Recovery from a physical disk failure
b4btec
Sat Jun 22, 2019 10:08 pm
I run a Starwind hyperconverged appliance at my business and I am using an NFR license to run my homelab to learn and get accustomed to it. I set up my homelab cluster following Starwind's document for Hyper-V, and I had three physical disks in each of the two nodes. The, the C drive, a D drive had the CSV1 and witness virtual disks and an E drive that had the CSV2 virtual disk. In node 2 the physical D drive failed, losing the witness and CSV1 on that node. I'm struggling to find documentation on how to recreate the disks on node 2 and get them synchronized. What is the procedure for this situation?
Mon Jun 24, 2019 9:44 am
Start from step 28 - and you will be able to create a replica of your disk to the previously failed partner.
https://www.starwindsoftware.com/resour ... -ha-device
