Starwind vSAN Free on CVM (2 Node HA)
root
Fri May 02, 2025 4:32 pm
I am trying to setup two node HA using Starwind vSAN free with CVM deployment but currently facing issue.
Here is my setup:
Two Physical Windows Servers with 2x1SSDs (RAID 1) and 4x8HDDs (RAID 10).
Both Servers are connected to each other using two ethernet cables.
1 - External switch iSCSI (172.16.10.1/24) Host01 is 10.1 and Host02 is 10.2
2 - External switch Sync (172.16.20.1/24) Host01 is 20.1 and Host02 is 20.2
The servers are also connected to a managed switch for Management IP on 172.31.0.1/24 network
Host01 is 172.31.0.110
Host02 is 172.31.0.126
Note : I can ping all the provided IPs from both hosts.
I have imported CVM provided by Starwind to both the hosts and completed the initial setup. I added the RAID10 storage from both hosts as a HardDrive to both VMs. I than created Storage Pools and Volumes, but now I want to create a LUN which I cannot do it from webGUI because I am using free version.
I installed Starwind Management Console on both Hosts and I am trying to run the following Powershell Script, however I keep getting an error.
param($addr="172.31.0.110", $port=3261, $user="root", $password="starwind",
$addr2="172.31.0.126", $port2=$port, $user2=$user, $password2=$password,
#common
$initMethod="NotSynchronize",
$size=13631488,
$sectorSize=4096,
$failover=1,
$bmpType=1,
$bmpStrategy=0,
#primary node
$imagePath="/mnt/sdb1/vmStorage",
$imageName="device1",
$createImage=$true,
$storageName="",
$targetAlias="target1",
$poolName="",
$syncSessionCount=1,
$aluaOptimized=$true,
$cacheMode="none",
$cacheSize=0,
$syncInterface="#p2=172.16.20.2:3260",
$hbInterface="#p2=172.16.10.2:3260",
$createTarget=$true,
$bmpFolderPath="",
#secondary node
$imagePath2="/mnt/sdb1/vmStorage",
$imageName2="device1",
$createImage2=$true,
$storageName2="",
$targetAlias2="target1",
$poolName2="",
$syncSessionCount2=1,
$aluaOptimized2=$false,
$cacheMode2=$cacheMode,
$cacheSize2=$cacheSize,
$syncInterface2="#p2=172.16.20.1:3260",
$hbInterface2="#p2=172.16.10.1:3260",
$createTarget2=$true,
$bmpFolderPath2=""
Import-Module StarWindX
try
$server.Connect()
$firstNode = new-Object Node
$firstNode.HostName = $addr
$firstNode.HostPort = $port
$firstNode.Login = $user
$firstNode.Size = $size
$secondNode = new-Object Node
$secondNode.HostName = $addr2
$secondNode.HostPort = $port2
$secondNode.Login = $user2
Start-Sleep -m 2000
$device.Refresh()
catch
Write-Host $_ -foreground red
finally
$server.Disconnect()
Output:
Request to HOST01 ( 172.31.0.110 ) : 3261
control ImageFile -CreateImage:"/mnt/sdb1/vmStorage\device1.img" -Size:"13631488" -Flat:"True" -DeferredInit:"True" -Password:"starwind"
200 Failed: operation cannot be completed..
Can you please help me how can I fix this? Whatever I am doing is correct setup or not?
I ultimately want to run a Failover Cluster with 2 Node HA, so if Host01 goes down VMs should still run on Host02 because the data is mirrors between the hosts.
Appreciate your help.
Thank You
Fri May 02, 2025 4:50 pm
Welcome to StarWind Forum.
1. Use the Windows-based VSAN (https://www.starwindsoftware.com/tmplin ... ind-v8.exe), unless you need the software RAID feature or you are after NVMe-oF.
2. Check this out viewtopic.php?t=6852&p=37208&hilit=HINT8.
From what I see in your script:
1. Wrong failover strategy
2. poolName is missing
Good luck with your project.
root
Fri May 02, 2025 5:07 pm
I tried running Windows Application VSAN management console before going to CVM route.
I added both the hosts in the Starwind management console.
I still have to run powershell script to create storage for failover, correct?
Here is the script I was running
$addr2="127.0.0.1", $port2=$port, $user2=$user, $password2=$password,
#common
$initMethod="syncFromFirst",
$size=500000,
$sectorSize=4096,
$failover=1,
$bmpType=1,
$bmpStrategy=0,
#primary node
$imagePath="V:\VirtualMachines",
$imageName="masterImg",
$createImage=$true,
$storageName="",
$targetAlias="targetha1",
$poolName="",
$cacheMode="none",
$cacheSize=0,
$syncInterface="#p2={0}:3260" -f $addr2,
$hbInterface="",
$bmpFolderPath="",
#secondary node
$imagePath2="V:\VirtualMachines",
$imageName2="partnerImg",
$storageName2="",
$targetAlias2="partnerha2",
$poolName2="",
$aluaOptimized2=$true,
$hbInterface2="",
$bmpFolderPath2=""
try
Enable-SWXLog
$server.Connect()
# $firstNode.BitmapStoreType = $bmpType
# $firstNode.BitmapStrategy = $bmpStrategy
# $firstNode.BitmapFolderPath = $bmpFolderPath
# $secondNode.BitmapFolderPath = $bmpFolderPath2
Start-Sleep -m 2000
$device.Refresh()
catch
finally
However, I was getting the following error in Output.
control ImageFile -CreateHeader:"Headers\masterImg\masterImg.swdsk" -pathDirHeaderBackup:"V:\VirtualMachines" -file:"V:\VirtualMachines\masterImg.img" -Size:"500000" -CacheMode:"none" -CacheSizeMB:"0" -Blo
ckSize:"0" -psectorSize:"4096" -sectorSize:"4096"
200 Failed: file already exists.
After running the script when I RDP to Host01, I can see masterImg is created in that folder path with size 500GB. Please advise how can I move forward from here?
Thanks.
Fri May 02, 2025 5:20 pm
Please use the script from my post above; I think it will be faster just re-ip my script and change the file location.
