2-Node VSAN Error on Windows Server 2022 Standard
nlachica
Thu Dec 07, 2023 8:33 pm
I'm trying to run the CreateHA_2.ps1 script for the two nodes, but I'm getting the following error:
200 Failed: invalid partner info..
Here is the NIC Configuration:
Node 1:
10.10.1.21 - Host
10.10.10.21 - Synchronization
10.10.20.21 - iSCSI/HB
10.10.1.201 - iSCSI/HB2
Node 2:
10.10.1.22 - Host
10.10.10.22 - Synchronization
10.10.20.22 - iSCSI/HB
10.10.1.202 - iSCSI/HB2
Here is the script I am currently using:
param($addr="10.10.1.21", $port=3261, $user="root", $password="starwind",
   $addr2="10.10.1.22", $port2=$port, $user2=$user, $password2=$password,
#common
   $initMethod="SyncFromFirst",
   $size=1200,
   $sectorSize=512,
   $failover=0,
#primary node
   $imagePath="My computer\D",
   $imageName="masterImg21",
   $createImage=$true,
   $storageName="",
   $targetAlias="targetha21",
   $autoSynch=$true,
   $poolName="pool1",
   $syncSessionCount=1,
   $aluaOptimized=$true,
   $cacheMode="wb",
   $cacheSize=128,
   $syncInterface="#p2=10.10.10.22:3260" -f $addr2,
   $hbInterface="#p2=10.10.20.22:3260,10.10.1.202:3260" -f $addr2,
   $createTarget=$true,
#secondary node
   $imagePath2="My computer\D",
   $imageName2="partnerImg22",
   $createImage2=$true,
   $storageName2="",
   $targetAlias2="partnerha22",
   $autoSynch2=$true,
   $poolName2="pool1",
   $syncSessionCount2=1,
   $aluaOptimized2=$true,
   $cacheMode2=$cacheMode,
   $cacheSize2=$cacheSize,
   $syncInterface2="#p1=10.10.10.21:3260" -f $addr,
   $hbInterface2="#p1=10.10.20.21:3260,10.10.1.201:3260" -f $addr,
   $createTarget2=$true
Import-Module StarWindX
try
	Enable-SWXLog
	$server.Connect()
	$firstNode = new-Object Node
	$firstNode.HostName = $addr
	$firstNode.HostPort = $port
	$firstNode.Login = $user
	$firstNode.Size = $size
	$secondNode = new-Object Node
	$secondNode.HostName = $addr2
	$secondNode.HostPort = $port2
	$secondNode.Login = $user2
		Start-Sleep -m 2000
		$device.Refresh()
catch
	Write-Host $_ -foreground red
finally
	$server.Disconnect()
I have stopped the Starwind service, formatted the drives to try anew as mentioned in another thread.
I have also tried following the steps in this https://forums.starwindsoftware.com/vie ... p+3#p31505 thread.
Any assistance would be much appreciated.
Thu Dec 07, 2023 10:04 pm
Welcome to StarWind Forum!
Can you please check if there are any masterImg21 and targetha21 on node1's StarWind.cfg and targetha22 and masterImg22 on node2's in StarWind.cfg file? Thanks!
