both nodes say NOT SYNCHRONIZED
Gim
Mon Sep 01, 2025 9:59 am
I'm using Starwind's Free virtual SAN version.
8.0.14338.0
Following storms and multiple reboots, the status of my two nodes is out of sync.
I tried the solutions suggested on the forum:
If both nodes say NOT SYNCHRONIZED and PARTNER NOT SYNCHRONIZED
1. Stop StarWindService on both
2. For one go to the headers directory and edit HA.swdsk
see the area that looks like
<node id="1" name="HAImage" shut="false" active="true" flags="0">
<storages>
<storage_ref id="1"/>
</storages>
<parameters>
<type>1</type>
<priority>2</priority>
<auto_sync>true</auto_sync>
<sync_status>1</sync_status>
<sync_delay>50</sync_delay>
<sync_traffic_share>50</sync_traffic_share>
<failover_conf>0</failover_conf>
<last_sync_snap_id>0</last_sync_snap_id>
<alua_access_state>0</alua_access_state>
</parameters>
</node>
<node id="2" name="iqn.2008-08.com.starwindsoftware:10.1.101.4-swstorage3" shut="false" active="true">
<storages>
<storage_ref id="2"/>
</storages>
<parameters>
<type>1</type>
<priority>1</priority>
<sync_status>0</sync_status>
<type_bitmap>RAM</type_bitmap>
</parameters>
</node>
</header>
3. Start the service.
4. Bring up the storage in Failvoer Cluster or rescan ESXi hosts.
5. Make sure data is up-to-date.
6. If up-to-date, start StarWind Service on the remaining node.
I have removed the caching as instructed but get the same error
Thank you for your help.
I should be able to recover my VMs on one of the two nodes.
Mon Sep 01, 2025 10:13 am
To force synchronization, try using manual synchronization. Use SyncHaDevice.ps1, comment $device.Synchronize([SwHaSyncType]::SW_HA_SYNC_FULL, "") and uncomment #$device.MarkAsSynchronized()
Gim
Mon Sep 01, 2025 2:34 pm
A great big thank you Yaroslav.
That works
One last question:
I modified the files that allow me to disable the cache on my first node.
Do I need to restore them to their original state before synchronizing?
Mon Sep 01, 2025 3:45 pm
I am glad to read that it worked! Leave the cache off on both nodes.
frostyoccupation
Mon Sep 08, 2025 9:46 am
Hi, try checking network connectivity, time sync, and storage configuration on both nodes. Restart StarWind services and review logs for errors. If it still shows ‘NOT SYNCHRONIZED,’ share your setup details for more help.
Mon Sep 08, 2025 10:05 am
Make sure to follow https://knowledgebase.starwindsoftware. ... -blackout/
You can force synchronization, try using manual synchronization. Use SyncHaDevice.ps1, comment $device.Synchronize([SwHaSyncType]::SW_HA_SYNC_FULL, "") and uncomment #$device.MarkAsSynchronized()
