vVol creatiion on VSAN Free
DataBitz
Thu Feb 21, 2019 2:52 am
I'm looking for some guidance about how to create a vVol using Powershell on VSAN free.
Based on what can be done in the UI, it looks like there should be an option with the New-Target command to specify a type of vVol.
UI reference.
https://www.starwindsoftware.com/resour ... view-guide
These are the options I see.
SYNTAX
    New-Target [-server] <Object> [-alias] <String> [[-name] <String>] [[-devices] <String[]>] [[-clustered]
    <String>] [<CommonParameters>]
Oleg(staff)
Thu Feb 21, 2019 9:36 am
Unfortunately, VVols configuration is not available via StarWindX library.
Sekkmer
Tue Feb 26, 2019 10:26 am
IStarwindServer has a method:
CreateTarget(string targetAlias, string TargetName, Parameters builder)
You have to build your parameters for vvols:
$param.AppendParam("targetType", "vvols")
The other parameter which can be set is "clustered" which can be "Yes" or " No"
TargetName can be an empty string.
Oleg(staff)
Tue Feb 26, 2019 11:27 am
Sekkmer,
Thank you for your findings.
