SW 3.0. won't allow initiator connection?
dmckeown
Mon Apr 24, 2006 6:24 pm
Howdy,
I recently uninstalled 2.4 and installed 3.0. I re-created my 2 trusty image volumes to share out (using the already existing image files.) However, when I try to connect with my Qlogic 4010c, I get the following in the SW log file (see below.)
What'd I mess up or miss?
Doug
4/24 11:48:22 77c C[0x7b23], IN_LOGIN: T4.
4/24 11:48:22 784 Params: <<< Numeric param 'FirstBurstLength': received 131072, accepted 65536
4/24 11:48:22 784 Params: <<< Boolean param 'DataPDUInOrder': received No, accepted 0
4/24 11:48:22 784 Params: <<< Boolean param 'DataSequenceInOrder': received No, accepted 0
4/24 11:48:22 77c Params: <<< String param 'InitiatorName': received 'iqn.2000-04.com.qlogic:qla4010.fs20531b04194', accepted 'iqn.2000-04.com.qlogic:qla4010.fs20531b04194'
4/24 11:48:22 784 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 65536, accepted 65536
4/24 11:48:22 784 Params: Update OFMarkInt according to the value of OFMarker.
4/24 11:48:22 77c Params: <<< String param 'TargetName': received 'iqn.2003-06.com.rocketdivision.starwind:fserv.saintmarys.edu.imagefile.imagefile0', accepted 'iqn.2003-06.com.rocketdivision.starwind:fserv.saintmarys.edu.imagefile.imagefile0'
4/24 11:48:22 784 Params: Update IFMarkInt according to the value of IFMarker.
4/24 11:48:22 77c Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
4/24 11:48:22 77c Params: <<< Boolean param 'InitialR2T': received No, accepted 0
4/24 11:48:22 784 S: *LIMIT* iqn.2003-06.com.rocketdivision.starwind:fserv.saintmarys.edu.ramdisk.ramdrive0: all of 0 allowed sessions are opened.
4/24 11:48:22 77c Params: <<< Numeric param 'FirstBurstLength': received 131072, accepted 65536
4/24 11:48:22 784 S[0x8c32]: *LIMIT* No more sessions for allowed due to target 'iqn.2003-06.com.rocketdivision.starwind:fserv.saintmarys.edu.ramdisk.ramdrive0' restrictions.
4/24 11:48:22 77c Params: <<< Boolean param 'DataPDUInOrder': received No, accepted 0
4/24 11:48:22 784 T[0x99002d]: *ERROR* Login request: device open failed.
4/24 11:48:22 77c Params: <<< Boolean param 'DataSequenceInOrder': received No, accepted 0
4/24 11:48:22 77c Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 65536, accepted 65536
4/24 11:48:22 77c Params: Update OFMarkInt according to the value of OFMarker.
4/24 11:48:22 77c Params: Update IFMarkInt according to the value of IFMarker.
4/24 11:48:22 77c S: *LIMIT* iqn.2003-06.com.rocketdivision.starwind:fserv.saintmarys.edu.imagefile.imagefile0: all of 0 allowed sessions are opened.
4/24 11:48:22 77c S[0x8c33]: *LIMIT* No more sessions for allowed due to target 'iqn.2003-06.com.rocketdivision.starwind:fserv.saintmarys.edu.imagefile.imagefile0' restrictions.
4/24 11:48:22 77c T[0x91002d]: *ERROR* Login request: device open failed.
4/24 11:48:22 760 C[0x7b22], IN_LOGIN: Event - LOGIN_REJECT.
4/24 11:48:22 760 C[0x7b22], FREE: T7.
4/24 11:48:22 790 C[0x7b23], IN_LOGIN: Event - LOGIN_REJECT.
4/24 11:48:22 790 C[0x7b23], FREE: T7.
4/24 11:48:22 784 C[0x7b22], FREE: recvData() error (10054)
4/24 11:48:22 77c C[0x7b23], FREE: recvData() error (10054)
4/24 11:48:22 788 C[0x7b24], XPT_UP: Event - LOGIN.
4/24 11:48:22 788 C[0x7b24], IN_LOGIN: T4.
4/24 11:48:22 788 Params: <<< String param 'InitiatorName': received 'iqn.2000-04.com.qlogic:qla4010.fs20531b04194', accepted 'iqn.2000-04.com.qlogic:qla4010.fs20531b04194'
4/24 11:48:22 788 Params: <<< String param 'TargetName': received 'iqn.2003-06.com.rocketdivision.starwind:fserv.saintmarys.edu.imagefile.imagefile1', accepted 'iqn.2003-06.com.rocketdivision.starwind:fserv.saintmarys.edu.imagefile.imagefile1'
4/24 11:48:22 788 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
4/24 11:48:22 788 Params: <<< Boolean param 'InitialR2T': received No, accepted 0
4/24 11:48:22 788 Params: <<< Numeric param 'FirstBurstLength': received 131072, accepted 65536
4/24 11:48:22 788 Params: <<< Boolean param 'DataPDUInOrder': received No, accepted 0
4/24 11:48:22 788 Params: <<< Boolean param 'DataSequenceInOrder': received No, accepted 0
4/24 11:48:22 788 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 65536, accepted 65536
4/24 11:48:22 788 Params: Update OFMarkInt according to the value of OFMarker.
4/24 11:48:22 788 Params: Update IFMarkInt according to the value of IFMarker.
4/24 11:48:22 788 S: *LIMIT* iqn.2003-06.com.rocketdivision.starwind:fserv.saintmarys.edu.imagefile.imagefile1: all of 0 allowed sessions are opened.
4/24 11:48:22 788 S[0x8c34]: *LIMIT* No more sessions for allowed due to target 'iqn.2003-06.com.rocketdivision.starwind:fserv.saintmarys.edu.imagefile.imagefile1' restrictions.
4/24 11:48:22 788 T[0x95002d]: *ERROR* Login request: device open failed.
4/24 11:48:22 780 C[0x7b24], IN_LOGIN: Event - LOGIN_REJECT.
4/24 11:48:22 780 C[0x7b24], FREE: T7.
4/24 11:48:22 788 C[0x7b24], FREE: recvData() error (10054)
4/24 11:49:32 610 conf: Accepted the control connection from 127.0.0.1:1104.
4/24 11:49:53 8c0 Srv: Removing target 'iqn.2003-06.com.rocketdivision.starwind:fserv.saintmarys.edu.ramdisk.ramdrive0'...
4/24 11:49:53 8c0 S: the device 'RamDrive0' is closed.
4/24 11:52:17 8c0 Srv: Refreshing device list (plugins)...
4/24 12:09:38 8c0 Srv: Refreshing device list (plugins)...
Val (staff)
Mon Apr 24, 2006 7:49 pm
The following line means your StarWind service has no valid license. So zero initiator connections are allowed.
"*LIMIT* iqn.2003-06.com.rocketdivision.starwind:fserv.saintmarys.edu.ramdisk.ramdrive0: all of 0 allowed sessions are opened."
StarWind 2.6/3.0 do not work without a license unlike the earlier versions (2.4.*).
Valeriy
dmckeown
Wed May 10, 2006 1:57 pm
valery (staff) wrote:Hi,
Should I email support to get my license replaced? I was running 2.6, uninstalled it, installed 3.0 and added my license. I don't get the nag window when I start the product but I do get this error (seen above) in the logs. Weird...
Doug
p.s. From the "about" window, after I connect -
The following connections present:
localhost:3260
StarWind iSCSI Target v3.0 (Build 20060306, Win32)
Active license count: 2
License ID: 19481395
User name: Saint Marys College
Organization: Saint Marys College
Hosts: 2
Val (staff)
Wed May 10, 2006 2:10 pm
Doug
localhost:3260
Hosts: 2
Hi Doug,
Please contact our support about upgrading of your current license.
Inside a year after purchasing a license it's pissible to upgrade to the recent version free of charge.
FYI The recent StarWind version is 3.1. It's available to download from our web-site.
Valeriy
