Free vSAN network setup
mrcurlywurly
Thu Apr 21, 2022 4:31 pm
Hi All,
I have installed vSAN and created my first target and disk via powershell, but it appears I can only connect on locally 127.0.0.1.
Checking under:
"Configuration" >>> "Network"
This is only shows 127.0.0.1
Do I need to update the network section with the IP of my network interface?
Here is a screenshot of what I am seeing:
https://imgur.com/a/l2H1onK
Mon Apr 25, 2022 10:23 am
Did you set up any networks so far?
Can I see ipconfig and get-netadapter outputs, please? Finally, please make sure not to have the iSCSI Server feature installed.
mrcurlywurly
Wed Apr 27, 2022 4:02 pm
yaroslav (staff) wrote:Hi,
Thank you so much! It looks like this was caused by the iSCSI Server feature being installed. Removing that and rebooting looks to have fixed the Network section :)
Wed Apr 27, 2022 4:08 pm
Greetings,
Thank you for your update.
