Dynamically enable or disable L1 cache?
danswartz
Fri May 03, 2019 7:41 pm
So, in my home lab, I'm in the middle of spinning up two vsphere 6.7 servers. Each host has a server 2016 VM as a storage appliance. I have a ton of ram on each server, so I thought to allocate 32GB or so to each VSA. Here's the thing: when we have a power failure, it's usually for an hour or longer, at which point the UPS has run out, and everything stops dead in its tracks. I had previously been using one vsphere host connecting to a CentOS 7 storage server with direct connect cables, with ZFS providing the storage. To improve write performance (using NFS), I had set sync=disabled, but that is problematic if an outage occurs. Since my lab has an APC UPS, I had apcupsd run a poweroff script when AC power fails, and a poweron script when it restores. The scripts enable or disable sync mode as appropriate. So, my question: is there any way to do this with Starwind? e.g. to have the VSAs query the UPS, and switch the L1 cache to write-through when AC power is lost, and switch back to write-back when it is restored?
Fri May 03, 2019 8:54 pm
Unfortunately, there is no way to dynamically change the operation mode of L1 cache in StarWind VSAN at present.
danswartz
Sat May 04, 2019 12:40 am
Ah, bummer. Thanks :)
Oleg(staff)
Mon May 06, 2019 10:07 am
You are welcome!
bertram
Sat May 18, 2019 6:12 am
while it's not possible to dynamically change the operation mode of the L1 cache what procedure could you recommend to perform this in a 2-node converged scenario?
Regards
bertram
Oleg(staff)
Mon May 20, 2019 2:25 pm
Please find KB article by following this link.
bertram
Wed May 22, 2019 4:47 am
is it safe enough to disable the WB L1 cache on only one node to survive a following complete power failure or do you recommend to do it on both nodes?
In case of the second scenario it really becomes tricky because without a built in logic in Starwind it's hard to define which node starts with the process.
Oleg(staff)
Wed May 22, 2019 8:05 am
The amount of caching should be the same on both nodes.
The cache is HA as well.
