Poor performance VSAN Vsphere
CedricT
Thu Mar 25, 2021 9:40 am
We have this configuration:
2 HPE DL385Gen10
Raid Controler: HPE RAID Smart Array P408i-a SR Gen10
10 HDD 1.2To SAS 10k => RAID 5 (not the best option we know)
1 SSD 1.7 To => RDM for cache L2
We noticed we have a very poor performance if we disable the cache on the RAID 5 even if we use cache L1 starwind
Is there any trick with this raid controler?
Thu Mar 25, 2021 11:11 am
For HDDs, please always use RAID controller cache.
CedricT
Thu Mar 25, 2021 11:27 am
Since i was following this recommandation i don't clearly understand
https://knowledgebase.starwindsoftware. ... ssd-disks/
Recommended settings for hardware RAID arrays based on HDD:
RAID type: RAID 10
Disk cache policy: Default (disabled by default)
Write policy: Write Back
Read policy: Read ahead
Stripe Size: 64K
Thu Mar 25, 2021 12:05 pm
In your original post, you reported bad performance with RAID 5 cache disabled. I mentioned that you need to enable it (in our KB you can see that we recommend write-back cache), disk caching is a bit different thing.
CedricT
Fri Mar 26, 2021 9:38 am
Alright my bad!
Clearly we misread the recommandations.
Thank you again!
Fri Mar 26, 2021 9:55 am
No worries, always glad to help you!
