Invalid Channel Format [2] from Create Device
whbn3
Tue Aug 20, 2019 6:17 pm
When I run CreateHA(two nodes).ps1 I get this error from CreateDevice.
Here is my modified script:
Import-Module StarWindX
try
Enable-SWXLog
$server = New-SWServer -host 10.1.3.106 -port 3261 -user root -password starwind
$server.Connect()
$firstNode = new-Object Node
$firstNode.HostName = "localhost"
$firstNode.ImagePath = "K:\"
$firstNode.ImageName = "masterImg21"
$firstNode.Size = 200
$firstNode.TargetAlias = "targetha21"
$firstNode.AutoSynch = $true
$firstNode.SyncInterface = "10.1.3.18"
$firstNode.HBInterface = "10.1.3.18"
$firstNode.PoolName = "pool1"
$firstNode.SectorSize = 512
$secondNode = new-Object Node
$secondNode.HostName = "10.1.3.18"
$secondNode.HostPort = "3261"
$secondNode.Login = "root"
$secondNode.ImagePath = "K:\"
$secondNode.ImageName = "partnerImg22"
$secondNode.Size = 200
$secondNode.TargetAlias = "partnerha22"
$secondNode.AutoSynch = $true
$secondNode.SyncInterface = "10.1.3.106"
$secondNode.HBInterface = "10.1.3.106"
Start-Sleep -m 2000
$device.Refresh()
catch
Write-Host $_ -foreground red
finally
$server.Disconnect()
Can anyone help me get past this?
Oleg(staff)
Wed Aug 21, 2019 8:36 am
The problem can be related to the IPs you are using. You are assigning the same IP for connecting, heartbeat and synchronization.
Please check best practices.
