Update ESXi on 2-node VSAN
Garthe_Cems
Wed May 24, 2023 1:58 pm
I have searched the message boards and the FAQs but can't find a full procedure for updating our 2 node VSAN hosts. From what I can tell,
Verify the hosts are in a Synchronized state
Place the host into maintenance mode in the Starwind management console
***Power off SW-HCA-VM-01*** (not sure about this part)
Update ESXi normally
***Power on SW-HCA-VM-01*** (not sure about this part)
Remove host from maintenance mode in the Starwind management console
Does this procedure appear accurate?
Thanks in advance!
Thu May 25, 2023 7:49 am
There is no need to enable StarWind Maintenance mode for a restart. See more on StarWind Maintenance mode (https://www.starwindsoftware.com/help/M ... eMode.html).
See StarWind VSAN restart procedure https://knowledgebase.starwindsoftware. ... installed/ (To restart the servers for installing software updates, hardware changes, etc:).
See the similar forum thread https://forums.starwindsoftware.com/vie ... ind#p34083.
Garthe_Cems
Thu May 25, 2023 4:01 pm
This worked like a charm, just wanted to confirm the necessity of Maintenance Mode on in the Starwind Managment Console.
Service vms powered back on very quickly and synchronized right away.
Thanks for your assistance Yaroslav!
My procedure was:
Repeat on 2nd host
Thu May 25, 2023 6:23 pm
Yup, that's the solid one we normally use too.
Please make sure to check the iSCSI paths to be available from all StarWind VMs before restarting a node. If some of the paths are not available, rescan the storage adapter and VMFS, and check again.
