I Have a suggestion
jm5423
Fri Nov 11, 2005 2:28 am
One Img File, Initiator Use "anymous" as username to Connect
Readonly ie "yes"
IF a Initiator User Like "Admin" to connect
it's change can be save,That is to say readonly is no
Val (staff)
Fri Nov 11, 2005 10:10 am
jm5423 wrote:One Img File, Initiator Use "anymous" as username to Connect
Readonly ie "yes"
Thank you for the suggestion.
But it seems to be some out of scope of the iSCSI specification.
We'll think about including the feature in one of the next releases.
Valeriy
