StarWind iSCSI SAN
Starwind and VMWare - Delayed Ack
Pure software-based VM-centric and flash-friendly VM storage (iSCSI, SMB3, NFS, iSER and NVMe over Fabrics) including free version. Same software embedded on StarWind ready nodes.
Postby KPS » Mon Mar 04, 2019 3:29 pm
Hi!
Is it safe to use "Delayed Ack = Off" with Starwind?
I need to disable it for another storage, but both share the iSCSI-software-initiator...
Thank you for your help!
KPS
KPS
Re: Starwind and VMWare - Delayed Ack
Postby Oleg(staff) » Wed Mar 06, 2019 4:12 pm
Hi!
It is better to leave the default option.
You can disable one for the targets you are planning to use for another storage.
Oleg(staff)
Postby KPS » Wed Mar 06, 2019 4:42 pm
Hi Oleg,
thank you for your answer.
Its not possible to define "Delayed Ack" per volume, as I have to configure it for the whole initiator (and there is only one software-iscsi-initiator).
Does Starwind have any problems with Delayed-Ack=yes?
I can only use Starwind, if it does not interfer with the other storage.
Thank you
KPS
Postby Oleg(staff) » Fri Mar 08, 2019 1:40 pm
You can configure Delayed Ack per target :)
Generally, it should work without issues. But it is better to double check before.
Oleg(staff)
Return to StarWind Virtual SAN / StarWind Virtual SAN Free / StarWind HyperConverged Appliance / StarWind Storage Appliance
Who is online
Users browsing this forum: Google [Bot] and 1 guest
