RAID feature (using demo version)
spiv
Sat May 20, 2006 9:32 am
I'm using the demo version and have a question about using RAID. When I try to add a device the option for RAID 1 is greyed out. I assume this is a limitation of the demo version - can you explain how this works with the full version?
Specifically, how is this different/better than using the software RAID capability in Windows Device Manager (Windows Server 2003) to create RAID using Windows dynamic volumes?
serge (staff)
Sat May 20, 2006 12:05 pm
Hello.
Mirror (RAID - 1) plugin is not enabled in that build.
It will become part of the next build that should become available in a few days
Serge
spiv
Sat May 20, 2006 3:17 pm
Can you explain how the feature works. Sorry for sounding like a newbie but the online help/docs do not explain what this option (when available) will do.
I'm just looking for a quick overview that explains the benefit of using this option and any limitations or additional requirements.
serge (staff) wrote:Hello.
serge (staff)
Sun May 21, 2006 9:10 am
Hello.
Mirror plugin enables you to combine two images into a failover mirror to ensure data reliability. This feature emulates RAID 1 support.
When data is written to mirror device it is writen to both images so that second image becomes a mirror of the first (main) image.
The benefit is improved data reliability and when two local images are used to create a mirror there are no usage limitations
Serge
