Setting up iSCSI LUNs on HCA (Ubuntu based VM)
deprivedwriter
Mon Feb 10, 2025 3:04 pm
I'm starting off trying this product out and so far I've gotten everything configured the way I think I need it based on the documentation, but then when I try to create a LUN to present to my target host, I'm not able to do so through the GUI (which from what I understand is a known thing) but everything is telling me I need to set them up via PowerShell. I can do that, but the appliances are Ubuntu based, so is there some sort of module I need to install on a my bastion host that connects to these VSANs so that I can run the powershell script to create the LUNs? This is the part that isn't really clear and the documentation that was provided for my setup (https://www.starwindsoftware.com/resour ... ng-web-ui/) does not specify the steps needed, and tells me to go to a section which doesn't exist.
Thank you for your assistance.
Mon Feb 10, 2025 4:12 pm
Welcome to StarWind Forum.
StarWind VSAN free, by design, allows GUI only for management.
You can install StarWind VSAN Management Console and the PowerShell module into a Windows-based VM.
Speaking of the script, check this out https://forums.starwindsoftware.com/vie ... NT8#p37208.
Swet11
Tue Feb 11, 2025 4:40 pm
Just curious, have you had any issues running the StarWind VSAN Management Console in a VM, or does it work smoothly for you?
Tue Feb 11, 2025 4:41 pm
Works well.
pedaram
Mon Jun 02, 2025 2:13 am
Thanks, got it working. :)
mickhison
Sun Feb 15, 2026 5:27 pm
Thanks for the clear explanation! Setting up the StarWind VSAN Management Console and PowerShell module on a Windows VM makes the process much clearer. This thread is really helpful for anyone configuring iSCSI LUNs on Ubuntu-based appliances.
admin2
Fri May 08, 2026 2:35 pm
useful and meaningful, nice
