Shared Storage Disruption on StarWind Free License Cluster
2blucas
Tue Jan 21, 2025 9:40 am
I am currently facing critical issues with my StarWind vSAN free license setup.
Setup Overview:
3 virtual machines acting as cluster nodes.
Network issues caused multiple server reboots.
Network issues have been resolved, but the shared storage has stopped functioning.
Symptoms Observed:
Web UI Issue:
On all 3 nodes, the Web UI displays:
Management service is starting. Please wait...
API Logs:
The following endpoints fail with timeout errors:
Log Analysis:
The Management Console logs (/var/log/starwind/starwind-san-and-nas-console/ManagementConsole.log) show repeated timeout errors for remote storage nodes:
ERROR | [RemoteStorageAppliance]: GetDtoStorageNode end with exception, nodeid 'FA830CDA-784A-11EF-BE93-452859475797', message: Request timeout error.
Additionally, nginx points /api requests to port 8100, but port 8100 is not listening on any of the nodes.
Initial Network Errors (Resolved):
Previous logs showed the following errors, but the related network issues have been resolved:
ERROR | [RemoteStorageAppliance]: GetDtoStorageNode end with exception, nodeid 'EE1783EA-784A-11EF-A1E8-31F9AB668896', message: No route to host
Disk Visibility Issue:
The shared storage disks are no longer visible, iscsi connector canot connect
I can still see the .img files in the storage directory, but I am unsure how to extract or recover the data from them.
Steps Taken So Far:
Network connectivity between all nodes has been verified and is operational.
Ports and services were checked, but port 8100 is not listening on any node.
System logs indicate issues with remote storage nodes and possible problems with the Management Service startup.
Please, how can I even access the data?
Thank you for your prompt assistance.
Tue Jan 21, 2025 9:48 am
Is it a CVM on Hyper-V? If so, please install Windows-based Management Console and check if any of the devices is synchronized.
If none is synchronized, try pinging CVM ips from another CVM.
2blucas
Tue Jan 21, 2025 9:52 am
Hi Yaroslav,
Yes I'm using a CVM in proxmox.
I'm using 3 nodes proxmox v8.2.5, with HA.
"install Windows-based Management Console and check if any of the devices is synchronized."
Where can I get it?
Tue Jan 21, 2025 10:08 am
Thanks for your update.
Where can I get it?
Go to the Gear-shaped menu and navigate to one of the tabs on the right there.
Rescan iSCSI initiator on Proxmox. See more on iSCSI syntax here https://support.citrix.com/s/article/CT ... uage=en_US.
2blucas
Tue Jan 21, 2025 10:15 am
Sorry I don't understand.
I can't find the link to download the "Windows-based Management Console"
Can you please help
My issue is that the VM is stuck in GUI with "Management service is starting. Please wait...",
Tue Jan 21, 2025 10:22 am
Please refresh the page.
Or, try closing the page and opening it again. Did it get stuck for all 3 VMs or just one?
2blucas
Tue Jan 21, 2025 10:30 am
yes,
I've rebooted many times it's like this for more 12 hours
Tue Jan 21, 2025 10:48 am
Please answer my questions above. I can't help without having answers.
1. Does ping work between nodes?
2. What does windows-based console say about sync statuses?
3. Did you try rescanning?
Thanks.
2blucas
Tue Jan 21, 2025 10:56 am
yes, works fine (administrator@SW-vSAN-PVE1:~$ sudo ping -f -c 100000 3 nodes) test ok be
I don't know what are you talking about.
how? Don't have access to gui, it says "Management service is starting. Please wait...",
Tue Jan 21, 2025 11:22 am
Did you check it for ALL networks?
I mentioned it in this thread already.
Try https://starwindsoftware.com/tmplink/starwind-v8.exe
Once installed, please connect the servers.
I've also answered to this one ealier.
