StarWind iSCSI SAN
Problem burning cd to remote lite on burner
Pure software-based VM-centric and flash-friendly VM storage (iSCSI, SMB3, NFS, iSER and NVMe over Fabrics) including free version. Same software embedded on StarWind ready nodes.
Postby michael_S » Sun Aug 01, 2004 9:05 pm
When I attempt to burn a cd to a drive connected through starport on my notebook computer, it begins the burn, then immediately cancels the burn, and the software kicks back an 'unknown error'
On the machine running starwind that shares the cd burner, after the burn attempt from the remote machine fails, the cd burner is no longer visible by the windows explorer, it cannot be opened and continues to run slowly.
I have installed starwind on the machine with the cd-burner. I have installed starport on the remote machine that connects to the starwind server. They connect easily and everything looks great until I attempt to burn a disk.
Also, as the drive is inaccessable after the burn attempt, the logfile keeps adding the same info over and over until I reboot. After a reboot, the machine runs normally again (until I attempt a remote burn again)
Here is the error log:
20:20:12:671 (1300) Srv: Accepted connection from 192.168.1.103:1043. id assigned - 4372
20:20:12:671 (1300) C[0x1114], FREE: Event - CONNECTED.
20:20:12:671 (1300) C[0x1114], XPT_UP: T3.
20:20:12:671 (2320) C[0x1114], XPT_UP: Login request: ISID 0x801234567890, TSIH 0x0000.
20:20:12:671 (2320) C[0x1114], XPT_UP: Event - LOGIN.
20:20:12:671 (2320) C[0x1114], IN_LOGIN: T4.
20:20:12:671 (2320) Params: <<< String param 'InitiatorName': received 'iqn.2003-06.com.rocketdivision.starportmikes-notebook', accepted 'iqn.2003-06.com.rocketdivision.starportmikes-notebook'
20:20:12:671 (2320) Params: <<< Enum param 'SessionType': received 'Discovery', accepted 'Discovery'
20:20:12:671 (2320) Params: <<< Enum param 'AuthMethod': received 'None', accepted 'None'
20:20:12:671 (2320) Params: Update OFMarkInt according to the value of OFMarker.
20:20:12:671 (2320) Params: Update IFMarkInt according to the value of IFMarker.
20:20:12:671 (2320) T[0x1]: Anonimous connection allowed.
20:20:12:671 (2320) Params: >>> AuthMethod=None.
20:20:12:671 (2328) T[0x1]: The end of stage 0, next stage is 1.
20:20:12:671 (2320) Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
20:20:12:671 (2320) Params: <<< Numeric param 'MaxConnections': received 1, accepted 1
20:20:12:671 (2320) Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
20:20:12:671 (2320) Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
20:20:12:671 (2320) Params: <<< Boolean param 'OFMarker': received No, accepted 0
20:20:12:671 (2320) Params: <<< Boolean param 'IFMarker': received No, accepted 0
20:20:12:671 (2320) Params: <<< Boolean param 'InitialR2T': received No, accepted 0
20:20:12:671 (2320) Params: <<< Boolean param 'ImmediateData': received Yes, accepted 1
20:20:12:671 (2320) Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 65536, accepted 65536
20:20:12:671 (2320) Params: <<< Numeric param 'MaxBurstLength': received 262144, accepted 262144
20:20:12:671 (2320) Params: <<< Numeric param 'FirstBurstLength': received 65536, accepted 65536
20:20:12:671 (2320) Params: <<< Numeric param 'DefaultTime2Wait': received 5, accepted 5
20:20:12:671 (2320) Params: <<< Numeric param 'DefaultTime2Retain': received 20, accepted 20
20:20:12:671 (2320) Params: <<< Numeric param 'MaxOutstandingR2T': received 1, accepted 1
20:20:12:671 (2320) Params: <<< Boolean param 'DataPDUInOrder': received Yes, accepted 1
20:20:12:671 (2320) Params: <<< Boolean param 'DataSequenceInOrder': received Yes, accepted 1
20:20:12:671 (2320) Params: >>> ErrorRecoveryLevel=0.
20:20:12:671 (2320) Params: >>> MaxConnections=1.
20:20:12:671 (2320) Params: >>> HeaderDigest=None.
20:20:12:671 (2320) Params: >>> DataDigest=None.
20:20:12:671 (2320) Params: >>> OFMarker=No.
20:20:12:671 (2320) Params: >>> IFMarker=No.
20:20:12:671 (2320) Params: >>> InitialR2T=No.
20:20:12:671 (2320) Params: >>> ImmediateData=Yes.
20:20:12:671 (2320) Params: >>> MaxRecvDataSegmentLength=65536.
20:20:12:671 (2320) Params: >>> MaxBurstLength=262144.
20:20:12:671 (2320) Params: >>> FirstBurstLength=65536.
20:20:12:671 (2320) Params: >>> DefaultTime2Wait=5.
20:20:12:671 (2320) Params: >>> DefaultTime2Retain=20.
20:20:12:671 (2320) Params: >>> MaxOutstandingR2T=1.
20:20:12:671 (2320) Params: >>> DataPDUInOrder=Yes.
20:20:12:671 (2320) Params: >>> DataSequenceInOrder=Yes.
20:20:12:671 (2328) T[0x1]: The end of stage 1, next stage is 3.
20:20:12:671 (2328) C[0x1114], IN_LOGIN: Event - LOGIN_ACCEPT.
20:20:12:671 (2328) C[0x1114], LOGGED_IN: T5.
20:20:12:671 (2328) C[0x1114], LOGGED_IN: Event - LOGOUT.
20:20:12:671 (2328) C[0x1114], IN_LOGOUT: T9/10.
20:20:12:671 (2324) C[0x1114], IN_LOGOUT: Event - LOGOUT_ACCEPT.
20:20:12:671 (2324) C[0x1114], FREE: T13.
20:20:49:890 (2232) conf: A control connection is closed.
20:21:04:015 (1360) conf: Accepted the control connection from 127.0.0.1:1040.
20:22:10:156 (2664) conf: Reading '[devices]'
20:22:10:156 (2664) S: Assigned target name: 'cd-burner', SymId: 'CDDVD.D'.
20:22:10:156 (2664) S: the device '\\.\D:' is opened successfully.
20:22:10:156 (2664) S: cd-burner: 1 session(s) allowed.
20:23:24:687 (1300) Srv: Accepted connection from 192.168.1.103:1044. id assigned - 4373
20:23:24:687 (1300) C[0x1115], FREE: Event - CONNECTED.
20:23:24:687 (1300) C[0x1115], XPT_UP: T3.
20:23:24:687 (2792) C[0x1115], XPT_UP: Login request: ISID 0x801234567890, TSIH 0x0000.
20:23:24:687 (2792) C[0x1115], XPT_UP: Event - LOGIN.
20:23:24:687 (2792) C[0x1115], IN_LOGIN: T4.
20:23:24:687 (2792) Params: <<< String param 'InitiatorName': received 'iqn.2003-06.com.rocketdivision.starportmikes-notebook', accepted 'iqn.2003-06.com.rocketdivision.starportmikes-notebook'
20:23:24:687 (2792) Params: <<< Enum param 'SessionType': received 'Discovery', accepted 'Discovery'
20:23:24:687 (2792) Params: <<< Enum param 'AuthMethod': received 'None', accepted 'None'
20:23:24:687 (2792) Params: Update OFMarkInt according to the value of OFMarker.
20:23:24:687 (2792) Params: Update IFMarkInt according to the value of IFMarker.
20:23:24:687 (2792) T[0x1]: Anonimous connection allowed.
20:23:24:687 (2792) Params: >>> AuthMethod=None.
20:23:24:687 (2800) T[0x1]: The end of stage 0, next stage is 1.
20:23:24:703 (2792) Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
20:23:24:703 (2792) Params: <<< Numeric param 'MaxConnections': received 1, accepted 1
20:23:24:703 (2792) Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
20:23:24:703 (2792) Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
20:23:24:703 (2792) Params: <<< Boolean param 'OFMarker': received No, accepted 0
20:23:24:703 (2792) Params: <<< Boolean param 'IFMarker': received No, accepted 0
20:23:24:703 (2792) Params: <<< Boolean param 'InitialR2T': received No, accepted 0
20:23:24:703 (2792) Params: <<< Boolean param 'ImmediateData': received Yes, accepted 1
20:23:24:703 (2792) Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 65536, accepted 65536
20:23:24:703 (2792) Params: <<< Numeric param 'MaxBurstLength': received 262144, accepted 262144
20:23:24:703 (2792) Params: <<< Numeric param 'FirstBurstLength': received 65536, accepted 65536
20:23:24:703 (2792) Params: <<< Numeric param 'DefaultTime2Wait': received 5, accepted 5
20:23:24:703 (2792) Params: <<< Numeric param 'DefaultTime2Retain': received 20, accepted 20
20:23:24:703 (2792) Params: <<< Numeric param 'MaxOutstandingR2T': received 1, accepted 1
20:23:24:703 (2792) Params: <<< Boolean param 'DataPDUInOrder': received Yes, accepted 1
20:23:24:703 (2792) Params: <<< Boolean param 'DataSequenceInOrder': received Yes, accepted 1
20:23:24:703 (2792) Params: >>> ErrorRecoveryLevel=0.
20:23:24:703 (2792) Params: >>> MaxConnections=1.
20:23:24:703 (2792) Params: >>> HeaderDigest=None.
20:23:24:703 (2792) Params: >>> DataDigest=None.
20:23:24:703 (2792) Params: >>> OFMarker=No.
20:23:24:703 (2792) Params: >>> IFMarker=No.
20:23:24:703 (2792) Params: >>> InitialR2T=No.
20:23:24:703 (2792) Params: >>> ImmediateData=Yes.
20:23:24:703 (2792) Params: >>> MaxRecvDataSegmentLength=65536.
20:23:24:703 (2792) Params: >>> MaxBurstLength=262144.
20:23:24:703 (2792) Params: >>> FirstBurstLength=65536.
20:23:24:703 (2792) Params: >>> DefaultTime2Wait=5.
20:23:24:703 (2792) Params: >>> DefaultTime2Retain=20.
20:23:24:703 (2792) Params: >>> MaxOutstandingR2T=1.
20:23:24:703 (2792) Params: >>> DataPDUInOrder=Yes.
20:23:24:703 (2792) Params: >>> DataSequenceInOrder=Yes.
20:23:24:703 (2800) T[0x1]: The end of stage 1, next stage is 3.
20:23:24:703 (2800) C[0x1115], IN_LOGIN: Event - LOGIN_ACCEPT.
20:23:24:703 (2800) C[0x1115], LOGGED_IN: T5.
20:23:24:703 (2800) C[0x1115], LOGGED_IN: Event - LOGOUT.
20:23:24:703 (2800) C[0x1115], IN_LOGOUT: T9/10.
20:23:24:703 (2796) C[0x1115], IN_LOGOUT: Event - LOGOUT_ACCEPT.
20:23:24:703 (2796) C[0x1115], FREE: T13.
20:23:41:546 (1300) Srv: Accepted connection from 192.168.1.103:1045. id assigned - 4374
20:23:41:546 (1300) C[0x1116], FREE: Event - CONNECTED.
20:23:41:546 (1300) C[0x1116], XPT_UP: T3.
20:23:41:546 (2804) C[0x1116], XPT_UP: Login request: ISID 0x801234567890, TSIH 0x0000.
20:23:41:546 (2804) C[0x1116], XPT_UP: Event - LOGIN.
20:23:41:546 (2804) C[0x1116], IN_LOGIN: T4.
20:23:41:546 (2804) Params: <<< String param 'InitiatorName': received 'iqn.2003-06.com.rocketdivision.starportmikes-notebook', accepted 'iqn.2003-06.com.rocketdivision.starportmikes-notebook'
20:23:41:546 (2804) Params: <<< String param 'TargetName': received 'cd-burner', accepted 'cd-burner'
20:23:41:546 (2804) Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
20:23:41:546 (2804) Params: <<< Enum param 'AuthMethod': received 'None', accepted 'None'
20:23:41:546 (2804) Params: Update OFMarkInt according to the value of OFMarker.
20:23:41:546 (2804) Params: Update IFMarkInt according to the value of IFMarker.
20:23:41:546 (2804) S: cd-burner: 1 session(s) are opened, 0 more allowed.
20:23:41:546 (2804) T[0x1]: Anonimous connection allowed.
20:23:41:546 (2804) Params: >>> AuthMethod=None.
20:23:41:546 (2804) Params: >>> TargetPortalGroupTag=1.
20:23:41:546 (2812) T[0x1]: The end of stage 0, next stage is 1.
20:23:41:546 (2804) Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
20:23:41:546 (2804) Params: <<< Numeric param 'MaxConnections': received 1, accepted 1
20:23:41:546 (2804) Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
20:23:41:546 (2804) Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
20:23:41:546 (2804) Params: <<< Boolean param 'OFMarker': received No, accepted 0
20:23:41:546 (2804) Params: <<< Boolean param 'IFMarker': received No, accepted 0
20:23:41:546 (2804) Params: <<< Boolean param 'InitialR2T': received No, accepted 0
20:23:41:546 (2804) Params: <<< Boolean param 'ImmediateData': received Yes, accepted 1
20:23:41:546 (2804) Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 65536, accepted 65536
20:23:41:546 (2804) Params: <<< Numeric param 'MaxBurstLength': received 262144, accepted 131072
20:23:41:546 (2804) Params: <<< Numeric param 'FirstBurstLength': received 65536, accepted 65536
20:23:41:546 (2804) Params: <<< Numeric param 'DefaultTime2Wait': received 5, accepted 5
20:23:41:546 (2804) Params: <<< Numeric param 'DefaultTime2Retain': received 20, accepted 20
20:23:41:546 (2804) Params: <<< Numeric param 'MaxOutstandingR2T': received 1, accepted 1
20:23:41:546 (2804) Params: <<< Boolean param 'DataPDUInOrder': received Yes, accepted 1
20:23:41:546 (2804) Params: <<< Boolean param 'DataSequenceInOrder': received Yes, accepted 1
20:23:41:546 (2804) Params: >>> ErrorRecoveryLevel=0.
20:23:41:546 (2804) Params: >>> MaxConnections=1.
20:23:41:546 (2804) Params: >>> HeaderDigest=None.
20:23:41:546 (2804) Params: >>> DataDigest=None.
20:23:41:546 (2804) Params: >>> OFMarker=No.
20:23:41:546 (2804) Params: >>> IFMarker=No.
20:23:41:546 (2804) Params: >>> InitialR2T=No.
20:23:41:546 (2804) Params: >>> ImmediateData=Yes.
20:23:41:546 (2804) Params: >>> MaxRecvDataSegmentLength=65536.
20:23:41:546 (2804) Params: >>> MaxBurstLength=131072.
20:23:41:546 (2804) Params: >>> FirstBurstLength=65536.
20:23:41:546 (2804) Params: >>> DefaultTime2Wait=5.
20:23:41:546 (2804) Params: >>> DefaultTime2Retain=20.
20:23:41:546 (2804) Params: >>> MaxOutstandingR2T=1.
20:23:41:546 (2804) Params: >>> DataPDUInOrder=Yes.
20:23:41:546 (2804) Params: >>> DataSequenceInOrder=Yes.
20:23:41:546 (2812) T[0x1]: The end of stage 1, next stage is 3.
20:23:41:546 (2812) C[0x1116], IN_LOGIN: Event - LOGIN_ACCEPT.
20:23:41:546 (2812) C[0x1116], LOGGED_IN: T5.
20:23:41:562 (2812) SPTI: '\\.\D:': *ERROR* Wrong LUN 0x100. Only LUN 0 is supported!
20:27:58:734 (2812) SPTI: '\\.\D:': DeviceIoControl failed: The semaphore timeout period has expired. (code: 121).
20:27:58:734 (2812) SPTI: '\\.\D:': IOCTL_SCSI_PASS_THROUGH_DIRECT (before):
  0000 2c 00 00 00 00 00 06 12 02 00 00 00 00 00 00 00 ,...............
  0010 02 00 00 00 00 00 00 00 2c 00 00 00 1b 00 00 00 ........,.......
  0020 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
  0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
20:27:58:734 (2812) SPTI: '\\.\D:': IOCTL_SCSI_PASS_THROUGH_DIRECT (after):
I believe this is the key error in the log:
But I have no idea what it means, or how to fix it... Any ideas?
The cd burner is a Lite-On CD RW 24x10x40
michael_S
Postby anton (staff) » Mon Aug 02, 2004 9:29 am
What's version of both softwar titles (StarPort and StarWind) you're running? Before we'll proceed would you please make sure they are the latest ones downloaded from this site (2.4.0). Thanks!
Re: Problem burning cd to remote lite on burner
Postby Alex (staff) » Mon Aug 02, 2004 10:58 am
michael_S wrote:I believe this is the key error in the log:
No. This message means only that the initiator tries several LUNs starting from 0. As soon as the device supports only LUN 0 the rest of tries will fail. This is normal behaviour.
In fact the problem is another message:
I will check what is wrong with it.
PS. Try to add -timeout:108000 to the "add \\.\D:" directive.
Alexey.
Alex (staff)
versions
Postby michael_S » Mon Aug 02, 2004 7:10 pm
I believe I am using the latest versions as I downoaded them from your site yesterday.
Starwind: 2.4.0 Build 0x200-40730
I will try your other suggestion and post if there is any different result...
michael_S
Postby michael_S » Mon Aug 02, 2004 7:47 pm
I am not sure how to add that directive.
I did the following:
add "\\.\D:" "CD-Burner" -timeout:108000
and it had no effect.
The same thing happens.
Error log:
19:38:46:031 (292) SPTI: '\\.\D:': *ERROR* Wrong LUN 0x100. Only LUN 0 is supported!
19:43:52:968 (292) SPTI: '\\.\D:': DeviceIoControl failed: The semaphore timeout period has expired. (code: 121).
19:43:52:968 (292) SPTI: '\\.\D:': IOCTL_SCSI_PASS_THROUGH_DIRECT (before):
  0000 2c 00 00 00 00 00 0a 12 02 00 00 00 00 00 00 00 ,...............
  0010 02 00 00 00 00 00 00 00 2c 00 00 00 54 01 00 00 ........,...T...
  0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
19:43:52:968 (292) SPTI: '\\.\D:': IOCTL_SCSI_PASS_THROUGH_DIRECT (after):
19:44:05:640 (292) SPTI: '\\.\D:': DeviceIoControl failed: The semaphore timeout period has expired. (code: 121).
19:44:05:640 (292) SPTI: '\\.\D:': IOCTL_SCSI_PASS_THROUGH_DIRECT (before):
  0000 2c 00 00 00 00 00 0a 12 01 00 00 00 08 00 00 00 ,...............
  0010 02 00 00 00 38 cb 08 00 2c 00 00 00 4a 01 00 00 ....8╦..,...J...
  0020 50 00 00 00 08 00 00 00 00 00 00 00 00 00 00 00 P...............
19:44:05:640 (292) SPTI: '\\.\D:': IOCTL_SCSI_PASS_THROUGH_DIRECT (after):
19:44:18:328 (292) SPTI: '\\.\D:': DeviceIoControl failed: The semaphore timeout period has expired. (code: 121).
19:44:18:328 (292) SPTI: '\\.\D:': IOCTL_SCSI_PASS_THROUGH_DIRECT (before):
19:44:18:328 (292) SPTI: '\\.\D:': IOCTL_SCSI_PASS_THROUGH_DIRECT (after):
19:44:31:015 (292) SPTI: '\\.\D:': DeviceIoControl failed: The semaphore timeout period has expired. (code: 121).
19:44:31:015 (292) SPTI: '\\.\D:': IOCTL_SCSI_PASS_THROUGH_DIRECT (before):
19:44:31:015 (292) SPTI: '\\.\D:': IOCTL_SCSI_PASS_THROUGH_DIRECT (after):
19:44:57:046 (292) SPTI: '\\.\D:': DeviceIoControl failed: The specified network resource or device is no longer available. (code: 55).
19:44:57:046 (292) SPTI: '\\.\D:': IOCTL_SCSI_PASS_THROUGH_DIRECT (before):
  0010 02 00 00 00 48 ce 08 00 2c 00 00 00 25 00 00 00 ....H╬..,...%...
19:44:57:046 (292) SPTI: '\\.\D:': IOCTL_SCSI_PASS_THROUGH_DIRECT (after):
19:44:57:046 (292) SPTI: '\\.\D:': DeviceIoControl failed: The device does not recognize the command. (code: 22).
  0010 02 00 00 00 48 ce 08 00 2c 00 00 00 4a 01 00 00 ....H╬..,...J...
19:44:57:062 (292) SPTI: '\\.\D:': DeviceIoControl failed: The device does not recognize the command. (code: 22).
19:44:57:062 (292) SPTI: '\\.\D:': IOCTL_SCSI_PASS_THROUGH_DIRECT (before):
19:44:57:062 (292) SPTI: '\\.\D:': IOCTL_SCSI_PASS_THROUGH_DIRECT (after):
19:44:57:125 (292) SPTI: '\\.\D:': DeviceIoControl failed: The device does not recognize the command. (code: 22).
19:44:57:125 (292) SPTI: '\\.\D:': IOCTL_SCSI_PASS_THROUGH_DIRECT (before):
  0010 02 00 00 00 00 00 00 00 2c 00 00 00 00 00 00 00 ........,.......
19:44:57:125 (292) SPTI: '\\.\D:': IOCTL_SCSI_PASS_THROUGH_DIRECT (after):
19:44:58:109 (292) SPTI: '\\.\D:': DeviceIoControl failed: Access is denied. (code: 5).
19:44:58:109 (292) SPTI: '\\.\D:': IOCTL_SCSI_PASS_THROUGH_DIRECT (before):
19:44:58:109 (292) SPTI: '\\.\D:': IOCTL_SCSI_PASS_THROUGH_DIRECT (after):
19:44:59:109 (292) SPTI: '\\.\D:': DeviceIoControl failed: Access is denied. (code: 5).
19:44:59:109 (292) SPTI: '\\.\D:': IOCTL_SCSI_PASS_THROUGH_DIRECT (before):
michael_S
Postby Alex (staff) » Tue Aug 03, 2004 11:15 am
I got the information that similar problem (failed SPTI requests) was observed with some other software on some USB burners. Could you, please, give me the following details:
1. How is your burner connected - USB, IDE, SCSI?
2. What burning software do you use?
Could you also try a different burner?
Alexey.
Alex (staff)
Postby Alex (staff) » Fri Aug 06, 2004 1:11 pm
[quote="michael_S]
[/quote]
We found this bug. Timeout settings were broken by accidence. Updated version will be available ASAP.
Alexey.
Alex (staff)
Return to StarWind Virtual SAN / StarWind Virtual SAN Free / StarWind HyperConverged Appliance / StarWind Storage Appliance
Who is online
Users browsing this forum: No registered users and 3 guests
