Is it possible to install startwind VSAN without HA?
kktwenty
Thu Jun 30, 2022 10:34 am
I know this sounds like a very strange request but can you create a non HA vsan? I.e. on server with local storage, create a starwind iscsi presented volume (that will only be used on that server)? No heartbeat, lose the server or storage and lose the starwind volume etc. I have looked through the powershell scripts but couldnt see a way of creating a 1 node no HA. I can see the "Add-HADevice" command but obviously this needs details of a second node. Would this be what the "createimagefile.ps1" is for? i.e. would this create a single node non HA iscsi target
aram($addr="127.0.0.1", $port=3261, $user="root", $password="starwind",
	$fileName="VD01",
	$filePath="My Computer\f\Starwind_VD01",
	$size=5000000,
	$targetAlias="VD015T",
	$sectorSize=4096,
	$numaNode=0,
	$cacheMode="wb",
	$cacheSize=128)
Import-Module StarWindX
try
	Enable-SWXLog
	if($sectorSize -eq 4096 -and $size -lt 2)
		throw "Minimal device size 2MB"
	$server.Connect()
	#create image file
	New-ImageFile -server $server -path $filePath -fileName $fileName -size $size
	#create device
	$device = Add-ImageDevice -server $server -path $filePath -fileName $fileName -sectorSize $sectorSize -NumaNode $numaNode -CacheMode $cacheMode -CacheSize $cacheSize
	$device
	#create target
	$target = New-Target -server $server -alias $targetAlias -devices $device.Name
	$target
catch
	Write-Host $_ -foreground red
finally
	$server.Disconnect()
I have seen that there is a starwind vsan and nas but I was under the impression that this was a VM rather than a more lightweight application that can run on an existing server.
Thu Jun 30, 2022 12:48 pm
Welcome to StarWind Forum. Yes, you can create a non-replicated (i.e., standalone) .img file. Try CreateImageFile.ps1.
NOTE: Please make sure to disable caching for that device.
kktwenty
Thu Jun 30, 2022 1:41 pm
perfect. thank you.
Thu Jun 30, 2022 2:40 pm
You are welcome. Let me know if more assistance is needed.
