StarWind iSCSI SAN
Problems installing Free version with ESX
Pure software-based VM-centric and flash-friendly VM storage (iSCSI, SMB3, NFS, iSER and NVMe over Fabrics) including free version. Same software embedded on StarWind ready nodes.
Postby jep » Fri Feb 22, 2019 1:51 pm
Trying to install the free version of VSAN as a proof of concept for possibly using at our company to replace using shared storage array between two hosts. Trying to follow the docs but not sure what I'm still missing.
I have my two StarWinds esx appliances up, with ip addresses, and local storage configured. I also have a management console running on a Windows VM. When I run the management console, I have the appliances connected, but I'm not able to add any devices. It's all greyed out. I know I haven't provided a lot of information here, but any clues on where to look?
Also, one more question. We use HA on our two ESX hosts. When you are using HA, you can't set specific VMs to startup and shutdown with the ESX host, so how exactly do you get these to start up?
Lastly, once the appliances are up and running, do they run independently of the StarWinds manager software?
James
jep
Re: Problems installing Free version with ESX
Postby Oleg(staff) » Mon Feb 25, 2019 11:05 am
Hi Jep,
StarWind Free version has Management Console only for monitoring, the options of creation/managing via console are available in trial and paid version. You can use and modify samples from StarWindX library from folder "C:\Program Files\StarWind Software\StarWind\StarWindX\Samples\powershell" according to your needs.
You can configure VMs startup/shutdown before enabling the vSphere HA option.
Yes, they can.
Oleg(staff)
Postby jep » Tue Feb 26, 2019 8:05 pm
Hello. I appreciate the response. I'm trying to use the CreateHA(two nodes) script. I keep getting this error:
Exception calling "CreateDevice" with "4" argument(s): "Failed to query volume properties: -1044527128
QueryVolumeProperties "/mnt/disk1"
104 Volume name required.. "
I can successfully run CreateImageFile and subsequently enumDevices just fine.
I cannot find any info on this error.
My script looks like this:
Import-Module StarWindX
try
   Enable-SWXLog
   $server = New-SWServer -host 192.168.1.55 -port 3261 -user root -password starwind
   $server.Connect()
   $firstNode = new-Object Node
   $firstNode.HostName = "192.168.1.55"
   $firstNode.ImagePath = "/mnt/disk1"
   $firstNode.ImageName = "img1"
   $firstNode.Size = 1300234
   $firstNode.TargetAlias = "partnerHA1"
   $firstNode.AutoSynch = $true
   $firstNode.SyncInterface = "#p2=192.168.99.56:3260"
   $firstNode.HBInterface = "#p2=192.168.100.56:3260"
   $firstNode.PoolName = ""
   $firstNode.SectorSize = 512
   $secondNode = new-Object Node
   $secondNode.HostName = "192.168.1.56"
   $secondNode.HostPort = "3261"
   $secondNode.Login = "root"
   $secondNode.ImagePath = "/mnt/disk1"
   $secondNode.ImageName = "img2"
   $secondNode.Size = 1300234
   $secondNode.TargetAlias = "partnerHA2"
   $secondNode.AutoSynch = $true
   $secondNode.SyncInterface = "#p1=192.168.99.55:3260"
   $secondNode.HBInterface = "#p1=192.168.100.55:3260"
      Start-Sleep -m 2000
      $device.Refresh()
catch
   Write-Host $_ -foreground red
finally
   $server.Disconnect()
Any help is appreciated.
Thanks.
jep
Postby Oleg(staff) » Wed Feb 27, 2019 4:56 pm
Could you please log a support case using this form?
Please refer to this thread.
Oleg(staff)
Return to StarWind Virtual SAN / StarWind Virtual SAN Free / StarWind HyperConverged Appliance / StarWind Storage Appliance
Who is online
Users browsing this forum: Google [Bot] and 6 guests
