Not possible to extend HAImage over ~32 Tb
arifurinmoto
Thu Oct 31, 2024 9:24 am
Hello!
Our setup: 2-node cluster w/ Windows Server 2019 Datacenter, 54 Tb ReFS disk on each node configured by Storage Spaces
We have 2 HAImage devices at this disk (VSAN Free): HAImage1 30,7Tb (for fileshare) and HAImage2 4,7Tb (for shadowcopies)
We want to extend HAImage1 for additional 5 Tb but when run ExtendDevice.ps1 param($addr="127.0.0.1", $port=3261, $user="root", $password="starwind", $deviceName="HAImage1", $extendSize=5000000) we take next warning:
Failed to resize device 0x000001C82B175700
control 0x000001C82B175700 -Reserve:"33765195776000"
200 Failed: operation cannot be completed..
So, we dont understand what prevent disk from extending
Thu Oct 31, 2024 9:45 am
The value you are typing is in MB there.
P.S. Be careful with ReFS https://community.spiceworks.com/t/plea ... san/774118
arifurinmoto
Thu Oct 31, 2024 11:52 am
Yes, $extendSize=5000000 ~5 Tb while we have ~20Tb of free space
Thu Oct 31, 2024 11:58 am
Please tell me more about the system and share the script. What hypervisor do you use? Is it a Windows-based application or CVM (is it a white UI or a dark one)?
P.s. Please also note that we do not generally recommend devices bigger than 6 TB (https://www.starwindsoftware.com/best-p ... practices/). The bigger the device is the longer it takes to synchronize it. Full synchronization for large devices may overlap with productive and backup hours, causing performance impact or synchronization might drop due to other processes causing latency to go too high. As a result, such a synchronization may never finish.
arifurinmoto
Wed Nov 13, 2024 9:52 am
We do not use hypervisor. We do not have CSV. We use volumes on HAImage disks as Cluster disk on our File Server Cluster.
CreateHA_2 :
param($addr="10.35.0.1", $port=3261, $user="root", $password="starwind",
	$addr2="10.35.0.2", $port2=$port, $user2=$user, $password2=$password,
#common
	$initMethod="Clear",
	$size=1000,
	$sectorSize=4096,
	$failover=0,
	$bmpType=1,
	$bmpStrategy=0,
#primary node
	$imagePath="My computer\E\SW",
	$imageName="fs1share",
	$createImage=$true,
	$storageName="",
	$targetAlias="targetfs1",
	$autoSynch=$true,
	$poolName="pool1",
	$syncSessionCount=1,
	$aluaOptimized=$true,
	$cacheMode="wt",
	$cacheSize=1000,
	$syncInterface="#p2=10.33.0.2:3260" -f $addr2,
	$hbInterface="#p2=10.34.0.2:3260,10.35.0.2:3260",
	$createTarget=$true,
	$bmpFolderPath="",
#secondary node
	$imagePath2="My computer\E\SW",
	$imageName2="fs2share",
	$createImage2=$true,
	$storageName2="",
	$targetAlias2="targetfs2",
	$autoSynch2=$true,
	$poolName2="pool1",
	$syncSessionCount2=1,
	$aluaOptimized2=$true,
	$cacheMode2=$cacheMode,
	$cacheSize2=$cacheSize,
	$syncInterface2="#p1=10.33.0.1:3260" -f $addr,
	$hbInterface2="#p1=10.34.0.1:3260,10.35.0.1:3260",
	$createTarget2=$true,
	$bmpFolderPath2=""
ExtendDevice:
Wed Nov 13, 2024 10:18 am
This line is worrying see more about script syntax viewtopic.php?f=5&t=6852&p=37208&hilit=HINT8#p37208.
Did it create the device?
You can create a larger device with NotSynchronize option (it skips synchronization).
arifurinmoto
Mon Nov 25, 2024 7:28 am
About syntax
instead of
it could be
$syncInterface="#p2=10.33.0.2:3260,$addr2:3260" ,
or
$syncInterface="#p2={0}:3260" -f 10.33.0.2,$addr2,
Mon Nov 25, 2024 7:44 am
Do not use $addr.
arifurinmoto
Mon Nov 25, 2024 8:31 am
So,
$syncInterface="#p2=10.33.0.2:3260,10.35.0.2:3260" ,
equals
$syncInterface="#p2={0}:3260" -f 10.33.0.2,10.35.0.2,
Mon Nov 25, 2024 9:06 am
No, it's slightly different. See viewtopic.php?f=5&t=6852&p=37208&hilit=HINT8#p37208.
arifurinmoto
Mon Nov 25, 2024 11:15 am
Sorry, I didn't find exactly what the difference between these two options is.
Mon Nov 25, 2024 12:15 pm
The first one works.
arifurinmoto
Thu Jan 09, 2025 12:16 pm
Thanks for the last tip! We've fixed our scripts for the future.
But our main problem is still unresolved.
We decided to split our storage into two parts and create a new HAImage.
And now we are facing the same problem:
PS C:\Windows\system32> C:\SW_scripts\CreateHA_2_yet_another_disk.ps1
Request to  FS1.DOMEN ( 10.35.0.1 ) : 3261
control ImageFile -CreateImage:"My computer\E\SW\fs1share.img" -Size:"1000000000" -Flat:"True" -DeferredInit:"True" -Password:"starwind"
200 Failed: There is not enough space on the disk..
But we have >18Tb free space on disk E.
What could prevent the creation of a new HAImage or extension of an existing one?
Thu Jan 09, 2025 12:37 pm
Do both replication partners have enough space?
Could you please try creating a small device (1 GB) and expanding it afterward in several hops (e.g., add 3 TB, 6TB, and finally 9TB)?
arifurinmoto
Thu Jan 09, 2025 1:17 pm
Both partners have > 18Tb of free space.
We create small image 1Gb - OK
We extend it for 1 Gb - OK
We extend it for 100 Gb - OK
We extend it for 1 Tb - error There is not enough space on the disk..
