I've downloaded and installed VSAN Free on two new 2019 Servers. I've created successfull the first HA Image & Target with CreateHA_2.ps1. The first sync was successfull and I can connect via iSCSI.
I've changed some params ($imageName and $size) in the CreateHA_2.ps1 and created the second HA Image. This was successful, but in the Mgmt Console ist on the 1st node an error: Partner "xxx" is not synchronized. In the logs there are the following warnings/errors:
12/18 15:44:33.698510 8a8 HA: HANode::setIsNodeActive: Params(active = 1) ENTERed for target 'iqn.2008-08.com.starwindsoftware:hv2-hv2-ha'.
12/18 15:44:36.665746 20a8 HA: HANode::checkSyncTypeAvailableLocaly: Synchronization method <HA_SYNCH_TYPE_FAST> isn't available for current nodebecause cache mode is write back. The local node has not been shut gracefully and wasn't active.
12/18 15:44:36.667272 20a8 HA: HANode::synchronizeCurrentNode: Params(partnerNode = 0x00000169E712BD00, syncType = 1, snapshotId = 0x0, ignoreOwnSyncState = 0) ENTERed
12/18 15:44:36.667659 20a8 HA: HANode::synchronizeCurrentNode: Shutdown node before sending synchronization request!
12/18 15:44:36.667676 20a8 HA: HANode::shutdownCurrentNode_internal: Params(closeClientConnections = 1, sendShutdownNotifications = 1, partnerNodeNotificationExcluded = 0x0000000000000000, synchronizeCache = 1, synchronizeCacheSynchronously = 0, useHeaderCache = 0) ENTERed for target 'iqn.2008-08.com.starwindsoftware:hv2-hv2-ha'.
12/18 15:44:36.667789 20a8 HA: HANode::setIsNodeActive: Params(active = 0) ENTERed for target 'iqn.2008-08.com.starwindsoftware:hv2-hv2-ha'.
12/18 15:44:36.671303 20a8 HA: CHAPartnerNode::SendSynchronizationRequestCommand: ENTERed with params: p_SyncType = 1, p_ulSnapshotID = 0x0, p_bContinue = no, p_bVaaiWriteSame = yes
12/18 15:44:36.672374 259c HA: HANode::stopThreadSyncProgressPolling: Thread was not stopped, because thread isn't started.
12/18 15:44:36.672436 259c HA: HANode::setSyncStatus: Event: Device changed own sync status to 2 from 1. (target name = 'iqn.2008-08.com.starwindsoftware:hv2-hv2-ha')
12/18 15:44:36.676182 259c HA: HANode::runThreadSyncProgressPolling: Params(p_pPartnerNode = 0x00000169E70E29A0)
12/18 15:44:38.696844 1a68 HA: HANode::setSyncStatus: Event: Device changed own sync status to 1 from 2. (target name = 'iqn.2008-08.com.starwindsoftware:hv2-hv2-ha')
12/18 15:44:38.712976 1a68 PR: ResLunReservationEx::importState_CMD_V1: reservations imported.
12/18 15:44:38.713170 1a68 HA: HANode::setIsNodeActive: Params(active = 1) ENTERed for target 'iqn.2008-08.com.starwindsoftware:hv2-hv2-ha'.
12/18 15:44:41.670896 20a8 HA: HANode::checkSyncTypeAvailableLocaly: Synchronization method <HA_SYNCH_TYPE_FAST> isn't available for current nodebecause cache mode is write back. The local node has not been shut gracefully and wasn't active.
12/18 15:44:41.672445 20a8 HA: HANode::synchronizeCurrentNode: Params(partnerNode = 0x00000169E712BD00, syncType = 1, snapshotId = 0x0, ignoreOwnSyncState = 0) ENTERed
12/18 15:44:41.672832 20a8 HA: HANode::synchronizeCurrentNode: Shutdown node before sending synchronization request!
12/18 15:44:41.672849 20a8 HA: HANode::shutdownCurrentNode_internal: Params(closeClientConnections = 1, sendShutdownNotifications = 1, partnerNodeNotificationExcluded = 0x0000000000000000, synchronizeCache = 1, synchronizeCacheSynchronously = 0, useHeaderCache = 0) ENTERed for target 'iqn.2008-08.com.starwindsoftware:hv2-hv2-ha'.
12/18 15:44:41.672961 20a8 HA: HANode::setIsNodeActive: Params(active = 0) ENTERed for target 'iqn.2008-08.com.starwindsoftware:hv2-hv2-ha'.
12/18 15:44:41.677106 20a8 HA: CHAPartnerNode::SendSynchronizationRequestCommand: ENTERed with params: p_SyncType = 1, p_ulSnapshotID = 0x0, p_bContinue = no, p_bVaaiWriteSame = yes
12/18 15:44:41.678543 259c HA: HANode::stopThreadSyncProgressPolling: Thread was not stopped, because thread isn't started.
12/18 15:44:41.678609 259c HA: HANode::setSyncStatus: Event: Device changed own sync status to 2 from 1. (target name = 'iqn.2008-08.com.starwindsoftware:hv2-hv2-ha')
12/18 15:44:41.682231 259c HA: HANode::runThreadSyncProgressPolling: Params(p_pPartnerNode = 0x00000169E70E29A0)
12/18 15:44:43.702065 19f8 HA: HANode::setSyncStatus: Event: Device changed own sync status to 1 from 2. (target name = 'iqn.2008-08.com.starwindsoftware:hv2-hv2-ha')
12/18 15:44:43.717878 19f8 PR: ResLunReservationEx::importState_CMD_V1: reservations imported.
why is the 1st one synced automatically and the second not? thank you very much!
