CreateHA_2.ps1 Sync and Heartbeat format
bkdilse
Fri Apr 05, 2024 3:06 pm
I am using StarWind VSAN Free v8.0.15260.0, with the Free License.
Trying to create a 2 Node Storage system, with ESXi separate
Created the 4 x imagefiles separately using CreateImageFile.ps1.
Using CreateHA_2.ps1, with the option CreateImage = $false, so it doesn't overwrite my image files.
Node1
10.0.0.1 - Management
10.0.1.1 - Sync1
10.0.2.1 - Sync2
10.0.3.1 - iSCSI1
10.0.4.1 - iSCSI2
Node1
10.0.0.2 - Management
10.0.1.2 - Sync1
10.0.2.2 - Sync2
10.0.3.2 - iSCSI1
10.0.4.2 - iSCSI2
I managed to create the 1st HA device. When creating the 2nd one, it does not sync, and I get messages in the Console saying that all 4 interfaces are down.
Here is the interface sections of the script:
$FirstNode.SyncInterface = "#p2=10.0.1.2:3260,10.0.2.2:3260"
$FirstNode.HBInterface = "#p2=10.0.3.2:3260,10.0.4.2:3260"
$SecondNode.SyncInterface = "#p1=10.0.1.1:3260,10.0.2.1:3260"
$SecondNode.HBInterface = "#p1=10.0.3.1:3260,10.0.4.1:3260"
What is the correct way to do this in the script?
Fri Apr 05, 2024 3:20 pm
Can I have the screenshot of the error and the entire script, please?
bkdilse
Fri Apr 05, 2024 3:40 pm
Just removed everything, and I'll run it again from start. I can't attach screenshots here, can I email to you?
bkdilse
Fri Apr 05, 2024 3:56 pm
Moved all this into 2 Windows VMs, for testing, I'll leave my Physical Servers alone, until I get this working.
Script:
param($addr="10.1.21.1", $port=3261, $user="root", $password="starwind",
	$addr2="10.1.21.2", $port2=$port, $user2=$user, $password2=$password,
#common
	$initMethod="SyncFromFirst",
	$size=1024,
	$sectorSize=512,
	$failover=0,
	$bmpType=1,
	$bmpStrategy=0,
#primary node
	$imagePath="My Computer\F\Data",
	$imageName="SSD2",
	$createImage=$false,
	$storageName="imagefile2",
	$targetAlias="SSD2",
	$autoSynch=$true,
	$poolName="",
	$syncSessionCount=1,
	$aluaOptimized=$true,
	$cacheMode="none",
	$cacheSize="",
	$syncInterface="#p2=10.21.1.2:3260,10.21.2.2:3260",
	$hbInterface="#p2=10.21.3.2:3260,10.21.4.2:3260",
	$createTarget=$false,
	$bmpFolderPath="",
#secondary node
	$imagePath2=$imagePath,
	$imageName2=$imageName,
	$createImage2=$createImage,
	$storageName2="$storageName",
	$targetAlias2=$targetAlias,
	$autoSynch2=$true,
	$poolName2="",
	$syncSessionCount2=1,
	$aluaOptimized2=$true,
	$cacheMode2=$cacheMode,
	$cacheSize2=$cacheSize,
	$syncInterface2="#p1=10.21.1.1:3260,10.21.2.1:3260",
	$hbInterface2="#p1=10.21.3.1:3260,10.21.4.1:3260",
	$createTarget2=$createTarget,
	$bmpFolderPath2=""
Import-Module StarWindX
try
	$server.Connect()
	$firstNode = new-Object Node
	$firstNode.HostName = $addr
	$firstNode.HostPort = $port
	$firstNode.Login = $user
	$firstNode.Size = $size
	$secondNode = new-Object Node
	$secondNode.HostName = $addr2
	$secondNode.HostPort = $port2
	$secondNode.Login = $user2
		Start-Sleep -m 2000
		$device.Refresh()
catch
	Write-Host $_ -foreground red
finally
	$server.Disconnect()
Fri Apr 05, 2024 6:10 pm
Greetings,
Try commenting out the bmp-related entries. Also, is there any specific reason for not creating the device with $createTarget=$false?
Try sticking with $createTarget=$true.
bkdilse
Fri Apr 05, 2024 8:11 pm
Greetings,
Didn't work with commenting out bmp bits, errored.
Tried with creating target and images at the same time, and this works. I'll go with this, and not my old method.
Fri Apr 05, 2024 10:51 pm
Glad to read it worked ultimately.
Have a nice weekend!
