Hyper Converged Power Outage
janderson133
Wed May 04, 2022 5:31 am
In my lab I'm testing a hyper-converged scenario on vmware using the vsan for vmware ovf template. Here are my hosts/guests:
- vmHost1 with guest starwind-vsan1
- vmHost2 with guest starwind-vsan2
- vmHost3 with guest starwind-vsan3
I created a 2TB volume with the "master" image on starwind-vsan1 and the "partner" image on starwind-vsan2. starwind-vsan3 is the witness.
During a power outage where all hosts go down the starwind-vsan guests come up but the storage is marked as unsynchronized. I have to manually force one of the images as synced (only used master to date, but I'm guessing I could use partner if I knew the master was down before the partner). A 5 hour full synchronization is then started :/ I'm 99% sure this is by design.
I thought I read that the storage wasn't supposed to be used used during a full sync? Is this true? If yes, that really stinks because waiting 5 hours to bring up the guests is going to be a problem.
I noticed the vmHosts will remount the storage while it is being synced. However, I/O actions like storage vMotioning a guest to the iSCSI target will cause the "master" starwind-vsa1 guest to crash. Maybe this is expected behavior during a full sync?
Thanks for the help - Jeff
Wed May 04, 2022 1:56 pm
Greetings,
I think master and partner are not correct as we are referring to the active-active replication. See more at https://forums.starwindsoftware.com/vie ... f=5&t=5731.
You need to mark storage as synchronized due to write back cache, most probably. See the correct procedure to fix the mutual not synchronized conditions at https://knowledgebase.starwindsoftware. ... -blackout/.
Yes, full synchronization after the outage is OK.
Only the synchronized partner is available over iSCSI during full synchronization. Not synchronized node is not available over iSCSI until in sync.
This is probably related to the I/O load during enhanced storage vMotion. Please avoid i/o consuming tasks during the full synchronization.
janderson133
Wed May 04, 2022 11:39 pm
Thanks for the info. I just called the images master and partner like the powershell scripts :)
Sounds like I will always have this sync issue during an outage of all nodes because of the write-back cache.
As such, I created a 3 node cluster (2 active storage nodes and 1 witness) with write-through cache and the nodes didn't synchronize after creation - I had to run the powershell scrip to mark one of the nodes as synced (I just thought that was weird because when the cluster is created with write-back cache synchronization starts automatically).
I performed that same crash test - powered off all 3 storage vms at the same time. I brought them all back online at the same time and it came up perfectly - a full sync was initiated but I didn't have to do anything.
I appreciate the help.
Jeff
Thu May 05, 2022 3:38 pm
Greetings,
Yes, this synchronization behavior is often observed for HA devices with Write-Back cache on. It might happen to devices with no cache too though. See how to address such incidents in production https://knowledgebase.starwindsoftware. ... -blackout/
