Starwind x Proxmox Plugin on Proxmox 9
aptfinf
Tue Sep 09, 2025 2:15 pm
I have installed the Starwind x Proxmox plugin (version 1.0.2) on Proxmox 8.4, and I'm thinking about upgrading the cluster to Proxmox 9.
Clearly, in the in-place upgrade steps, it's mentioned that if you're using a third party storage plugin, you have to wait until the plugin author adapted it for Proxmox VE 9.0.
In the installation guide, there isn't an indication about the supported versions.
Is this plugin compatible with Proxmox 9?
Thank you
Wed Sep 10, 2025 9:45 am
It should, but I'd suggest postponing the updates for now, as we have not completed the tests for Proxmox9.
Stay tuned.
aptfinf
Fri Sep 26, 2025 9:08 am
Stay tuned.
Hi yaroslav,
I would like to point out to you that I tried in a lab the upgrade and snapshots on storage backed up by the plugin doesn't work anymore with the following error:
"can't rollback snapshot for 'raw' volume"
Fri Sep 26, 2025 10:01 am
Thanks for your update we will test that additionally.
ian.steigrad
Tue Nov 04, 2025 11:06 pm
Hello! I am putting together a new setup with Proxmox 9 and Starwind VSAN including the Starwind x Proxmox plugin (version 1.0.2) - The whole thing has been pretty east thanks to the various guides and this forum so thank you!
Quick question - I have also noticed some issues with live migration and snapshots using the plugin and Proxmox 9. its not a big deal for our setup, I can wait a bit for a fix but eventually we will want to use these features. Wondering if there's a likely fix soon, or if I should re-build with Proxmox 8.4 for now.
Tue Nov 04, 2025 11:24 pm
Welcome to StarWind Forum, yes we plan fixing these behaviors.
ian.steigrad
Wed Nov 05, 2025 12:07 am
Thanks Yaroslav, much appreciated. I'll stick with Proxmox 9 then.
Wed Nov 05, 2025 7:53 am
You are welcome! Good luck with your project!
tritonb7@gmail.com
Tue Nov 11, 2025 1:41 am
Is there an ETA on an update on getting the snapshots working again with the plugin?
Tue Nov 11, 2025 6:26 am
Snapshots still work, but it needs to be Proxmox8.
We are working onsnapshot support for Proxmox9. Sadly, I have no ETA now.
Sorry forno news.
ticktok
Tue Nov 11, 2025 7:19 am
I know that there is no ETA but are we looking at days, weeks, months or years?
Tue Nov 11, 2025 8:49 am
I hope it is months.
echo
Fri Dec 05, 2025 2:32 am
Does anyone know if there have been any updates on this issue or where I can look to find updates as they are made? My team can take but not revert snapshots on Proxmox 9.0.3.
Fri Dec 05, 2025 8:23 am
You are welcome to try thick volumes (i.e., non-starwlvm ones).
I hope it will arrive in the middle of Q1 next year.
tritonb7@gmail.com
Fri Feb 06, 2026 7:53 pm
Any update on the status o f this plugin?
