Deleted CSV1.img off 3rd node. How do I resync?
chezro
Mon Dec 31, 2018 8:31 pm
I accidentally deleted my csv off the third node in my cluster. All the storage is fine on the other nodes and I've already paused and stopped the cluster service and starwind on node 3 however when I try to resync I get:
PS C:\Windows\system32> C:\Program Files\StarWind Software\StarWind\StarWindX\Samples\powershell\SyncHaDevice.ps1
Synchronize device HAImage1
Failed to perform synchronization (1) from
Not sure which script to proceed from at this point.
I am currently syncing 2 disks on 3 nodes (should've been 3 I know). CSV1 is shared across all three but is working for my purposes.
I need to either resync node three or remove it from the deployment and just use the other two and re-purpose the node for something else.
Any help would be appreciated.
Thu Jan 03, 2019 12:15 am
When deleting .img, did you delete both .swdsk files?
