Unable to create 2 node vSAN with SMB quorum
Chinny
Thu Feb 10, 2022 6:09 pm
Hi all,
I've been tinkering around with Starwind's vSan solution and it works well. I've setup a 2 Node setup without quorum and it really works and I am very content with it.
To prevent a split-brain situation i would like to use the 2 Node setup with SMB quorum. But i just can't get it to work, The error that i get is: "200 The server is inaccessable."
I am assuming the error is about Starwind not being able to reach the samba share. If i set Failover to '0' and remove all smb related arguments, the virtual disk will be successfully created.
i am not 100% sure if i set the heartbeat interfaces correctly. Could anyone check my code? Any help would be appreciated. Thanks alot!
Tomorrow ill be at work again to get some logs out Starwind, let me know which files to check and ill check and upload it.
This is how the server layout looks like:
                     Witness with SMB
                     Samba @ \\172.16.20.30\witness\
                  / (vlan 100)                 \ (vlan 100)
= Node 1 =                                          = Node 2 =
Mgnt nic (172.16.20.20)    <-----vlan 100 --->     Mgnt nic (172.16.20.21)
hb nic (192.168.1.10)      <-----direct link---->  hb nic (192.168.1.11)
Sync nic (192.168.2.10)   <-----direct link---->   Sync nic (192.168.2.11)
*direct link is a link without a connection to a switch.
this is the following code that i use(CreateHASmbWitness.ps1):
param($addr="172.16.20.20", $port=3261, $user="root", $password="starwind",
	$addr2="172.16.20.21", $port2=$port, $user2=$user, $password2=$password,
#common
	$initMethod="Clear",
	$size=1024,
	$sectorSize=512,
	$failover=1,
	$smbWitnessFilePath="\\172.16.20.30\witness\witness.dat",
	$smbWitnessUsername="<user>",
	$smbWitnessPassword="<secret pass>",
#primary node
	$imagePath="\mnt\disk1",
	$imageName="masterImg21",
	$createImage=$true,
	$storageName="",
	$targetAlias="targetha21",
	$autoSynch=$true,
	$poolName="pool1",
	$syncSessionCount=1,
	$aluaOptimized=$true,
	$cacheMode="wb",
	$cacheSize=128,
	$syncInterface="#p2=192.168.2.11:3260",
	$hbInterface="#p2=172.16.20.21:3260,192.168.1.11:3260",
	$createTarget=$true,
#secondary node
	$imagePath2="\mnt\disk1",
	$imageName2="partnerImg22",
	$createImage2=$true,
	$storageName2="",
	$targetAlias2="partnerha22",
	$autoSynch2=$true,
	$poolName2="pool1",
	$syncSessionCount2=1,
	$aluaOptimized2=$false,
	$cacheMode2=$cacheMode,
	$cacheSize2=$cacheSize,
	$syncInterface2="#p1=192.168.2.10:3260",
	$hbInterface2="#p1=172.16.20.20:3260,192.168.1.10:3260",
	$createTarget2=$true
Import-Module StarWindX
try
	Enable-SWXLog -level SW_LOG_LEVEL_DEBUG -path "c:\Starwind.log"
	$server.Connect()
	$firstNode = new-Object Node
	$firstNode.HostName = $addr
	$firstNode.HostPort = $port
	$firstNode.Login = $user
	$firstNode.Size = $size
	$firstNode.SmbWitnessFilePath = $smbWitnessFilePath
	$firstNode.SmbWitnessUsername = $smbWitnessUsername
	$firstNode.SmbWitnessPassword = $smbWitnessPassword
	$secondNode = new-Object Node
	$secondNode.HostName = $addr2
	$secondNode.HostPort = $port2
	$secondNode.Login = $user2
        $secondNode.SmbWitnessFilePath = $smbWitnessFilePath
	$secondNode.SmbWitnessUsername = $smbWitnessUsername
	$secondNode.SmbWitnessPassword = $smbWitnessPassword
		Start-Sleep -m 2000
		$device.Refresh()
catch
	Write-Host $_ -foreground red
    Write-Host $_.Exception
finally
	$server.Disconnect()
*edited, code wasn't correct.
Chinny
Fri Feb 11, 2022 9:02 am
When i analyze the logs on the starwind appliance, i see the following:
This is the logs from 172.16.20.20(node1)
tail -f /var/StarWind/StarWindVSA/logs/StarWindVSA-20220211-094534.log
2/11 9:48:58.467474 2f conf: TelnetListener::listenConnections: Accepted control connection from 172.16.20.24:50300.
2/11 9:48:58.487339 3b FileBrowser: *** CFileBrowser::parsePath: Could not create image : provided path has invalid extension!
2/11 9:48:58.487363 3b Srv: *** iScsiServer::list: Error parsing path: VSA Storage\mnt\
2/11 9:49:00.165534 3b HA: SscPort_ControlRequest: Received request to create SMB witness
2/11 9:49:00.165574 3b HA: SscPort_ControlRequest: SMB file path to create '\\172.16.20.24\witness-test\witness.dat'
2/11 9:49:00.169070 40 HA: *** SmbWitnessImp::connect: WNetAddConnection2A(\\172.16.20.24\witness-test) failed, error code 0x4c6!
2/11 9:49:00.169092 40 HA: *** SmbWitnessImp::synchronousCreate: connect() failed, error code 0x4cd!
2/11 9:49:00.227198 3b conf: ControlConnection::processConnection: Control connection closed.
Fri Feb 11, 2022 9:27 am
Greetings,
Thanks for your question. The SMB witness is not available for StarWind VSAN for vSphere and is to be introduced in builds to come. Stay tuned.
Chinny
Fri Feb 11, 2022 9:45 am
Thanks for your reply, i wish i knew this earlier. Is there a way to get notified when this functionality is implemented for vSphere? Thank you again.
Fri Feb 11, 2022 9:25 pm
Greetings,
Yes, you can check the release notes from time to time OR log a call with Support by reaching out to us at support@starwind.com.
Chinny
Mon Feb 14, 2022 9:28 am
Before i start spending more time on this. How about 'CreateHAPartnerWitness.ps1' does this script work for Starwind vSAN on vSphere? Thank you.
Mon Feb 14, 2022 3:40 pm
Greetings,
SMB witness is not available for VSAN for vSphere for now. Using script does not make it.
SMB witness is only the VSAN for Hyper-V feature for now.
Chinny
Tue Feb 15, 2022 9:04 am
No, thats for 'CreateHASmbWitness.ps1'. This script utilizes the SMB share as a witness server. I know this functionality is not implemented yet and does not work in vSphere.
To be clear, I am asking about using the Starwind appliance as a witness node without any vSAN data. Which would be this script: 'CreateHAPartnerWitness.ps1'. Does this one work under vSphere?
If this script doesn't work as a partner witness under vSphere, then i assume this functionality does not work for the paid version as well under vSphere.
Thank you for your replies.
Tue Feb 15, 2022 12:40 pm
Sorry for such a misunderstanding. Node majority works for VSAN for vSphere.
