Starwind Web Console Problem
mahuan1688
Tue Mar 17, 2020 9:57 am
When deploying the program starwindmanagementconsolewebovf, import the virtual machine, but do not know the account and password of the Linux system. The user and password to view the document are starwind, but they cannot log in successfully.
It's a program at this address:
http://starwind.com/tmplink/StarWindMan ... WebOVF.zip
Tue Mar 17, 2020 11:14 am
L: starwind
P: starwind
do not work?
I tried quite a couple of months ago but everything was working...
mahuan1688
Tue Mar 17, 2020 11:59 am
The prompt after entering the user and password is incorrect, and the IP address cannot be seen,
Tue Mar 17, 2020 12:03 pm
Try
L: root
P: root
mahuan1688
Tue Mar 17, 2020 12:09 pm
Can't log in. The password is wrong
Tue Mar 17, 2020 12:57 pm
Try old credentials
L:root P:starwind
If that will not work, please submit a support ticket to get the steps on password recovery. Add there a link at this thread.
mahuan1688
Tue Mar 17, 2020 1:03 pm
web login is starwind ,password is starwind,But the login prompts this
linux login and password Still can not log in, can you test it, or give a new address to download.
Tue Mar 17, 2020 1:30 pm
The error depicted in the screenshot is a connectivity error. Please try logging in again when the connection becomes stable.
P.S. The default credentials worked for me.
mahuan1688
Wed Mar 18, 2020 5:12 am
do you have StarWind Command Center download address?I want try this product Replace web console。
Wed Mar 18, 2020 8:36 am
Hi, unfortunately, it is still undergoing testing and major improvement. I do not have a release ETA right now.
mahuan1688
Fri Apr 17, 2020 1:26 pm
Can't log in, is there any way, all passwords that can be tested have been tested and are incorrect
Sat Apr 18, 2020 3:33 pm
Hi mahuan1688,
Sorry to read that. The VM is deployed as an appliance and should be used only via the web interface. We cannot share the root password with users.
You can use its web interface.
