Starwind VASA Certificate Expired
BenM
Fri Dec 13, 2019 8:15 am
Guys,
I don't use vSphere - Win/Hyper-V all the way here - so should I be resetting the VASA certificate when it expires?
The cert expired on the anniversary of the install, back at the end of October, and I have only just noticed the warning in the windows event log :D
If I should be resetting VASA &, presumably, its certificate, can you confirm that
wmic -namespace:\\root\starwind path STARWIND_ClusterService call ResetVASA
Is the way to do it? (Found here)
Ben
Fri Dec 13, 2019 12:30 pm
First, let me explain what exactly VASA is. vSphere Storage APIs for Storage Awareness (VASA) – a set of application program interfaces that supplies information for the VMware ecosystem. This integration enables to configure StarWind Virtual SAN resources as storage containers for virtual machines and provide more efficient management for the architecture simplifying storage provisioning and consumption.
If you do not use any VMware components, no update is needed.
BenM
Fri Dec 13, 2019 2:28 pm
Thought as much - No vSphere, no VASA cert required.
Thanks for the confirmation.
Ben
Fri Dec 13, 2019 3:51 pm
You are right.
You are always welcome. :)
