SDC
Mon Jan 28, 2019 4:28 pm
Hi Guys,
Just reinstalled 2 new nodes with Server 2016. Only added to AD and installed MPIO.
Software installs fine
Heartbeat - 1GB direct link between both nodes
Sync - 10Gb direct Link
Image files are created fine, but both Sync and Heartbeat channels then refuse to come up on both nodes. I then reinstalled the Operating system and installed 2012R2 and receive the same issue. This all worked on these nodes before with no issues. The only difference this time is I am running a Server 2016 Active Directory domain.
Running build V8.0.0 (12658).
I can run various traffic over the heartbeat and sync channels just to test they were working fine.
Any thoughts?
SDC
Tue Jan 29, 2019 8:58 am
For the 1Gbps NICs we use the on-board Broadcom NetXtreme cards on the Dell R720 in use.
For the 10Gbps NIC we use Tehutin Networks TN9510 card.
Mnay Thanks
SDC
Tue Jan 29, 2019 9:39 am
Hi Oleg,
No Jumbo frames have not been enabled. Over night I just reinstalled the nodes with Server 2012 R2 and recieve the same issue.
Many Thanks
Adrian
Oleg(staff)
Tue Jan 29, 2019 10:13 am
Hi Adrian,
Please try to rename iSER_DM.dll file.
Stop the StarWind service on the node, locate the iSER_DM.dll file in the StarWind installation folder and rename it (e.g. to iSER_DM.dll.bak). Start the StarWind service again and do the same on another node.
SDC
Tue Jan 29, 2019 10:29 am
Hi Oleg,
Have done as requested.
On the first node, It was showing the device, but not as a HA device
On the second node, it is showing it as a HA device with the links down.
I have removed and just tried to recreate the device. It is now created on Node 2, but nothing on Node 1. When runnning the powershell script i now receive the following error:
Exception calling "CreateDevice" with "4" argument(s): "Plugin is not supported"
Adrian
SDC
Tue Jan 29, 2019 11:50 am
Fixed the error with plugin not supported by reinstalling StarwindsX and Microsoft Visual C++ 2015 Redistributable.
SDC
Tue Jan 29, 2019 2:29 pm
Hi Boris,
My last updated was only related to the plugin error I received. I still can't get the syncing to work.
Adrian
Tue Jan 29, 2019 4:14 pm
What kind of error is reported now that you have reinstalled StarWindX? Is it possible for you to redo the device creation from scratch and check the result?
SDC
Wed Feb 13, 2019 2:14 pm
Hi Boris,
Sorry have been working away for a while. I've come back and done a clean install again of everything and still the same issue. Can I send over the log files please?
Many Thanks
Adrian
SDC
Wed Feb 13, 2019 2:45 pm
Hi Boris,
I found the issue will help of one of your technical documents on your site.
Many Thanks
Adrian
