Hi all,
I've managed to configure 2 node Fail-over cluster on Windows Server 2016 , but without domain .behalf of DNS I've added DNS Suffix and added Host Records on each server.
there were only 2 NIC s , so 2 NIC assigned as NIC1 for Heart Beat and other one NIC2 for Synchronization.
But I'm having issues like below,
When I've down Cluster service only from Cluster manager its working but if i shutdown or when I'm remove both of Cables it doesn't work and I cant see Hyper V VM in either server.
then when I go to Star-wind management console and then i can see my CSV with yellow Exclamation mark , when I select Mark as Synchronized then it will perform full syny then after that its working fine .
is that limitation of Free version or am I missing some thing , Do I need Seperate Network switch for Heart Beat ?
thanks ,
AP
