StarWind iSCSI SAN
an external component caused an exception
Pure software-based VM-centric and flash-friendly VM storage (iSCSI, SMB3, NFS, iSER and NVMe over Fabrics) including free version. Same software embedded on StarWind ready nodes.
Postby kedal » Thu Nov 07, 2019 10:04 pm
Sorry if i have grammatical errors, but i am colombian.
I am using powershell scripting with the examples that are in Starwind, the script is: CreateHA(Two Nodes). But when i run it, only say me an external component has caused and exception or in Spanish: un componente externo produjo una excepción, as it is a testing i am using the default user and password, the patch is: C:\images
StarWind Version: 8.0.0.12767
And i am doing it with two Windows Server 2016.
Here is the script:
Import-Module StarWindX
try
   Enable-SWXLog
   $server.Connect()
   $firstNode = new-Object Node
   $firstNode.HostName = "localhost"
   $firstNode.ImagePath = "C:\images"
   $firstNode.ImageName = "masterImg21"
   $firstNode.Size = 1024
   $firstNode.TargetAlias = "targetha21"
   $firstNode.AutoSynch = $true
   $firstNode.SyncInterface = "#p2=10.0.132.102:3260"
   $firstNode.HBInterface = "#p2=10.1.1.2:3260"
   $firstNode.PoolName = "pool1"
   $firstNode.SectorSize = 4096
   $secondNode = new-Object Node
   $secondNode.HostName = "10.0.132.102"
   $secondNode.HostPort = "3261"
   $secondNode.Login = "root"
   $secondNode.ImagePath = "C:\images"
   $secondNode.ImageName = "partnerImg22"
   $secondNode.Size = 1024
   $secondNode.TargetAlias = "partnerha22"
   $secondNode.AutoSynch = $true
   $secondNode.SyncInterface = "#p1=10.0.132.101:3260"
   $secondNode.HBInterface = "#p1=10.1.1.1:3260"
      Start-Sleep -m 2000
      $device.Refresh()
catch
   Write-Host $_ -foreground red
finally
   $server.Disconnect()
Thank for the helo that you can bring me
kedal
Re: an external component caused an exception
Postby Boris (staff) » Fri Nov 08, 2019 8:32 am
Could you provide more details on what components you installed, the OS you try this with and any relevant information in general?
Postby kedal » Fri Nov 08, 2019 10:05 pm
Boris (staff) wrote:Could you provide more details on what components you installed, the OS you try this with and any relevant information in general?
Server x3100M4
Starwind 8.0.0.12767
Full Instalation
OS= Windows Server 2016 Standard/Version 1607
Server x3200 M3
Full Instalation
OS=Windows Server 2016 Standard/Version1607
I already checked the firewall, IP's, and folders permissions.
kedal
Postby Boris (staff) » Sat Nov 09, 2019 7:30 pm
Adjust Enable-SWXLog to
This is written to a file in the root of your user directory. I would like to have a look at this log file.
Postby kedal » Mon Nov 18, 2019 4:08 pm
Boris (staff) wrote:Adjust Enable-SWXLog to
Here is the log file that you need:
18-11  10:49:59  INFO   :    STARWINDX LOG STARTED!
18-11  10:49:59  INFO   :    Version 1.0.0.436
18-11  10:49:59  DEBUG  : Send to host 10.200.1.13261:
protocolversion 100
18-11  10:49:59  DEBUG  : Response from host 10.200.1.13261:
200 Completed.
login root starwind
200 Completed.
18-11  10:49:59  INFO   : Refresh service data
18-11  10:49:59  INFO   : Refresh targets
list -what:"targets" -mode:0
200 Completed.
TargetName="iqn.2008-08.com.starwindsoftware:localhost-db-storage"
TargetId="0x0000025A8B16B700"
TargetAlias="DB_Storage"
clustered="yes"
TargetNumaNode="0"
TargetDevices="HAImage1"
TargetLuns="0-0"
TargetLun="0000000000000000"
TargetLunId="0"
Eui64Id="521E16BDD73C280C"
Naa64Id="D41E16BDD73C280C"
DeviceId="0x0000025A8AE6D3C0"
DeviceLun="0"
LunNumaNode="0"
18-11  10:49:59  INFO   : Refresh devices
list -what:"devices"
200 Completed.
DeviceName="imagefile1"
DeviceId="0x0000025A8AE77D40"
DeviceHeaderPath="C:\images\DB_Storage.swdsk"
DeviceType="Image file"
DeviceBusType="Unknown"
SerialId="9573FE111C82BAB8"
Eui64Id="9573FE111C82BAB8"
Naa64Id="E573FE111C82BAB8"
ScsiInquiry="STARWIND STARWIND         0001"
DeviceMounted="no"
parent="HAImage1"
state="0"
reservation="yes"
DeviceNumaNode="0"
header="0"
file="C:\images\DB_Storage.img"
buffering="no"
asyncmode="yes"
SectorSize="4096"
PhySectorSize="4096"
ImageSizeLow="3045064704"
ImageSizeHigh="1"
readonly="no"
DeviceState="1"
CacheMode="none"
ScsiLun="0"
DeviceName="HAImage1"
DeviceHeaderPath="C:\images\DB_Storage_HA.swdsk"
DeviceType="HA Image"
SerialId="521E16BDD73C280C"
PoolName="pool1"
DeviceMounted="no"
storage="imagefile1"
state="0"
reservation="no"
DeviceNumaNode="0"
header="0"
file="C:\images\DB_Storage_HA.swdsk"
buffering="no"
asyncmode="yes"
readonly="no"
highavailability="yes"
ha_serialid_string="521E16BDD73C280C"
ha_synch_status="1"
ha_synch_percent="100"
ha_synch_type="0"
ha_sync_elapsed_time="0"
ha_sync_estimated_time="0"
ha_priority="0"
ha_is_node_removed_from_partners="no"
ha_is_storage_extend_supported="yes"
ha_is_storage_snapshot_supported="no"
ha_is_storage_device_ready="yes"
ha_is_storage_device_readonly="no"
ha_is_SMISHidden="no"
ha_autosynch_enabled="yes"
ha_wait_on_autosynch="0"
ha_auto_sync_priority="1"
ha_maintenance_mode="0"
ha_sync_traffic_share="50"
ha_alua_group_node_state="0"
ha_tracker="no"
ha_tracker_frozen="no"
ha_tracker_snapshots_storage=""
ha_tracker_mount_time="0"
ha_tracker_mount_snapshot=""
ha_tracker_status="-1"
ha_tracker_pending="0"
ha_tracker_replicated="0"
ha_tracker_replicating="0"
ha_tracker_scheduled="0"
ha_node_type="1"
ImageSizeHigh="1"
SectorSize="4096"
CacheMode="none"
CacheSizeMB="0"
CacheBlockExpiryPeriodMS="0"
ha_partner_nodes_count="1"
ha_failover_config_type="0"
ha_partner_node1_target_name="iqn.2008-08.com.starwindsoftware:10.200.1.2-db-storage"
ha_partner_node1_priority="1"
ha_partner_node1_type="1"
ha_partner_node1_storage_device_type="ImageFile"
ha_partner_node1_sync_channels="10.200.1.2$3260$1"
ha_partner_node1_heartbeat_channels="10.100.1.2$3260$1"
ha_partner_node1_is_exist_sync_valid_connection="1"
ha_partner_node1_is_exist_heartbeat_valid_connection="1"
ha_partner_node1_sync_status="1"
ha_partner_node1_sync_percent="0"
ha_partner_node1_sync_type="0"
ha_partner_node1_sync_elapsed_time="0"
ha_partner_node1_sync_estimated_time="0"
ha_partner_node1_tracker_frozen="no"
ha_partner_node1_tracker_snapshots_storage=""
ha_partner_node1_tracker_mount_time="0"
ha_partner_node1_tracker_mount_snapshot=""
ha_partner_node1_auth_chap_type="None"
ha_partner_node1_auth_chap_login=""
ha_partner_node1_auth_chap_password=""
ha_partner_node1_auth_mutual_chap_name=""
ha_partner_node1_auth_mutual_chap_secret=""
ScsiLun="0"
DeviceName="\\?\ide#diskhua722050cla330______39m4517_42c0468ibm_jp2oa3gb#5&1f30838c&0&0.0.0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}"
DeviceId="0x0000025A8AEB2140"
DeviceType="SPTI:Disk"
DeviceBusType="Ata"
SerialId="      JPW9L0N00AX1XL"
Eui64Id="0000000000000000"
Naa64Id="C000000000000000"
ScsiInquiry=" HUA722050CLA330  JP2O"
DeviceMounted="no"
state="0"
reservation="yes"
DeviceNumaNode="0"
ScsiAdapter="0"
ScsiBus="0"
ScsiTarget="0"
ScsiLun="0"
DeviceName="\\?\usbstor#disk&ven_generic&prod_flash_disk&rev_8.07#3e591adb&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}"
DeviceId="0x0000025A8AEB1500"
DeviceBusType="Usb"
SerialId="3"
ScsiInquiry="Generic  Flash Disk       8.07"
DeviceMounted="no"
state="0"
reservation="yes"
DeviceNumaNode="0"
ScsiAdapter="0"
ScsiBus="0"
ScsiTarget="0"
ScsiLun="0"
DeviceName="\\?\ide#cdromtsstcorp_dvd-rom_ts-h353c_______________le01____#5&394f2925&0&0.0.0#{53f56308-b6bf-11d0-94f2-00a0c91efb8b}"
DeviceId="0x0000025A8AEAF080"
DeviceType="SPTI:CD/DVD"
DeviceBusType="Atapi"
ScsiInquiry=" TSSTcorp DVD-ROM LE01"
DeviceMounted="no"
state="0"
reservation="yes"
DeviceNumaNode="0"
ScsiAdapter="2"
ScsiBus="0"
ScsiTarget="0"
ScsiLun="0"
18-11  10:50:00  INFO   :    STARWINDX LOG CLOSED!
kedal
Postby Boris (staff) » Tue Nov 19, 2019 2:54 pm
I will check the log additionally and let you know my findings.
Postby Boris (staff) » Tue Nov 19, 2019 4:04 pm
In the log I see a USB drive attached.
Try removing the USB drive and check the behavior once again.
Return to StarWind Virtual SAN / StarWind Virtual SAN Free / StarWind HyperConverged Appliance / StarWind Storage Appliance
Who is online
Users browsing this forum: No registered users and 4 guests
