Can't add a device
perdrix
Fri Apr 26, 2019 1:37 pm
I installed the latest Virtual SAN Free download to support my Tape drive (Tape Redirector function).
When I connect to the server the "Add Device" button is greyed out and I also get a nastygram saying "GUI management not allowed by license"????
Help!
David
Cheers
Dave
Oleg(staff)
Fri Apr 26, 2019 2:03 pm
That is correct. You can use GUI only for monitoring with the free license:
https://knowledgebase.starwindsoftware. ... g-options/
perdrix
Sat May 04, 2019 9:39 am
The older version worked fine and didn't disable the GUI - did I download the wrong thing? Or if not that how do I define my tape drive without using the GUI?
David
Oleg(staff)
Wed May 08, 2019 8:13 am
Yes, correct, Tape Redirector option should have GUI.
Could you please log a support case using this form?
Please refer to this thread.
perdrix
Wed May 08, 2019 9:00 am
Very odd I! I uninistalled,, reinstalled, and reloaded the license. Now everyhing works as I expected!
Confused in Kenilworth
David
Cheers
Dave
Oleg(staff)
Wed May 08, 2019 9:10 am
I am very glad to hear that the issue is resolved :)
