StarWind iSCSI SAN
Unable to set CHAP permissions on replicated targets
Pure software-based VM-centric and flash-friendly VM storage (iSCSI, SMB3, NFS, iSER and NVMe over Fabrics) including free version. Same software embedded on StarWind ready nodes.
Postby kkristian » Mon Mar 11, 2019 10:43 am
Dear all,
when trying to set CHAP permissions on replicated targets I get following error message:
Failed to remove permission from partners. Unable to retrieve partner information.
I can set the credentials before replication, but those are not replicated to partner.
regards,
Kristian
kkristian
Re: Unable to set CHAP permissions on replicated targets
Postby Oleg(staff) » Tue Mar 12, 2019 9:15 am
Hello Kristian,
Could you please clarify, did you configure CHAP permissions according to this article?
Oleg(staff)
Postby kkristian » Fri Mar 15, 2019 1:12 pm
Hello Oleg,
I was trying to set individual target permission. When the target is single node, I can add permission without issue, when the target is replicated across 2 nodes I get the mentioned error message. I was configuring CHAP permissions exactly as in the article (Setting individual target permissions part). I'm running version 8.0.0.10799.
kkristian
Postby Oleg(staff) » Fri Mar 15, 2019 2:58 pm
Hello Kristian,
I believe you need to upgrade the build you are currently using.
Could you please log a support case using this form?
Please refer to this thread.
Oleg(staff)
Return to StarWind Virtual SAN / StarWind Virtual SAN Free / StarWind HyperConverged Appliance / StarWind Storage Appliance
Who is online
Users browsing this forum: Google [Bot] and 8 guests
