Starwind 6. Sync over 10 Gbit very slow
ss4344
Thu Apr 25, 2019 10:46 pm
I do. You can see in my post above, where I include the application log that MM is noted as being rolled back, just after heartbeat links all fail.
Thu Apr 25, 2019 11:07 pm
I would like you to submit a ticket via https://www.starwindsoftware.com/support-form with reference to this thread. Investigation of your case will be done there, while the result will be published here to update the community.
ss4344
Sat Apr 27, 2019 4:41 am
I think I worked out what was happening, Boris, so I won't log a case.
A previous test failure must have caused the Starwind devices to initiate a full sync (which I did not realise was running). On testing later while the sync was still running, attempting to put the devices in maintenance mode completed, despite the full sync, then it was rolled back. An improvement in Starwind logging to the application log might be warranted, or a failure to go into maintenance mode if a sync is running.
I ran a complete shutdown/restart test today when everything was in a stable state, and the test executed flawlessly.
Here are my final Hyper-V two-node cluster UPS shutdown scripts, in case they help anyone else:
Shutdown:
Executed with Eaton IPP:
cmd.exe /c "%SystemRoot%\sysnative\WindowsPowerShell\v1.0\powershell.exe -ExecutionPolicy Bypass -NoProfile -File c:\scripts\UPS-Shutdown-Node.ps1 > c:\scripts\UPS-Shutdown-Node.log 2>&1"
(A sysnative launch of POSH is needed because Eaton IPP runs as a 32-bit process. The sysnative causes a 64-bit POSH to be launched, which is required for this script because of cluster management.)
# Set SaveVMs to true will save the virtual machine state
# Setting it to false will shut down the virtual machine guest operating system
$SaveVMs = $true
# Maximum time to wait for all virtual machines to stop
$StopTimeout = 60
# Temporarty file holding node names, used for restart script
$NodeFile = "C:\Scripts\nodes.tmp"
# Get this node name, and save the cluster node names for the ExitMaintenance script to use later
$nodes = (Get-ClusterNode).Name
$nodes | Set-Content -Path $NodeFile
# Shut down VMs on this node, and prevent live migration by setting the owner node to just this node
$VMs = Get-VM
$VMcrs = Get-ClusterResource | ? {($VMs.Name -contains $_.OwnerGroup) -and ($_.ResourceType -eq "Virtual Machine")}
Write-Host "Setting cluster node ownership for $(($VMcrs).Count) cluster resources"
$VMcrs | Set-ClusterOwnerNode -Owners (Get-WmiObject win32_computersystem).DNSHostName
if ($SaveVMs) {
    Write-Host "Saving state of $($VMs.Count) virtual machines"
    $VMs | Stop-VM -Save -AsJob > $null 2>&1
} else {
    Write-Host "Shutting down $($VMs.Count) virtual machines"
    $VMs | Stop-VM -AsJob > $null 2>&1
# Wait until all virtual machine resources on all cluster nodes are offline
Write-Host "Waiting for all virtual machines on all nodes to stop"
$c1 = 0
do {
    $ResourcesOnline = ((Get-ClusterResource | ? {($_.ResourceType -eq "Virtual Machine") -and ($_.State -ne "Offline")}) | measure).Count
    if ($ResourcesOnline -gt 0) { $c1 += 1 ; sleep 1 }
} while (($ResourcesOnline -gt 0) -and ($c1 -lt $StopTimeout))
# If any cluster virtual machine resources remain in a non-offline state, terminate them if they are running on this node
    $StillRunning = Get-VM | ? {(Get-ClusterResource | ? {($_.ResourceType -eq "Virtual Machine") -and ($_.State -ne "Offline")}).OwnerGroup.Name -eq $_.Name}
    $StillRunning | ForEach-Object { Write-Host "$($_.Name) still not offline ... turning off" }
    $StillRunning | Stop-VM -TurnOff -Force -ErrorAction SilentlyContinue
# Randomly cause one node to continue first
$delay = Get-Random -Maximum 5000
Write-Host "Pausing $($delay) miliseconds"
Start-Sleep -Milliseconds $delay
# Take all cluster shared volumes offline
Write-Host "Taking cluster shared volumes offline"
do {
    Sleep 1
    $OnlineCSVs = Get-ClusterSharedVolume | ? {$_.State -eq 'Online'}
    $OnlineCSVs | ForEach-Object { $_ | Stop-ClusterResource -ErrorAction SilentlyContinue > $null }
} until (($OnlineCSVs | measure).Count -eq 0)
Import-Module StarWindX
# Set Starwind devices in maintenance mode
Write-Host "Preparing Starwind devices"
try {
    $SWserver = New-SWServer -Host 127.0.0.1 -Port 3261 -User root -Password starwind
    $SWserver.Connect()
    $SWserver.Devices | ? {$_.DeviceType -eq "HA Image"} | ForEach-Object {
        Write-Host "Putting $($_.Name) into maintenance mode"
        $_.SwitchMaintenanceMode($true, $true)
} catch {
    Write-Host $_ -foreground red
} finally {
    $SWserver.Disconnect()
# Create a scheduled task to disable maintenance mode on startup
Write-Host "Creating scheduled task to exit maintenance mode"
try {
    $action = New-ScheduledTaskAction -Execute "Powershell.exe" -Argument '-command "Powershell -ExecutionPolicy Bypass -NoProfile -File C:\Scripts\SW-ExitMaintenance.ps1 > C:\Scripts\SW-ExitMaintenance.log 2>&1"'
    $trigger = New-ScheduledTaskTrigger -AtStartup -RandomDelay 00:00:30
    $settings = New-ScheduledTaskSettingsSet -Compatibility Win8
    $principal = New-ScheduledTaskPrincipal -UserId SYSTEM -LogonType ServiceAccount -RunLevel Highest
    $definition = New-ScheduledTask -Action $action -Principal $principal -Trigger $trigger -Settings $settings -Description "Exit maintenance mode for Starwind HA devices"
    Register-ScheduledTask -TaskName "Maintenance Mode Off" -InputObject $definition > $null 2>&1
} catch {
# Set the Cluster and Virtual Machine Management services to manual
Write-Host "Setting cluster and vmms services to manual startup"
Get-Service -Name vmms | Set-Service -StartupType Manual
Get-Service -Name ClusSvc | Set-Service -StartupType Manual
# Shut down the node
Write-Host "Stopping cluster node"
Stop-Computer -Force
Restart:
$ServiceTimeout = 120
# Get the cluster node names that were saved by the UPS-Shutdown-Node script (can't use Get-ClusterNode as cluster not started yet)
$nodes = Get-Content -Path $NodeFile
$ServiceName = "StarWindService"
do {
    sleep 1
    $s1 = Get-Service -ComputerName $nodes[0] -Name $ServiceName -ErrorAction SilentlyContinue
    $s2 = Get-Service -ComputerName $nodes[1] -Name $ServiceName -ErrorAction SilentlyContinue
} until (($s1.Status -eq "Running") -and ($s2.Status -eq "Running"))
Write-Host "$ServiceName is running on both nodes"
# Take Starwind devices out of maintenance mode
try {
    $SWserver.Connect()
        Write-Host "Taking $($_.Name) out of maintenance mode"
        $_.SwitchMaintenanceMode($false, $true)
} catch {
} finally {
# Set the Cluster and Virtual Machine Management services to automatic, and start the services
Get-Service -Name vmms | Set-Service -StartupType Automatic
Get-Service -Name vmms | Start-Service
Get-Service -Name ClusSvc | Set-Service -StartupType Automatic
Get-Service -Name ClusSvc | Start-Service
$c1 = 0
$c2 = 0
$c3 = 0
$c4 = 0
do {
    $s1 = (Get-Service -ComputerName $nodes[0] -Name vmms).Status
    $s2 = (Get-Service -ComputerName $nodes[0] -Name ClusSvc).Status
    $s3 = (Get-Service -ComputerName $nodes[1] -Name vmms).Status
    $s4 = (Get-Service -ComputerName $nodes[1] -Name ClusSvc).Status
    if ($s1 -ne "Running") { $c1 += 1 } else { Write-Host "$($nodes[0]): Virtual Machine Management service running after $($c1) seconds" }
    if ($s2 -ne "Running") { $c2 += 1 } else { Write-Host "$($nodes[0]): Cluster service running after $($c2) seconds" }
    if ($s3 -ne "Running") { $c3 += 1 } else { Write-Host "$($nodes[1]): Virtual Machine Management service running after $($c3) seconds" }
    if ($s4 -ne "Running") { $c4 += 1 } else { Write-Host "$($nodes[1]): Cluster service running after $($c4) seconds" }
    if (($s1 -ne "Running") -or ($s2 -ne "Running") -or ($s3 -ne "Running") -or ($s4 -ne "Running")) { Sleep 1 }
} until ((($s1 -eq "Running") -and ($s2 -eq "Running") -and ($s3 -eq "Running") -and ($s4 -eq "Running")) -or ($c1 -gt $ServiceTimeout) -or ($c2 -gt $ServiceTimeout) -or ($c3 -gt $ServiceTimeout) -or ($c4 -gt $ServiceTimeout))
if (($c1 -gt $ServiceTimeout) -or ($c2 -gt $ServiceTimeout) -or ($c3 -gt $ServiceTimeout) -or ($c4 -gt $ServiceTimeout)) {
    Write-Host "A service failed to start"
    exit
# Make sure all CSVs are online
Write-Host "Waiting for all cluster shared volumes online"
do {
    Sleep 1
    $OfflineCSVs = Get-ClusterSharedVolume | ? {$_.State -ne 'Online'}
    foreach ($OfflineCSV in $OfflineCSVs) { Start-ClusterResource -Name $OfflineCSV.Name -ErrorAction SilentlyContinue > $null 2>&1 }
} until (($OfflineCSVs | measure).Count -eq 0)
# Small pause to ensure cluster recognises that cluster shared volumes are up
Sleep 15
# Start the VMs on all nodes, and set any node to be the owner
Write-Host "Setting virtual machine possible owners to all nodes"
Get-ClusterResource | ? {($_.ResourceType -eq "Virtual Machine")} | Set-ClusterOwnerNode -Owners (Get-ClusterNode).Name
Write-Host "Starting virtual machines on all nodes"
Get-ClusterResource | ? {($_.ResourceType -eq "Virtual Machine") -and ($_.State -eq "Offline")} | Start-ClusterResource
Write-Host "Unregistering scheduled task"
Unregister-ScheduledTask -TaskName "Maintenance Mode Off" -Confirm:$false -ErrorAction SilentlyContinue
Sun Apr 28, 2019 4:21 am
It's great you have been able to figure this out.
As for logging, I have transferred this information to R&D already for them to work on it further.
And thanks for sharing the scripts. I believe they will be useful for some of our community members.
