I'm putting together a 2-Node Hyper-converged Hyper-V Cluster using V San Free.
I have x2 1GB Management/Access interfaces and x2 10GB Interfaces on QLogic cards.
I have used 2016's Switch Embedded Teaming on both sets of interfaces. The 10GB interfaces are patched direct between servers with no in between devices with SM fiber. From this vSwitch I created 3 Virtual adapters on the ManagementOS side, (Heartbeat, "Storage" Sync Channel, VM Live-Migration) each on separate subnets. I created two HA vDisks using the Heartbeat/Sync Interfaces/Subnets.
Is it even possible or advisable to use MPIO under this setup?
-On a side note does anyone know where the setting for jumbo packets is on QLogic cards?
-Thanks
