Hi All,
can any one explain following will be enough for Hyper V Fail-over Configuration for Production Implementation
1. Star-wind Free SAN
2. Two Network Adapters
3. Gigabit Switch with 1Gbps Throughput
Currently what is happening was if I shutdown one Node ,fail over its not working . but if I manually down cluster service or Test failure using Cluster Manager i can see its working , So i want to figured out where is the root cause. this cluster is running on Work group.
Thanks & Regards,
Amith Prasanna
