I have a 3 node cluster using the free vsa (Node3 is the witness node). The nodes are running the latest version of starwind. There was some networking issues that caused the nodes to go offline. Node 2 shows synchronized. When it tries to synchronize with node 1 is fails at 6%. I also noticed that when I try to vmotion VMs off the iSCSI target the task will fail with the same message as the synchronization message. Here are the logs:
11/12 22:57:05.677468 2f debug: *** Swn_CheckCompletions: io_event for ov 0000000001ED5C10, res 5, err 31!
11/12 22:57:05.677502 2f IMG: *** ImageFile_IoCompleted: Disk operation failed. Disk path: C:\StarWind\storage\mnt\disk0\vmhost1-vmhost2-4TB-SSD-1.img. Error code: (31).
11/12 22:57:05.677513 2f func: >>> iScsiServer::sendNotification
11/12 22:57:05.677517 2f func: >>> CEventDataBase::AddRecord
11/12 22:57:05.677523 2f EventDB: CEventDataBase::AddRecord: Code 520, severity 3, additional strings: 2
11/12 22:57:05.677537 2f func: <<< CEventDataBase::AddRecord
11/12 22:57:05.677540 2f Srv: iScsiServer::sendNotification: Send reaction start (reaction type 2, msg code 520).
11/12 22:57:05.677552 2f Srv: iScsiServer::sendNotification: Send reaction finish.
11/12 22:57:05.677555 2f Srv: iScsiServer::sendNotification: Send reaction start (reaction type 1, msg code 520).
11/12 22:57:05.677658 2f Srv: iScsiServer::sendNotification: Send reaction finish.
11/12 22:57:05.677663 2f func: <<< iScsiServer::sendNotification
11/12 22:57:05.677666 2f IMG: *** ImageFile_ReadWriteSectorsCompleted: Error occured (ScsiStatus = 2, DataTransferLength = 0)!
11/12 22:57:05.677672 2f IMG: *** ImageFile_ReadWriteWithCacheCompleted: Error (0xC0000001) returned to cache request completion!
11/12 22:57:05.677677 2f Common: CStarWindStorageDevice::AsyncReadWriteCompleted: IO operation failed, scsi status 2!
11/12 22:57:05.677680 2f Common: CStarWindStorageDevice::AsyncReadWriteCompleted: SenseCode = 3, AdSenseCode = 0, AdSenseQualifier = 0
11/12 22:57:05.677684 2f HA: *** HANode::sscRequestScsiOpRead_CompleteCallback: There's no synchronized partner and read error(senseKey = 3)
11/12 22:57:05.677688 2f HA: HASyncNode::sscRequestScsiOpRead_Complete: Native read returned: ScsiStatus = 0x2, SenseCode = 0x3, AdSenseCode = 0x0, AdSenseQualifier = 0x0
11/12 22:57:05.677692 2f HA: HANode::completeSscCommandRequest: (0x28) CHECK_CONDITION , sense: 0x3 0x0/0x0 returned.
Any help appreciated!
