronization..
This is what the logs show on node 1
9/22 18:32:28.423616 3c HA: HADeviceEventTask::execute: Event: HA_NN_ALL_CHANNELS_BECOME_VALID, Partner node: 'iqn.2008-08.com.starwindsoftware:10.35.15.15-lun0', ulChannelManagerId = 2.
9/22 18:32:28.426572 59 HA: HAPartneriScsiChannel::permanentConnectionPollingThread: Event: Established connection - Device(0x00000000012A9158), IP(192.168.10.15), InitiatorName(iqn.2008-08.com.starwindsoftware:10.35.15.14-lun1), Target(iqn.2008-08.com.starwindsoftware:10.35.15.15-lun1)!
9/22 18:32:28.426653 52 func: >>> HANode::reportEvent
9/22 18:32:28.426661 52 func: >>> iScsiServer::sendNotification
9/22 18:32:28.426665 52 func: >>> CEventDataBase::AddRecord
9/22 18:32:28.426668 52 EventDB: CEventDataBase::AddRecord: Code 777, severity 1, additional strings: 4
9/22 18:32:28.426679 52 func: <<< CEventDataBase::AddRecord
9/22 18:32:28.426683 52 Srv: iScsiServer::sendNotification: Send reaction start (reaction type 2, msg code 777).
9/22 18:32:28.426689 52 Srv: iScsiServer::sendNotification: Send reaction finish.
9/22 18:32:28.426693 52 Srv: iScsiServer::sendNotification: Send reaction start (reaction type 1, msg code 777).
9/22 18:32:28.426792 52 Srv: iScsiServer::sendNotification: Send reaction finish.
9/22 18:32:28.426799 52 func: <<< iScsiServer::sendNotification
9/22 18:32:28.426802 52 func: <<< HANode::reportEvent
9/22 18:32:28.426811 52 HA: HADeviceEventTask::execute: Event: HA_NN_CHANNEL_BECOME_VALID, Partner node: 'iqn.2008-08.com.starwindsoftware:10.35.15.15-lun1', ulChannelManagerId = 2, ulChannelId = 1.
9/22 18:32:28.426815 52 HA: HADeviceEventTask::execute: Event: HA_NN_FIRST_VALID_CONNECTION_ESTABLISHED, Partner node: 'iqn.2008-08.com.starwindsoftware:10.35.15.15-lun1', ulChannelManagerId = 2, ulChannelId = 1.
9/22 18:32:28.426818 52 func: >>> HANode::reportEvent
9/22 18:32:28.426822 52 func: >>> iScsiServer::sendNotification
9/22 18:32:28.426826 52 func: >>> CEventDataBase::AddRecord
9/22 18:32:28.426829 52 EventDB: CEventDataBase::AddRecord: Code 837, severity 1, additional strings: 3
9/22 18:32:28.426838 52 func: <<< CEventDataBase::AddRecord
9/22 18:32:28.426841 52 Srv: iScsiServer::sendNotification: Send reaction start (reaction type 2, msg code 837).
9/22 18:32:28.426847 52 Srv: iScsiServer::sendNotification: Send reaction finish.
9/22 18:32:28.426850 52 Srv: iScsiServer::sendNotification: Send reaction start (reaction type 1, msg code 837).
9/22 18:32:28.426937 52 Srv: iScsiServer::sendNotification: Send reaction finish.
9/22 18:32:28.426944 52 func: <<< iScsiServer::sendNotification
9/22 18:32:28.426947 52 func: <<< HANode::reportEvent
9/22 18:32:28.426951 52 HA: HADeviceEventTask::execute: Event: HA_NN_ALL_CHANNELS_BECOME_VALID, Partner node: 'iqn.2008-08.com.starwindsoftware:10.35.15.15-lun1', ulChannelManagerId = 2.
9/22 18:32:29.630447 5e Srv: TelnetListener::listenConnections: Accepted control connection from 10.35.15.15:47192.
9/22 18:32:29.630854 1eb Srv: ControlConnection::processConnection: start processing 10.35.15.15:47192
9/22 18:32:29.632907 1eb FileBrowser: CFileBrowser::command: Return param: 'DiskSize' = '30837178368'
9/22 18:32:29.633289 1eb FileBrowser: CFileBrowser::command: Return param: 'FreeSpace' = '18644230144'
9/22 18:32:29.637853 5e Srv: TelnetListener::listenConnections: Accepted control connection from 10.35.15.15:47206.
9/22 18:32:29.638140 1e4 Srv: ControlConnection::processConnection: start processing 10.35.15.15:47206
9/22 18:32:29.664001 1e4 Srv: ControlConnection::processConnection: finish 10.35.15.15:47206
9/22 18:32:29.664011 1e4 Srv: ControlConnection::stop: 10.35.15.15:47206
9/22 18:32:29.677149 1eb FileBrowser: CFileBrowser::command: Return param: 'DiskSize' = 'Failed: Specified file can not be opened'
9/22 18:32:29.677631 1eb FileBrowser: CFileBrowser::command: Return param: 'DiskSize' = 'Failed: Specified file can not be opened'
9/22 18:32:29.678083 1eb Srv: ControlConnection::processConnection: finish 10.35.15.15:47192
9/22 18:32:29.678091 1eb Srv: ControlConnection::stop: 10.35.15.15:47192
9/22 18:32:29.678983 5e Srv: TelnetListener::listenConnections: Accepted control connection from 10.35.15.15:47222.
9/22 18:32:29.679268 1f1 Srv: ControlConnection::processConnection: start processing 10.35.15.15:47222
9/22 18:32:29.681823 1f1 Srv: ControlConnection::processConnection: finish 10.35.15.15:47222
9/22 18:32:29.681832 1f1 Srv: ControlConnection::stop: 10.35.15.15:47222
9/22 18:32:29.684970 5e Srv: TelnetListener::listenConnections: Accepted control connection from 10.35.15.15:47226.
9/22 18:32:29.685206 1e6 Srv: ControlConnection::processConnection: start processing 10.35.15.15:47226
9/22 18:32:29.689424 1e6 Srv: ControlConnection::processConnection: finish 10.35.15.15:47226
9/22 18:32:29.689434 1e6 Srv: ControlConnection::stop: 10.35.15.15:47226
9/22 18:32:29.727176 5e Srv: TelnetListener::listenConnections: Accepted control connection from 10.35.15.15:47242.
9/22 18:32:29.727457 1ef Srv: ControlConnection::processConnection: start processing 10.35.15.15:47242
9/22 18:32:29.729406 1ef FileBrowser: CFileBrowser::command: Return param: 'DiskSize' = '30837178368'
9/22 18:32:29.729768 1ef FileBrowser: CFileBrowser::command: Return param: 'FreeSpace' = '18644230144'
9/22 18:32:29.731846 5e Srv: TelnetListener::listenConnections: Accepted control connection from 10.35.15.15:47256.
9/22 18:32:29.732156 1ed Srv: ControlConnection::processConnection: start processing 10.35.15.15:47256
9/22 18:32:29.736580 1ed Srv: ControlConnection::processConnection: finish 10.35.15.15:47256
9/22 18:32:29.736589 1ed Srv: ControlConnection::stop: 10.35.15.15:47256
node 2
9/23 22:57:55.274568 60 Srv: TelnetListener::listenConnections: Accepted control connection from 10.35.5.54:53804.
9/23 22:57:55.275206 8a Srv: ControlConnection::processConnection: start processing 10.35.5.54:53804
9/23 22:57:55.304529 8a HA: SscPort_ControlRequest: Event: Received Synchronize command from console (sync_type = 1, synchronizer = '(null)', snapshot_id = 0)
9/23 22:57:55.305525 8a HA: *** HANode::FindPartnerNodeByTargetName: Partner node name is empty!
9/23 22:57:55.305534 8a HA: HANode::synchronizeCurrentNode: Params(partnerNode = 0x0000000000000000, syncType = 1, snapshotId = 0x0, ignoreOwnSyncState = 0) ENTERed
9/23 22:57:55.306248 8a HA: *** HANode::checkSynchronizationStartAvailability: Partner node(synchronizer) for synchronization is not found!
9/23 22:57:55.306256 8a HA: HANode::synchronizeCurrentNode: Synchronization can't be run!
9/23 22:57:55.311366 8a Srv: ControlConnection::processConnection: finish 10.35.5.54:53804
9/23 22:57:55.311375 8a Srv: ControlConnection::stop: 10.35.5.54:53804
9/23 23:02:00.376162 60 Srv: TelnetListener::listenConnections: Accepted control connection from 10.35.5.54:54208.
9/23 23:02:00.376592 8b Srv: ControlConnection::processConnection: start processing 10.35.5.54:54208
9/23 23:02:00.399954 8b HA: SscPort_ControlRequest: Event: Received Synchronize command from console (sync_type = 1, synchronizer = '(null)', snapshot_id = 0)
9/23 23:02:00.400786 8b HA: *** HANode::FindPartnerNodeByTargetName: Partner node name is empty!
9/23 23:02:00.400793 8b HA: HANode::synchronizeCurrentNode: Params(partnerNode = 0x0000000000000000, syncType = 1, snapshotId = 0x0, ignoreOwnSyncState = 0) ENTERed
9/23 23:02:00.401455 8b HA: *** HANode::checkSynchronizationStartAvailability: Partner node(synchronizer) for synchronization is not found!
9/23 23:02:00.401469 8b HA: HANode::synchronizeCurrentNode: Synchronization can't be run!
9/23 23:02:00.403671 8b Srv: ControlConnection::processConnection: finish 10.35.5.54:54208
9/23 23:02:00.403679 8b Srv: ControlConnection::stop: 10.35.5.54:54208
Wed Sep 24, 2025 7:33 am
Did you have a chance to edit that script?
No need to rebuild anything. Just trigger full sync.
You can stop one cvm, run the script for the remaining one ans check data. As mentioned in the article, your pricedure should be stop one cvm > run script adjusted the way I described >check console to se if the right nodr is synchronized >rescan storage by running iscsiadm login > check vm data. If all good, start the node you stopped.
ehinkle29
Wed Sep 24, 2025 12:46 pm
I have followed that step, shutdown node2, uncomment the section of the script as stated, but I still get an error when running the script and the system shows not synced.
Below is what that section of the script looks like
	if($device.SyncStatus -ne [SwHaSyncStatus]::SW_HA_SYNC_STATUS_SYNC)
		Write-Host "Synchronize device $($device.name)" -foreground yellow
		$device.Synchronize([SwHaSyncType]::SW_HA_SYNC_FULL, "")
		$device.MarkAsSynchronized()
	else
		Write-Host "Device $($device.name) is synchronized" -foreground yellow
catch
This is the error shown when running the script with the node1 ip address
control 0x000000000118DA00 -Synchronize: -SynchronizationType:"1"
This is what it shows in the console and when I try logging in from the iscsi client it fails.
https://i.postimg.cc/0QCcfnFj/node1-aftersync.png
Last login: Wed Sep 24 08:41:37 EDT 2025 from 10.35.15.20 on pts/0
root@pve02:~# iscsiadm -m discovery -t st -p 192.168.10.14
192.168.10.14:3260,-1 iqn.2008-08.com.starwindsoftware:10.35.15.14-lun0
192.168.10.14:3260,-1 iqn.2008-08.com.starwindsoftware:10.35.15.14-lun1
root@pve02:~# iscsiadm -m node -T iqn.2008-08.com.starwindsoftware:10.35.15.14-lun0 -p 192.168.10.14 --login -d 8
iscsiadm: to [iqn.2008-08.com.starwindsoftware:10.35.15.14-lun0,192.168.10.14,3260][default tcp,,]:0
iscsiadm: to [iqn.2008-08.com.starwindsoftware:10.35.15.14-lun1,192.168.10.14,3260][default tcp,,]:0
iscsiadm: searching iqn.2008-08.com.starwindsoftware:10.35.15.15-lun0
iscsiadm: found 10.35.15.15,3260
iscsiadm: updated 'node.name', '' => 'iqn.2008-08.com.starwindsoftware:10.35.15.15-lun0'
iscsiadm: updated 'node.discovery_address', '' => '10.35.15.15'
iscsiadm: updated 'node.conn[0].address', '' => '10.35.15.15'
iscsiadm: to [iqn.2008-08.com.starwindsoftware:10.35.15.15-lun0,10.35.15.15,3260][default tcp,,]:0
iscsiadm: found 192.168.10.15,3260
iscsiadm: updated 'node.discovery_address', '' => '192.168.10.15'
iscsiadm: updated 'node.conn[0].address', '' => '192.168.10.15'
iscsiadm: to [iqn.2008-08.com.starwindsoftware:10.35.15.15-lun0,192.168.10.15,3260][default tcp,,]:0
iscsiadm: searching iqn.2008-08.com.starwindsoftware:10.35.15.15-lun1
iscsiadm: updated 'node.name', '' => 'iqn.2008-08.com.starwindsoftware:10.35.15.15-lun1'
iscsiadm: to [iqn.2008-08.com.starwindsoftware:10.35.15.15-lun1,10.35.15.15,3260][default tcp,,]:0
iscsiadm: to [iqn.2008-08.com.starwindsoftware:10.35.15.15-lun1,192.168.10.15,3260][default tcp,,]:0
iscsiadm: default: Creating session 1/1
Logging in to [iface: default, target: iqn.2008-08.com.starwindsoftware:10.35.15.14-lun0, portal: 192.168.10.14,3260]
Wed Sep 24, 2025 1:35 pm
Please share the entire script with me and make sure that the password is root/starwind.
ehinkle29
Wed Sep 24, 2025 3:21 pm
This is the script.
param($addr="10.35.15.14", $port=3261, $user="root", $password="starwind", $deviceName="HAImage1")
Import-Module StarWindX
try
	Enable-SWXLog
	$server = New-SWServer $addr $port $user $password
	$server.Connect()
	if( !$device )
		Write-Host "Device not found" -foreground red
		return
	else
catch
	Write-Host $_ -foreground red
finally
	$server.Disconnect()
Wed Sep 24, 2025 7:36 pm
Is not commented in your script.
ehinkle29
Thu Sep 25, 2025 10:26 pm
Okay, missed that, looks like that worked.
