Hello! I just downloaded the StarWind Shareware and can connect via StarPort, but not the MS Initiator. I am trying to standardize on MS for customers already using it. I can send my .conf if needed. Please help!
The MS Initiator errors out with:
"The iSCSI Name specified contains invalid characters or is too long."
Here is the StarWind log:
2/23 12:35:38 7a4 Srv: StarWind iSCSI Target v2.6.4 (Build 20050908, Win32)
2/23 12:35:38 7a4 Srv: *** TRIAL VERSION *** [ expires in 14 day(s) ]
2/23 12:35:38 7a4 Srv: Please contact Rocket Division Software at <info@rocketdivision.com> for more details.
2/23 12:35:38 7a4 Srv: Unlimited number of client hosts allowed.
2/23 12:35:38 7a4 Srv: Config file: 'C:\Program Files\Rocket Division Software\StarWind\starwind.conf'
2/23 12:35:38 7a4 conf: 'LogLevel' = '1'
2/23 12:35:38 7a4 conf: 'LogMask' = '0x8fffffff'
2/23 12:35:38 7a4 conf: 'Port' = '3260'
2/23 12:35:38 7a4 conf: 'Interface' = '10.10.1.120'
2/23 12:35:38 7a4 conf: 'DefTargetName' = 'iqn.2003-06.com.starwind:iscsitest'
2/23 12:35:38 7a4 conf: 'Login' = ''
2/23 12:35:38 7a4 conf: 'Password' = '##1B2M2Y8AsgTpgAmY7PhCfg=='
2/23 12:35:38 7a4 conf: 'Echo' = 'no'
2/23 12:35:38 7a4 conf: 'MinBufferSize' = '65536'
2/23 12:35:38 7a4 conf: 'AlignmentMask' = '0x0000'
2/23 12:35:38 7a4 conf: 'MaxPendingRequests' = '64'
2/23 12:35:38 7a4 conf: Variable 'LogLevel' is set to '1'.
2/23 12:35:38 7a4 conf: Variable 'LogMask' is set to '0x8fffffff'.
2/23 12:35:38 7a4 conf: Variable 'Port' is set to '3260'.
2/23 12:35:38 7a4 conf: Variable 'Interface' is set to '10.10.1.120'.
2/23 12:35:38 7a4 conf: Variable 'DefTargetName' is set to 'iqn.2003-06.com.starwind:iscsitest'.
2/23 12:35:38 7a4 conf: Variable 'Login' is set to ''.
2/23 12:35:38 7a4 conf: Variable 'Password' is set to '##1B2M2Y8AsgTpgAmY7PhCfg=='.
2/23 12:35:38 7a4 conf: Variable 'Echo' is set to 'no'.
2/23 12:35:38 7a4 conf: Variable 'MinBufferSize' is set to '65536'.
2/23 12:35:38 7a4 conf: Variable 'AlignmentMask' is set to '0x0000'.
2/23 12:35:38 7a4 conf: Variable 'MaxPendingRequests' is set to '64'.
2/23 12:35:38 7a4 conf: 'RamDisk.dll' loaded successfully.
2/23 12:35:38 7a4 IMAGE: *SscPort_Init:
Dirname: '*'
Rights: 0x1f
Alias: 'My Computer'
Extensions: 'img,dat'
2/23 12:35:38 7a4 conf: 'ImageFile.dll' loaded successfully.
2/23 12:35:38 7a4 VDVD: *SscPort_Init:
Dirname: '*'
Rights: 0x18
Extensions: 'mds,iso'
2/23 12:35:38 7a4 conf: 'VirtualDvd.dll' loaded successfully.
2/23 12:35:38 7a4 IBV: *SscPort_Init:
Dirname: '*'
Rights: 0x1f
Extensions: 'ibv'
Dirname: '*'
Rights: 0x18
Alias: 'Readonly ImageFiles'
2/23 12:35:38 7a4 conf: 'IBVolume.dll' loaded successfully.
2/23 12:35:38 7a4 S: the device 'ImageFile0' is opened successfully.
2/23 12:35:38 7a4 S: Assigned target name: 'rocket_test', SymId: 'Imagefile.ImageFile0'.
2/23 12:35:38 7a4 S: parameter 'header', value '0'.
2/23 12:35:38 7a4 S: parameter 'file', value 'My Computer\T\test.dat'.
2/23 12:35:38 7a4 S: parameter 'buffering', value 'no'.
2/23 12:35:38 7a4 S: clustered 0.
2/23 12:35:38 7a4 S: parameter 'asyncmode', value 'no'.
2/23 12:35:38 7a4 S: parameter 'ImageSizeLow', value '1073741824'.
2/23 12:35:38 7a4 S: parameter 'ImageSizeHigh', value '0'.
2/23 12:35:38 7a4 S: rocket_test: 1 session(s) allowed.
2/23 12:35:38 7a4 conf: Target [0x93ae0] has been created. Device 'ImageFile0' is accesible as target 'rocket_test'.
2/23 12:35:38 7a4 Srv: Refreshing device list (complete)...
2/23 12:35:40 7a4 Srv: Found SPTI device '\\.\PhysicalDrive0': ' NetCell SyncRAID(TM) SR5000 R3-3 '
2/23 12:35:40 7a4 Srv: Found SPTI device '\\.\PhysicalDrive1': ' PQI IDE Secured DiskOnModule S04274'
2/23 12:35:40 7a4 Srv: Found SPTI device '\\.\PhysicalDrive2': 'WDIGTL WDE9150 ULTRA2 1.30'
2/23 12:35:40 7a4 Srv: Found SPTI device '\\.\PhysicalDrive3': 'WDIGTL WDE9150 ULTRA2 1.30'
2/23 12:35:40 7a4 Srv: Binding to 10.10.1.120:3260 ...
2/23 12:35:40 7a4 Srv: Waiting for a connection at port 10.10.1.120:3260 ...
2/23 12:35:40 7c0 conf: Waiting for a control connection at port 3261 ...
2/23 12:35:43 7c0 conf: Accepted the control connection from 127.0.0.1:1038.
2/23 12:35:51 2c4 conf: A control connection is closed.
2/23 12:36:02 7c0 conf: Accepted the control connection from 10.10.1.120:1039.
2/23 12:39:24 7a4 Srv: Accepted connection from 10.10.1.100:1775. id assigned - 4370
2/23 12:39:24 7a4 C[0x1112], FREE: Event - CONNECTED.
2/23 12:39:24 7a4 C[0x1112], XPT_UP: T3.
2/23 12:39:24 420 C[0x1112], XPT_UP: Login request: ISID 0x400001370000, TSIH 0x0000.
2/23 12:39:24 420 C[0x1112], XPT_UP: Event - LOGIN.
2/23 12:39:24 420 C[0x1112], IN_LOGIN: T4.
2/23 12:39:24 420 Params: <<< String param 'InitiatorName': received 'iqn.1991-05.com.microsoft:media-pc', accepted 'iqn.1991-05.com.microsoft:media-pc'
2/23 12:39:24 420 Params: <<< Enum param 'SessionType': received 'Discovery', accepted 'Discovery'
2/23 12:39:24 420 Params: <<< Enum param 'AuthMethod': received 'None', accepted 'None'
2/23 12:39:24 420 Params: Update OFMarkInt according to the value of OFMarker.
2/23 12:39:24 420 Params: Update IFMarkInt according to the value of IFMarker.
2/23 12:39:24 420 T[0x1]: Anonymous connection allowed.
2/23 12:39:24 420 Params: >>> AuthMethod=None.
2/23 12:39:24 520 T[0x1]: The end of stage 0, next stage is 1.
2/23 12:39:24 420 Params: <<< Enum param 'HeaderDigest': received 'None,CRC32C', accepted 'None'
2/23 12:39:24 420 Params: <<< Enum param 'DataDigest': received 'None,CRC32C', accepted 'None'
2/23 12:39:24 420 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 65536, accepted 65536
2/23 12:39:24 420 Params: <<< Numeric param 'DefaultTime2Wait': received 0, accepted 2
2/23 12:39:24 420 Params: <<< Numeric param 'DefaultTime2Retain': received 60, accepted 20
2/23 12:39:24 420 Params: >>> HeaderDigest=None.
2/23 12:39:24 420 Params: >>> DataDigest=None.
2/23 12:39:24 420 Params: >>> InitialR2T=No.
2/23 12:39:24 420 Params: >>> ImmediateData=Yes.
2/23 12:39:24 420 Params: >>> MaxRecvDataSegmentLength=65536.
2/23 12:39:24 420 Params: >>> MaxBurstLength=262144.
2/23 12:39:24 420 Params: >>> FirstBurstLength=65536.
2/23 12:39:24 420 Params: >>> DefaultTime2Wait=2.
2/23 12:39:24 420 Params: >>> DefaultTime2Retain=20.
2/23 12:39:24 420 Params: >>> MaxOutstandingR2T=1.
2/23 12:39:24 420 Params: >>> DataPDUInOrder=Yes.
2/23 12:39:24 420 Params: >>> DataSequenceInOrder=Yes.
2/23 12:39:24 520 T[0x1]: The end of stage 1, next stage is 3.
2/23 12:39:24 520 C[0x1112], IN_LOGIN: Event - LOGIN_ACCEPT.
2/23 12:39:24 520 C[0x1112], LOGGED_IN: T5.
2/23 12:39:24 520 C[0x1112], LOGGED_IN: Event - LOGOUT.
2/23 12:39:24 520 C[0x1112], IN_LOGOUT: T9/10.
2/23 12:39:24 6bc C[0x1112], IN_LOGOUT: Event - LOGOUT_ACCEPT.
2/23 12:39:24 6bc C[0x1112], FREE: T13.
2/23 12:45:52 7a4 Srv: Accepted connection from 10.10.1.100:1876. id assigned - 4371
2/23 12:45:52 7a4 C[0x1113], FREE: Event - CONNECTED.
2/23 12:45:52 7a4 C[0x1113], XPT_UP: T3.
2/23 12:45:52 388 C[0x1113], XPT_UP: Login request: ISID 0x400001370000, TSIH 0x0000.
2/23 12:45:52 388 C[0x1113], XPT_UP: Event - LOGIN.
2/23 12:45:52 388 C[0x1113], IN_LOGIN: T4.
2/23 12:45:52 388 Params: <<< String param 'InitiatorName': received 'iqn.1991-05.com.microsoft:media-pc', accepted 'iqn.1991-05.com.microsoft:media-pc'
2/23 12:45:52 388 Params: <<< Enum param 'SessionType': received 'Discovery', accepted 'Discovery'
2/23 12:45:52 388 Params: <<< Enum param 'AuthMethod': received 'None', accepted 'None'
2/23 12:45:52 388 Params: Update OFMarkInt according to the value of OFMarker.
2/23 12:45:52 388 Params: Update IFMarkInt according to the value of IFMarker.
2/23 12:45:52 388 T[0x1]: Anonymous connection allowed.
2/23 12:45:52 388 Params: >>> AuthMethod=None.
2/23 12:45:52 568 T[0x1]: The end of stage 0, next stage is 1.
2/23 12:45:52 388 Params: <<< Enum param 'HeaderDigest': received 'None,CRC32C', accepted 'None'
2/23 12:45:52 388 Params: <<< Enum param 'DataDigest': received 'None,CRC32C', accepted 'None'
2/23 12:45:52 388 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 65536, accepted 65536
2/23 12:45:52 388 Params: <<< Numeric param 'DefaultTime2Wait': received 0, accepted 2
2/23 12:45:52 388 Params: <<< Numeric param 'DefaultTime2Retain': received 60, accepted 20
2/23 12:45:52 388 Params: >>> HeaderDigest=None.
2/23 12:45:52 388 Params: >>> DataDigest=None.
2/23 12:45:52 388 Params: >>> InitialR2T=No.
2/23 12:45:52 388 Params: >>> ImmediateData=Yes.
2/23 12:45:52 388 Params: >>> MaxRecvDataSegmentLength=65536.
2/23 12:45:52 388 Params: >>> MaxBurstLength=262144.
2/23 12:45:52 388 Params: >>> FirstBurstLength=65536.
2/23 12:45:52 388 Params: >>> DefaultTime2Wait=2.
2/23 12:45:52 388 Params: >>> DefaultTime2Retain=20.
2/23 12:45:52 388 Params: >>> MaxOutstandingR2T=1.
2/23 12:45:52 388 Params: >>> DataPDUInOrder=Yes.
2/23 12:45:52 388 Params: >>> DataSequenceInOrder=Yes.
2/23 12:45:52 568 T[0x1]: The end of stage 1, next stage is 3.
2/23 12:45:52 568 C[0x1113], IN_LOGIN: Event - LOGIN_ACCEPT.
2/23 12:45:52 568 C[0x1113], LOGGED_IN: T5.
2/23 12:45:52 568 C[0x1113], LOGGED_IN: Event - LOGOUT.
2/23 12:45:52 568 C[0x1113], IN_LOGOUT: T9/10.
2/23 12:45:52 640 C[0x1113], IN_LOGOUT: Event - LOGOUT_ACCEPT.
2/23 12:45:52 640 C[0x1113], FREE: T13.
