How to uninstall? (Starwind/BSOD problem)
nwebb
Sun Jan 01, 2006 8:12 pm
last week I installed Alcohol 120 with Starwind (on XP [Media Center Edition]) but since then I've been experiencing Blue-screens.
The Windows error log is reporting errors with the Starwind service just before each crash occurs.
I've uninstalled Alcohol, but I can't see how to uninstall Starwind. Any help appreciated!
Cheers,
Neil
Val (staff)
Sun Jan 01, 2006 9:27 pm
nwebb wrote:Hi,
Cheers,
Neil
Hi Neil,
Starwind is purely an usermode application, so it's very unlikely the BSODs occure because of it.
There may be some third-party driver in your environment that misbehaves completing SPTI requests used by StarWind to recognize CD/DVD burners in the system.
The StarWind module should be uninstalled during uninstalling of the main Alcohol.
You can manually uninstall StarWind if you need:
1) Start the Command prompt and change dir to the location where StarWindService.exe is.
2) StarWindService.exe --stop
3) StarWindService.exe --uninstall
I hope this helps.
Valeriy
nwebb
Mon Jan 02, 2006 4:13 pm
Thanks Valerie :)
Val (staff)
Tue Jan 03, 2006 8:47 am
nwebb wrote:Thanks Valerie :)
Glad to help you. :)
Valeriy
Tue Jan 03, 2006 1:24 pm
Well... Actually we'd be more happy to help you to make your system work with StarWind instead of helping you to remove our code from your machine :)
