What would be really nice is a view on a starwind server that reports the space used vs the allocated size of an IBvolume.
The "problem" is that I need to flick between windows explorer and starwind to be able to get a "x of y" type view.
In all honesty the connections against a device is a bit pointless when used in a similar way to our environment, where 1 IBVolume can only have just one connection.
I would like to see a straight listview with the following columns.
Icon*, Volume Name, Space Allocated, Space Used, Local Path
* The icon is greyed out if no connections are present, and represents the type of device.
I can understand if this not a massive priority for you guys, but I thought I'd leave some feedback for you.
Simon
