iSER on Virtual SAN free
seowbin
Mon Dec 10, 2018 5:36 am
First, i encountered problem to enable iSER on the free version since "modify/add" options are not available from the management interface.
Long story short, i got it turn on now but facing errors.
iSCSI works well when switching to RoCE it fails with the following errors.
The esxi server and windows nas , both are using mellanox connectx-3 interface, it should supports ROCE v1 (and v1.5) only.
When set to RoCE v1 using Set-MlnxDriverCoreSetting -RoceMode 1
12/10 13:16:43.386 13c0 iSER: iSerDmSocket::InitQueues: Created QueuePair (recv 264, init 1056, cq 1320, group 0, affinity 0x3).
12/10 13:16:43.386 13c0 iSER: iSerDmSocket::Accept: iSER: Accept: using Ird = 0, Ord = 16.
12/10 13:16:43.386 13c0 iSER: *** iSerDmSocket::Accept: IND2Connector::Accept failed with c000009a
12/10 13:16:43.386 13c0 iSER: *** iSerDmServerSocket::Accept: Socket::Accept failed with c000009a
12/10 13:16:43.386 13c0 Srv: iScsiServer::listenConnections: Accepted iSER connection from 10.10.10.1:41688 to 10.10.10.20:3260. (Id = 0x1)
12/10 13:16:43.386 13c0 S[1]: iScsiSession::iScsiSession: Session (00000224D752E0C0)
12/10 13:16:43.386 13c0 C[1], FREE: iScsiConnection::doTransition: Event - CONNECTED.
12/10 13:16:43.386 13c0 C[1], XPT_UP: iScsiConnection::fsmT3: T3.
12/10 13:16:43.386 13c0 Srv: iScsiServer::listenConnections: Accepted iSER connection from 10.10.10.1:41689 to 10.10.10.20:3260. (Id = 0x2)
12/10 13:16:43.386 13c0 S[2]: iScsiSession::iScsiSession: Session (00000224D72B0FC0)
12/10 13:16:43.386 13c0 C[2], FREE: iScsiConnection::doTransition: Event - CONNECTED.
12/10 13:16:43.386 13c0 C[2], XPT_UP: iScsiConnection::fsmT3: T3.
From ESXi vmkernel.log
2018-12-10T05:16:43.396Z cpu16:2098053)iser: iser_EPConnect: src ipv4 10.10.10.1
2018-12-10T05:16:43.396Z cpu16:2098053)iser: iser_EPConnect: dst ipv4 10.10.10.20
2018-12-10T05:16:43.396Z cpu16:2098053)WARNING: rdmaDriver: RDMAGetValidGidType:1896: Protocol not supported by device
2018-12-10T05:16:43.396Z cpu16:2098053)WARNING: rdmaDriver: RDMACM_BindLegacy:3290: Underlying device does not support requested gid/RoCE type. Failed with status: Protocol not supported
2018-12-10T05:16:43.397Z cpu9:2097736)iser: iser_RDMACMEventHandler: iser conn 0x430b457dfce0 cm event 0
2018-12-10T05:16:43.397Z cpu16:2098053)iser: iser_EPConnect: src ipv4 10.10.10.1
2018-12-10T05:16:43.397Z cpu16:2098053)iser: iser_EPConnect: dst ipv4 10.10.10.20
2018-12-10T05:16:43.397Z cpu16:2098053)WARNING: rdmaDriver: RDMAGetValidGidType:1896: Protocol not supported by device
2018-12-10T05:16:43.397Z cpu16:2098053)WARNING: rdmaDriver: RDMACM_BindLegacy:3290: Underlying device does not support requested gid/RoCE type. Failed with status: Protocol not supported
2018-12-10T05:16:43.398Z cpu16:2098053)Binding for id: 0x430b457e26a0 exists, increment refcount
2018-12-10T05:16:43.398Z cpu16:2098053)WARNING: rdmaDriver: RDMACM_BindLegacy:3307: RDMA CM Binding already exists.
2018-12-10T05:16:43.398Z cpu19:2097784)iser: iser_RDMACMEventHandler: iser conn 0x430b457dfce0 cm event 2
2018-12-10T05:16:43.398Z cpu9:2097736)iser: iser_RDMACMEventHandler: iser conn 0x430b457e13c0 cm event 0
2018-12-10T05:16:43.399Z cpu19:2097784)iser: iser_ComplSlabInit: min 0 max 41048
2018-12-10T05:16:43.399Z cpu19:2097784)iser: iser_RouteResolvedHandler: iser conn: 0x430b457dfce0 uplink: vmnic4
2018-12-10T05:16:43.399Z cpu19:2097784)iser: iser_RDMACMEventHandler: iser conn 0x430b457e13c0 cm event 2
2018-12-10T05:16:43.399Z cpu21:2104896)iser: iser_DisconnectWorld: 0x430b457dfce0 iser conn disconnect world init
2018-12-10T05:16:43.400Z cpu19:2097784)iser: iser_ComplSlabInit: min 0 max 41048
2018-12-10T05:16:43.400Z cpu19:2097784)iser: iser_RouteResolvedHandler: iser conn: 0x430b457e13c0 uplink: vmnic4
2018-12-10T05:16:43.400Z cpu6:2104897)iser: iser_DisconnectWorld: 0x430b457e13c0 iser conn disconnect world init
2018-12-10T05:16:43.649Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:43.652Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:43.908Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:43.911Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:44.398Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:44.401Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:44.657Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:44.660Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:44.915Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:44.918Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:45.399Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:45.402Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:45.658Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:45.661Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:45.914Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:45.917Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:46.403Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:46.405Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:46.660Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:46.664Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:46.919Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:46.922Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:47.405Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:47.408Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:47.663Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:47.667Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:47.922Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:47.925Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:48.408Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:48.411Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:48.666Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:48.669Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:48.924Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:48.927Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:49.410Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:49.413Z cpu16:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:16:49.668Z cpu16:2098053)iser: iser_EPDisconnect: transport 0x430b457dfa00 ep 0x430b457dfce0
2018-12-10T05:16:49.668Z cpu16:2098053)iser: iser_EPDisconnect: Waiting for QP to transition to error state ...
2018-12-10T05:16:49.678Z cpu16:2098053)iser: iser_FreeIbConnRes: freeing iser_conn 0x430b457dfce0 ib resources
2018-12-10T05:16:49.734Z cpu21:2104896)iser: iser_DisconnectWorld: 0x430b457dfce0 iser conn disconnect world wake up: World is marked for death
2018-12-10T05:16:49.734Z cpu21:2104896)iser: iser_DisconnectWorld: 0x430b457dfce0 disconnect world wokeup
2018-12-10T05:16:49.736Z cpu16:2098053)iser: iser_EPDisconnect: transport 0x430b457dfa00 ep 0x430b457e13c0
2018-12-10T05:16:49.736Z cpu16:2098053)iser: iser_EPDisconnect: Waiting for QP to transition to error state ...
2018-12-10T05:16:49.746Z cpu16:2098053)iser: iser_FreeIbConnRes: freeing iser_conn 0x430b457e13c0 ib resources
2018-12-10T05:16:49.804Z cpu6:2104897)iser: iser_DisconnectWorld: 0x430b457e13c0 iser conn disconnect world wake up: World is marked for death
2018-12-10T05:16:49.804Z cpu6:2104897)iser: iser_DisconnectWorld: 0x430b457e13c0 disconnect world wokeup
seowbin
Mon Dec 10, 2018 5:42 am
When set to RoCE v1 using Set-MlnxDriverCoreSetting -RoceMode 2
2/10 13:22:27.061 13c iSER: iSerDmSocket::InitQueues: Created QueuePair (recv 264, init 1056, cq 1320, group 0, affinity 0x3).
12/10 13:22:27.061 13c iSER: iSerDmSocket::Accept: iSER: Accept: using Ird = 0, Ord = 16.
12/10 13:22:33.592 13c iSER: *** iSerDmSocket::Accept: IND2Connector::Accept failed with c0000241
12/10 13:22:33.592 13c iSER: *** iSerDmServerSocket::Accept: Socket::Accept failed with c0000241
12/10 13:22:33.592 13c Srv: iScsiServer::listenConnections: Accepted iSER connection from 10.10.10.1:41694 to 10.10.10.20:3260. (Id = 0x1)
12/10 13:22:33.592 13c S[1]: iScsiSession::iScsiSession: Session (000001D397F9CFC0)
12/10 13:22:33.592 13c C[1], FREE: iScsiConnection::doTransition: Event - CONNECTED.
12/10 13:22:33.592 13c C[1], XPT_UP: iScsiConnection::fsmT3: T3.
12/10 13:22:33.592 a58 iSER: iSerDmSocket::Recv: InCq->GetResults: Recv has failed with c0000120
12/10 13:22:33.592 a58 C[1], XPT_UP: iScsiConnection::receive: recvData returned 3221225760 (0xc0000120)!
12/10 13:22:33.592 a58 C[1], XPT_UP: iScsiConnection::recvWorker: *** 'recv' thread: recv failed 10058.
12/10 13:22:33.592 13c iSER: iSerDmSocket::InitQueues: Created QueuePair (recv 264, init 1056, cq 1320, group 0, affinity 0x3).
12/10 13:22:33.592 13c iSER: iSerDmSocket::Accept: iSER: Accept: using Ird = 0, Ord = 16.
12/10 13:22:33.623 13c iSER: *** iSerDmSocket::Accept: IND2Connector::Accept failed with c0000241
12/10 13:22:33.623 13c iSER: *** iSerDmServerSocket::Accept: Socket::Accept failed with c0000241
12/10 13:22:33.623 13c Srv: iScsiServer::listenConnections: Accepted iSER connection from 10.10.10.1:41695 to 10.10.10.20:3260. (Id = 0x2)
12/10 13:22:33.623 13c S[2]: iScsiSession::iScsiSession: Session (000001D397FB8880)
12/10 13:22:33.623 13c C[2], FREE: iScsiConnection::doTransition: Event - CONNECTED.
12/10 13:22:33.623 13c C[2], XPT_UP: iScsiConnection::fsmT3: T3.
12/10 13:22:33.623 cdc iSER: iSerDmSocket::Recv: InCq->GetResults: Recv has failed with c0000120
12/10 13:22:33.623 cdc C[2], XPT_UP: iScsiConnection::receive: recvData returned 3221225760 (0xc0000120)!
12/10 13:22:33.623 cdc C[2], XPT_UP: iScsiConnection::recvWorker: *** 'recv' thread: recv failed 10058.
12/10 13:22:33.655 1008 S[1]: iScsiSession::~iScsiSession: ~Session
12/10 13:22:33.686 b84 S[2]: iScsiSession::~iScsiSession: ~Session
From ESXi vmkernal.log
2018-12-10T05:22:27.072Z cpu20:2098053)iser: iser_EPConnect: src ipv4 10.10.10.1
2018-12-10T05:22:27.073Z cpu20:2098053)iser: iser_EPConnect: dst ipv4 10.10.10.20
2018-12-10T05:22:27.073Z cpu20:2098053)WARNING: rdmaDriver: RDMAGetValidGidType:1896: Protocol not supported by device
2018-12-10T05:22:27.073Z cpu20:2098053)WARNING: rdmaDriver: RDMACM_BindLegacy:3290: Underlying device does not support requested gid/RoCE type. Failed with status: Protocol not supported
2018-12-10T05:22:27.074Z cpu9:2097736)iser: iser_RDMACMEventHandler: iser conn 0x430b457dfce0 cm event 0
2018-12-10T05:22:27.074Z cpu20:2098053)iser: iser_EPConnect: src ipv4 10.10.10.1
2018-12-10T05:22:27.074Z cpu20:2098053)iser: iser_EPConnect: dst ipv4 10.10.10.20
2018-12-10T05:22:27.074Z cpu20:2098053)WARNING: rdmaDriver: RDMAGetValidGidType:1896: Protocol not supported by device
2018-12-10T05:22:27.074Z cpu20:2098053)WARNING: rdmaDriver: RDMACM_BindLegacy:3290: Underlying device does not support requested gid/RoCE type. Failed with status: Protocol not supported
2018-12-10T05:22:27.074Z cpu20:2098053)Binding for id: 0x430b457e26a0 exists, increment refcount
2018-12-10T05:22:27.074Z cpu20:2098053)WARNING: rdmaDriver: RDMACM_BindLegacy:3307: RDMA CM Binding already exists.
2018-12-10T05:22:27.074Z cpu19:2097784)iser: iser_RDMACMEventHandler: iser conn 0x430b457dfce0 cm event 2
2018-12-10T05:22:27.074Z cpu9:2097736)iser: iser_RDMACMEventHandler: iser conn 0x430b457e13c0 cm event 0
2018-12-10T05:22:27.075Z cpu19:2097784)iser: iser_ComplSlabInit: min 0 max 41048
2018-12-10T05:22:27.075Z cpu19:2097784)iser: iser_RouteResolvedHandler: iser conn: 0x430b457dfce0 uplink: vmnic4
2018-12-10T05:22:27.076Z cpu0:2104976)iser: iser_DisconnectWorld: 0x430b457dfce0 iser conn disconnect world init
2018-12-10T05:22:27.076Z cpu19:2097784)iser: iser_RDMACMEventHandler: iser conn 0x430b457e13c0 cm event 2
2018-12-10T05:22:27.077Z cpu19:2097784)iser: iser_ComplSlabInit: min 0 max 41048
2018-12-10T05:22:27.077Z cpu19:2097784)iser: iser_RouteResolvedHandler: iser conn: 0x430b457e13c0 uplink: vmnic4
2018-12-10T05:22:27.077Z cpu6:2104977)iser: iser_DisconnectWorld: 0x430b457e13c0 iser conn disconnect world init
2018-12-10T05:22:27.326Z cpu20:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:27.329Z cpu20:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:27.585Z cpu20:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:27.588Z cpu20:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:28.074Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:28.077Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:28.332Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:28.335Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:28.591Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:28.594Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:29.076Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:29.080Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:29.335Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:29.338Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:29.593Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:29.596Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:30.079Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:30.082Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:30.337Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:30.340Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:30.595Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:30.598Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:31.079Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:31.083Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:31.338Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:31.341Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:31.596Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:31.599Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:32.082Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:32.085Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:32.340Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:32.343Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:32.598Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:32.601Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:33.084Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:33.087Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:33.342Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457dfce0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:33.346Z cpu14:2098053)iser: iser_EPPoll: Polling ep/iser_conn 0x430b457e13c0 transport 0x430b457dfa00 timeoutMS 1
2018-12-10T05:22:33.601Z cpu14:2098053)iser: iser_EPDisconnect: transport 0x430b457dfa00 ep 0x430b457dfce0
2018-12-10T05:22:33.601Z cpu14:2098053)iser: iser_EPDisconnect: Waiting for QP to transition to error state ...
2018-12-10T05:22:33.611Z cpu14:2098053)iser: iser_FreeIbConnRes: freeing iser_conn 0x430b457dfce0 ib resources
2018-12-10T05:22:33.621Z cpu5:2104976)iser: iser_DisconnectWorld: 0x430b457dfce0 iser conn disconnect world wake up: World is marked for death
2018-12-10T05:22:33.621Z cpu5:2104976)iser: iser_DisconnectWorld: 0x430b457dfce0 disconnect world wokeup
2018-12-10T05:22:33.623Z cpu14:2098053)iser: iser_EPDisconnect: transport 0x430b457dfa00 ep 0x430b457e13c0
2018-12-10T05:22:33.623Z cpu14:2098053)iser: iser_EPDisconnect: Waiting for QP to transition to error state ...
2018-12-10T05:22:33.633Z cpu14:2098053)iser: iser_FreeIbConnRes: freeing iser_conn 0x430b457e13c0 ib resources
2018-12-10T05:22:33.644Z cpu6:2104977)iser: iser_DisconnectWorld: 0x430b457e13c0 iser conn disconnect world wake up: World is marked for death
2018-12-10T05:22:33.644Z cpu6:2104977)iser: iser_DisconnectWorld: 0x430b457e13c0 disconnect world wokeup
Oleg(staff)
Tue Dec 11, 2018 2:10 pm
Please check this article. Also Mellanox lossless configuration should be done.
march
Tue Jul 30, 2019 1:12 pm
Is there anyone that solved this issue with iSer/RoceV1
Marc
Thu Aug 01, 2019 7:21 pm
march,
As we do not see any reply from the topic starter, most likely the issue has been resolved.
If you seem to have a similar one, it may be a good idea to describe your issue, possibly within a new thread for us to take care of it.
