StarWind iSCSI SAN
Starwind and Freenas
Software-based VM-centric and flash-friendly VM storage + free version, StarWind VSAN "Ready Nodes"
Postby Albotross » Thu Mar 07, 2019 12:00 pm
Can anyone tell me if the following is possible:
I'd like to run 2 freenas (or FreeBSD) servers with a Starwind Free VM running on each to use the freenas pool as my "direct attached" storage. Basically, I'm trying to take advantage of the ZFS file system and use SW as my HA solution running 2 nodes.
Any thoughts?
Or, is there a better way for a DIY, ZFS HA solution (without paying for appliances). This is a home lab (to start) and then home storage once I've gotten comfortable with the solution.
Albotross
Re: Starwind and Freenas
Postby Oleg(staff) » Fri Mar 08, 2019 1:51 pm
Technically, it should work.
Oleg(staff)
Postby KPS » Fri Mar 15, 2019 3:44 pm
Hi!
That sound complex and provides a lot of space for problems, where nobody can help you.
I would avoid to combine the two products.
KPS
Postby Oleg(staff) » Fri Mar 15, 2019 5:12 pm
Correct, that is why I wrote that technically should work :)
Oleg(staff)
Return to StarWind Virtual SAN (VSAN) & VSAN Free, StarWind HyperConverged Appliance (HCA) & Storage Appliance (SA)
Who is online
Users browsing this forum: No registered users and 3 guests
