VSAN in Maintenance can't be off if one node is offline
pega2k
Wed Apr 01, 2020 6:01 pm
How can I put the remain node online. I try it with SwitchMaintenanceMode($false, $true) in powershell and it give "connection with partner node is invalid."
Greetings, PE.
Oleg(staff)
Wed Apr 01, 2020 6:57 pm
Hello PE,
In the case of losing the partner node, you would need to move StarWind devices from maintenance manually:
- stop StarWind service on this node;
- open *HA.swdsk header in the folder with StarWind device you want to move from maintenance;
- find <maintenance_mode>true</maintenance_mode> string and change to <maintenance_mode>false</maintenance_mode> ;
- start StarWind service and mark the device as synchronized.
pega2k
Thu Apr 02, 2020 2:32 pm
Oleg(staff) wrote:Hello PE,
Thank you, Oleg, any of these step can be done using the powershell module?, I am using the free license.
Thank again, PE.
Oleg(staff)
Thu Apr 02, 2020 2:51 pm
You need PowerShell only for the last step, mark the device as synchronized.
All other steps you can make with any version of StarWind.
pega2k
Thu Apr 02, 2020 3:12 pm
Oleg(staff) wrote:You need PowerShell only for the last step, mark the device as synchronized.
Perfect, thanks.
Oleg(staff)
Thu Apr 02, 2020 3:21 pm
You are welcome :)
