CHAP issue with VMware 6.5
bertram
Sun Dec 09, 2018 1:13 pm
I need some assist with setting up CHAP with Stawind v8_12658 and VMware 6.5. I've set a golbal CHAP PERMISSION (user & secret, 16 chars a-Z,0-9, no mutal) in starwind. When I try to connect with VMware I can't get authenticated. You can assume that I do not have used a mismatched secret!
Further I don't have set an explicit CHAP challange at target level because I assume it's inherited from the global CHAP PERMISSION (Note: I would prefer a hint in starwind at the target level that a CHAP is inherited instead of show "no chap configured").
Below are the results from 3 CHAP authentication methods in VMware 6.5.
If I set no CHAP nothing happens at all. I can't see any errors in the starwind log (e.g. missing CHAP). Anyway, no storage device is detected in VMware.
If I set to use CHAP if requried starind accepts "none" instead of "CHAP" but then states an error because authentication is required. (???)
If I set prefer CHAP I get the error that Authentication failed. Wrong response returned.
Could someone explain this behaviour?
### VMware NO CHAP ###
12/9 12:42:00.118 1e0 Srv: iScsiServer::listenConnections: Accepted iSCSI connection from 172.16.1.5:45950 to 172.16.1.150:3260. (Id = 0x2f8)
12/9 12:42:00.118 1e0 S[2f8]: iScsiSession::iScsiSession: Session (000000FCEE829E40)
12/9 12:42:00.118 1e0 C[2f8], FREE: iScsiConnection::doTransition: Event - CONNECTED.
12/9 12:42:00.118 1e0 C[2f8], XPT_UP: iScsiConnection::fsmT3: T3.
12/9 12:42:00.118 8dc C[2f8], XPT_UP: iScsiConnection::handleFirstLogin: Login request: ISID 0x00023d000000, TSIH 0x0000.
12/9 12:42:00.118 8dc C[2f8], XPT_UP: iScsiConnection::doTransition: Event - LOGIN.
12/9 12:42:00.118 8dc C[2f8], IN_LOGIN: iScsiConnection::fsmT4: T4.
12/9 12:42:00.118 8dc Params: iScsiParameter::update: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:esx-rz05-2cd6406f', accepted 'iqn.1998-01.com.vmware:esx-rz05-2cd6406f'
12/9 12:42:00.118 8dc Params: iScsiParameter::update: <<< String param 'InitiatorAlias': received 'esx-rz05', accepted 'esx-rz05'
12/9 12:42:00.118 8dc Params: iScsiParameter::update: <<< Enum param 'SessionType': received 'Discovery', accepted 'Discovery'
12/9 12:42:00.118 8dc Params: iScsiParameter::update: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
12/9 12:42:00.118 8dc Params: iScsiParameter::update: <<< Enum param 'DataDigest': received 'None', accepted 'None'
12/9 12:42:00.118 8dc Params: iScsiParameter::update: <<< Numeric param 'DefaultTime2Wait': received 0, accepted 0
12/9 12:42:00.118 8dc Params: iScsiParameter::update: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
12/9 12:42:00.118 8dc Params: iScsiParameter::update: <<< Boolean param 'IFMarker': received No, accepted 0
12/9 12:42:00.118 8dc Params: iScsiParameter::update: <<< Boolean param 'OFMarker': received No, accepted 0
12/9 12:42:00.118 8dc Params: iScsiParameter::update: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
12/9 12:42:00.118 8dc Params: iScsiParameter::update: <<< Numeric param 'MaxRecvDataSegmentLength': received 32768, accepted 32768
12/9 12:42:00.118 8dc Params: iScsiParams::createKeys: >>> ErrorRecoveryLevel=0.
12/9 12:42:00.118 8dc Params: iScsiParams::createKeys: >>> HeaderDigest=None.
12/9 12:42:00.118 8dc Params: iScsiParams::createKeys: >>> DataDigest=None.
12/9 12:42:00.118 8dc Params: iScsiParams::createKeys: >>> OFMarker=No.
12/9 12:42:00.118 8dc Params: iScsiParams::createKeys: >>> IFMarker=No.
12/9 12:42:00.118 8dc Params: iScsiParams::createKeys: >>> MaxRecvDataSegmentLength=262144.
12/9 12:42:00.118 8dc Params: iScsiParams::createKeys: >>> DefaultTime2Wait=0.
12/9 12:42:00.118 8dc Params: iScsiParams::createKeys: >>> DefaultTime2Retain=0.
12/9 12:42:00.118 1030 T[2f8,1]: iScsiTask::execLoginReq: session 0x2f8, connection 0x2f8 : end of stage 1, next stage 3.
12/9 12:42:00.118 1030 C[2f8], IN_LOGIN: iScsiConnection::doTransition: Event - LOGIN_ACCEPT.
12/9 12:42:00.118 1030 C[2f8], LIN: iScsiConnection::fsmT5: T5.
12/9 12:42:00.118 8dc Params: iScsiParameter::update: <<< String param 'SendTargets': received 'All', accepted 'All'
12/9 12:42:00.118 8dc Srv: iScsiServer::sendTargets: <no target>: 'SendTargets=All' for a Discovery session...
### VMware CHAP IF REQUIRED ###
12/9 12:46:08.690 1e0 Srv: iScsiServer::listenConnections: Accepted iSCSI connection from 172.16.1.5:44968 to 172.16.1.150:3260. (Id = 0x2fa)
12/9 12:46:08.690 1e0 S[2fa]: iScsiSession::iScsiSession: Session (000000FE1F9B3400)
12/9 12:46:08.690 1e0 C[2fa], FREE: iScsiConnection::doTransition: Event - CONNECTED.
12/9 12:46:08.690 1e0 C[2fa], XPT_UP: iScsiConnection::fsmT3: T3.
12/9 12:46:08.690 324 C[2fa], XPT_UP: iScsiConnection::handleFirstLogin: Login request: ISID 0x00023d000000, TSIH 0x0000.
12/9 12:46:08.690 324 C[2fa], XPT_UP: iScsiConnection::doTransition: Event - LOGIN.
12/9 12:46:08.690 324 C[2fa], IN_LOGIN: iScsiConnection::fsmT4: T4.
12/9 12:46:08.690 324 Params: iScsiParameter::update: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:esx-rz05-2cd6406f', accepted 'iqn.1998-01.com.vmware:esx-rz05-2cd6406f'
12/9 12:46:08.690 324 Params: iScsiParameter::update: <<< String param 'InitiatorAlias': received 'esx-rz05', accepted 'esx-rz05'
12/9 12:46:08.690 324 Params: iScsiParameter::update: <<< Enum param 'SessionType': received 'Discovery', accepted 'Discovery'
12/9 12:46:08.690 324 Params: iScsiParameter::update: <<< Enum param 'AuthMethod': received 'None,CHAP', accepted 'None'
12/9 12:46:08.690 324 Params: iScsiParams::createKeys: >>> AuthMethod=None.
12/9 12:46:08.690 11a8 T[2fa,1]: iScsiTask::execLoginReq: session 0x2fa, connection 0x2fa : end of stage 0, next stage 1.
12/9 12:46:08.690 324 Params: iScsiParameter::update: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
12/9 12:46:08.690 324 Params: iScsiParameter::update: <<< Enum param 'DataDigest': received 'None', accepted 'None'
12/9 12:46:08.690 324 Params: iScsiParameter::update: <<< Numeric param 'DefaultTime2Wait': received 0, accepted 2
12/9 12:46:08.690 324 Params: iScsiParameter::update: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
12/9 12:46:08.690 324 Params: iScsiParameter::update: <<< Boolean param 'IFMarker': received No, accepted 0
12/9 12:46:08.690 324 Params: iScsiParameter::update: <<< Boolean param 'OFMarker': received No, accepted 0
12/9 12:46:08.690 324 Params: iScsiParameter::update: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
12/9 12:46:08.690 324 Params: iScsiParameter::update: <<< Numeric param 'MaxRecvDataSegmentLength': received 32768, accepted 32768
12/9 12:46:08.690 324 Params: iScsiParams::createKeys: >>> ErrorRecoveryLevel=0.
12/9 12:46:08.690 324 Params: iScsiParams::createKeys: >>> HeaderDigest=None.
12/9 12:46:08.690 324 Params: iScsiParams::createKeys: >>> DataDigest=None.
12/9 12:46:08.690 324 Params: iScsiParams::createKeys: >>> OFMarker=No.
12/9 12:46:08.690 324 Params: iScsiParams::createKeys: >>> IFMarker=No.
12/9 12:46:08.690 324 Params: iScsiParams::createKeys: >>> MaxRecvDataSegmentLength=8192.
12/9 12:46:08.690 324 Params: iScsiParams::createKeys: >>> DefaultTime2Wait=2.
12/9 12:46:08.690 324 Params: iScsiParams::createKeys: >>> DefaultTime2Retain=0.
12/9 12:46:08.690 11a8 T[2fa,1]: iScsiTask::execLoginReq: session 0x2fa, connection 0x2fa : end of stage 1, next stage 3.
12/9 12:46:08.690 11a8 C[2fa], IN_LOGIN: iScsiConnection::doTransition: Event - LOGIN_ACCEPT.
12/9 12:46:08.690 11a8 C[2fa], LIN: iScsiConnection::fsmT5: T5.
12/9 12:46:08.690 324 Params: iScsiParameter::update: <<< String param 'SendTargets': received 'All', accepted 'All'
12/9 12:46:08.690 324 Srv: iScsiServer::sendTargets: <no target>: 'SendTargets=All' for a Discovery session...
12/9 12:46:08.690 11a8 C[2fa], LIN: iScsiConnection::doTransition: Event - LOGOUT.
12/9 12:46:08.690 11a8 C[2fa], IN_LOGOUT: iScsiConnection::fsmT9T10: T9/10.
12/9 12:46:08.690 111c C[2fa], IN_LOGOUT: iScsiConnection::doTransition: Event - LOGOUT_ACCEPT.
12/9 12:46:08.690 111c C[2fa], CLEANUP_WAIT: iScsiConnection::fsmT13: T13.
12/9 12:46:08.690 324 Sw: *** Swn_SocketRecv: WSARecv() failed with error 10054 (0x2746)!
12/9 12:46:08.690 324 Srv: *** SwSocket::Recv: Swn_SocketRecv() failed with error 10054 (0x2746)!
12/9 12:46:08.690 324 C[2fa], CLEANUP_WAIT: iScsiConnection::receive: recvData returned 10054 (0x2746)!
12/9 12:46:08.690 11a8 S[2fa]: iScsiSession::~iScsiSession: ~Session
12/9 12:46:08.705 1e0 Srv: iScsiServer::listenConnections: Accepted iSCSI connection from 172.16.1.5:11614 to 172.16.1.150:3260. (Id = 0x2fb)
12/9 12:46:08.705 1e0 S[2fb]: iScsiSession::iScsiSession: Session (000000FE1F9B2E40)
12/9 12:46:08.705 1e0 C[2fb], FREE: iScsiConnection::doTransition: Event - CONNECTED.
12/9 12:46:08.705 1e0 C[2fb], XPT_UP: iScsiConnection::fsmT3: T3.
12/9 12:46:08.955 614 C[2fb], XPT_UP: iScsiConnection::handleFirstLogin: Login request: ISID 0x00023d000003, TSIH 0x0000.
12/9 12:46:08.955 614 C[2fb], XPT_UP: iScsiConnection::doTransition: Event - LOGIN.
12/9 12:46:08.955 614 C[2fb], IN_LOGIN: iScsiConnection::fsmT4: T4.
12/9 12:46:08.955 614 Params: iScsiParameter::update: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:esx-rz05-2cd6406f', accepted 'iqn.1998-01.com.vmware:esx-rz05-2cd6406f'
12/9 12:46:08.955 614 Params: iScsiParameter::update: <<< String param 'InitiatorAlias': received 'esx-rz05', accepted 'esx-rz05'
12/9 12:46:08.955 614 Params: iScsiParameter::update: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:san-rz01.bex.lan-san-rz-lun01', accepted 'iqn.2008-08.com.starwindsoftware:san-rz01.bex.lan-san-rz-lun01'
12/9 12:46:08.955 614 Params: iScsiParameter::update: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
12/9 12:46:08.955 614 Params: iScsiParameter::update: <<< Enum param 'AuthMethod': received 'None,CHAP', accepted 'None'
12/9 12:46:08.955 614 HA: CHADevice::register_session: Client initiator iqn.1998-01.com.vmware:esx-rz05-2cd6406f is trying to register a session within the 'iqn.2008-08.com.starwindsoftware:san-rz01.bex.lan-san-rz-lun01' target... (sessId = 0x2fb, initiatorNameIsid = iqn.1998-01.com.vmware:esx-rz05-2cd6406f,00023D000003)
12/9 12:46:08.955 614 HA: CHADevice::register_session: Client session (IP: "172.16.1.5"; Initiator: "iqn.1998-01.com.vmware:esx-rz05-2cd6406f") has been allowed!
12/9 12:46:08.955 614 HA: CHADevice::register_session: Registering the external client session.
12/9 12:46:08.955 614 PR: ResLunSessionEngine::registerSession: LUN 0: existing record for session 0x2fb from iqn.1998-01.com.vmware:esx-rz05-2cd6406f,00023D000003 iqn.2008-08.com.starwindsoftware:san-rz01.bex.lan-san-rz-lun01
12/9 12:46:08.955 614 PR: ResLunSession::setUnitAttention: Set UA 0x2901 (0x0) for session 0x2fb from iqn.1998-01.com.vmware:esx-rz05-2cd6406f,00023D000003.
12/9 12:46:08.955 614 ScsiFlt: ALUA_Filter::register_session: registering session 0x2fb
12/9 12:46:08.955 614 HA: CHADevice::register_session: Return code 0.
12/9 12:46:08.955 614 Tgt: iScsiTarget::openSession: open 'iqn.2008-08.com.starwindsoftware:san-rz01.bex.lan-san-rz-lun01': 5 session(s) opened, 65531 more allowed.
12/9 12:46:08.955 614 T[2fb,1]: ***iScsiTask::handleAuth: *ERROR* Authentication required.
12/9 12:46:08.955 11a4 C[2fb], IN_LOGIN: iScsiConnection::doTransition: Event - LOGIN_REJECT.
12/9 12:46:08.955 11a4 C[2fb], IN_LOGIN: iScsiConnection::fsmT7: T7.
12/9 12:46:09.221 614 C[2fb], IN_LOGIN: iScsiConnection::receive: recvData returned 10058 (0x274a)!
12/9 12:46:09.221 5a8 HA: CHADevice::unregister_session: Client initiator iqn.1998-01.com.vmware:esx-rz05-2cd6406f has unregistered a session.
12/9 12:46:09.221 5a8 ScsiFlt: ALUA_Filter::unregister_session: unregistering session 0x2fb
12/9 12:46:09.221 5a8 Tgt: iScsiTarget::closeSession: close 'iqn.2008-08.com.starwindsoftware:san-rz01.bex.lan-san-rz-lun01': 4 session(s) opened, 65532 more allowed.
12/9 12:46:09.221 5a8 S[2fb]: iScsiSession::~iScsiSession: ~Session
### VMware CHAP PREFERED ###
12/9 12:51:53.144 1e0 Srv: iScsiServer::listenConnections: Accepted iSCSI connection from 172.16.1.5:55975 to 172.16.1.150:3260. (Id = 0x2fc)
12/9 12:51:53.144 1e0 S[2fc]: iScsiSession::iScsiSession: Session (000000FCEE685500)
12/9 12:51:53.144 1e0 C[2fc], FREE: iScsiConnection::doTransition: Event - CONNECTED.
12/9 12:51:53.144 1e0 C[2fc], XPT_UP: iScsiConnection::fsmT3: T3.
12/9 12:51:53.144 f9c C[2fc], XPT_UP: iScsiConnection::handleFirstLogin: Login request: ISID 0x00023d000000, TSIH 0x0000.
12/9 12:51:53.144 f9c C[2fc], XPT_UP: iScsiConnection::doTransition: Event - LOGIN.
12/9 12:51:53.144 f9c C[2fc], IN_LOGIN: iScsiConnection::fsmT4: T4.
12/9 12:51:53.144 f9c Params: iScsiParameter::update: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:esx-rz05-2cd6406f', accepted 'iqn.1998-01.com.vmware:esx-rz05-2cd6406f'
12/9 12:51:53.144 f9c Params: iScsiParameter::update: <<< String param 'InitiatorAlias': received 'esx-rz05', accepted 'esx-rz05'
12/9 12:51:53.144 f9c Params: iScsiParameter::update: <<< Enum param 'SessionType': received 'Discovery', accepted 'Discovery'
12/9 12:51:53.144 f9c Params: iScsiParameter::update: <<< Enum param 'AuthMethod': received 'CHAP,None', accepted 'CHAP'
12/9 12:51:53.144 f9c Params: iScsiParameter::update: <<< Enum param 'AuthMethod': received 'CHAP,None', accepted 'None'
12/9 12:51:53.144 f9c Params: iScsiParams::createKeys: >>> AuthMethod=None.
12/9 12:51:53.144 b78 T[2fc,1]: iScsiTask::execLoginReq: session 0x2fc, connection 0x2fc : end of stage 0, next stage 1.
12/9 12:51:53.144 f9c Params: iScsiParameter::update: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
12/9 12:51:53.144 f9c Params: iScsiParameter::update: <<< Enum param 'DataDigest': received 'None', accepted 'None'
12/9 12:51:53.144 f9c Params: iScsiParameter::update: <<< Numeric param 'DefaultTime2Wait': received 0, accepted 2
12/9 12:51:53.144 f9c Params: iScsiParameter::update: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
12/9 12:51:53.144 f9c Params: iScsiParameter::update: <<< Boolean param 'IFMarker': received No, accepted 0
12/9 12:51:53.144 f9c Params: iScsiParameter::update: <<< Boolean param 'OFMarker': received No, accepted 0
12/9 12:51:53.144 f9c Params: iScsiParameter::update: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
12/9 12:51:53.144 f9c Params: iScsiParameter::update: <<< Numeric param 'MaxRecvDataSegmentLength': received 32768, accepted 32768
12/9 12:51:53.144 f9c Params: iScsiParams::createKeys: >>> ErrorRecoveryLevel=0.
12/9 12:51:53.144 f9c Params: iScsiParams::createKeys: >>> HeaderDigest=None.
12/9 12:51:53.144 f9c Params: iScsiParams::createKeys: >>> DataDigest=None.
12/9 12:51:53.144 f9c Params: iScsiParams::createKeys: >>> OFMarker=No.
12/9 12:51:53.144 f9c Params: iScsiParams::createKeys: >>> IFMarker=No.
12/9 12:51:53.144 f9c Params: iScsiParams::createKeys: >>> MaxRecvDataSegmentLength=8192.
12/9 12:51:53.144 f9c Params: iScsiParams::createKeys: >>> DefaultTime2Wait=2.
12/9 12:51:53.144 f9c Params: iScsiParams::createKeys: >>> DefaultTime2Retain=0.
12/9 12:51:53.144 b78 T[2fc,1]: iScsiTask::execLoginReq: session 0x2fc, connection 0x2fc : end of stage 1, next stage 3.
12/9 12:51:53.144 b78 C[2fc], IN_LOGIN: iScsiConnection::doTransition: Event - LOGIN_ACCEPT.
12/9 12:51:53.144 b78 C[2fc], LIN: iScsiConnection::fsmT5: T5.
12/9 12:51:53.144 f9c Params: iScsiParameter::update: <<< String param 'SendTargets': received 'All', accepted 'All'
12/9 12:51:53.144 f9c Srv: iScsiServer::sendTargets: <no target>: 'SendTargets=All' for a Discovery session...
12/9 12:51:53.144 b78 C[2fc], LIN: iScsiConnection::doTransition: Event - LOGOUT.
12/9 12:51:53.144 b78 C[2fc], IN_LOGOUT: iScsiConnection::fsmT9T10: T9/10.
12/9 12:51:53.144 338 C[2fc], IN_LOGOUT: iScsiConnection::doTransition: Event - LOGOUT_ACCEPT.
12/9 12:51:53.144 338 C[2fc], CLEANUP_WAIT: iScsiConnection::fsmT13: T13.
12/9 12:51:53.144 f9c Sw: *** Swn_SocketRecv: WSARecv() failed with error 10054 (0x2746)!
12/9 12:51:53.144 f9c Srv: *** SwSocket::Recv: Swn_SocketRecv() failed with error 10054 (0x2746)!
12/9 12:51:53.144 f9c C[2fc], CLEANUP_WAIT: iScsiConnection::receive: recvData returned 10054 (0x2746)!
12/9 12:51:53.144 b78 S[2fc]: iScsiSession::~iScsiSession: ~Session
12/9 12:51:53.160 1e0 Srv: iScsiServer::listenConnections: Accepted iSCSI connection from 172.16.1.5:26239 to 172.16.1.150:3260. (Id = 0x2fd)
12/9 12:51:53.160 1e0 S[2fd]: iScsiSession::iScsiSession: Session (000000FCEE684F00)
12/9 12:51:53.160 1e0 C[2fd], FREE: iScsiConnection::doTransition: Event - CONNECTED.
12/9 12:51:53.160 1e0 C[2fd], XPT_UP: iScsiConnection::fsmT3: T3.
12/9 12:51:53.425 12c4 C[2fd], XPT_UP: iScsiConnection::handleFirstLogin: Login request: ISID 0x00023d000003, TSIH 0x0000.
12/9 12:51:53.425 12c4 C[2fd], XPT_UP: iScsiConnection::doTransition: Event - LOGIN.
12/9 12:51:53.425 12c4 C[2fd], IN_LOGIN: iScsiConnection::fsmT4: T4.
12/9 12:51:53.425 12c4 Params: iScsiParameter::update: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:esx-rz05-2cd6406f', accepted 'iqn.1998-01.com.vmware:esx-rz05-2cd6406f'
12/9 12:51:53.425 12c4 Params: iScsiParameter::update: <<< String param 'InitiatorAlias': received 'esx-rz05', accepted 'esx-rz05'
12/9 12:51:53.425 12c4 Params: iScsiParameter::update: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:san-rz01.bex.lan-san-rz-lun01', accepted 'iqn.2008-08.com.starwindsoftware:san-rz01.bex.lan-san-rz-lun01'
12/9 12:51:53.425 12c4 Params: iScsiParameter::update: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
12/9 12:51:53.425 12c4 Params: iScsiParameter::update: <<< Enum param 'AuthMethod': received 'CHAP,None', accepted 'CHAP'
12/9 12:51:53.425 12c4 HA: CHADevice::register_session: Client initiator iqn.1998-01.com.vmware:esx-rz05-2cd6406f is trying to register a session within the 'iqn.2008-08.com.starwindsoftware:san-rz01.bex.lan-san-rz-lun01' target... (sessId = 0x2fd, initiatorNameIsid = iqn.1998-01.com.vmware:esx-rz05-2cd6406f,00023D000003)
12/9 12:51:53.425 12c4 HA: CHADevice::register_session: Client session (IP: "172.16.1.5"; Initiator: "iqn.1998-01.com.vmware:esx-rz05-2cd6406f") has been allowed!
12/9 12:51:53.425 12c4 HA: CHADevice::register_session: Registering the external client session.
12/9 12:51:53.425 12c4 PR: ResLunSessionEngine::registerSession: LUN 0: existing record for session 0x2fd from iqn.1998-01.com.vmware:esx-rz05-2cd6406f,00023D000003 iqn.2008-08.com.starwindsoftware:san-rz01.bex.lan-san-rz-lun01
12/9 12:51:53.425 12c4 PR: ResLunSession::setUnitAttention: Set UA 0x2901 (0x0) for session 0x2fd from iqn.1998-01.com.vmware:esx-rz05-2cd6406f,00023D000003.
12/9 12:51:53.425 12c4 ScsiFlt: ALUA_Filter::register_session: registering session 0x2fd
12/9 12:51:53.425 12c4 HA: CHADevice::register_session: Return code 0.
12/9 12:51:53.425 12c4 Tgt: iScsiTarget::openSession: open 'iqn.2008-08.com.starwindsoftware:san-rz01.bex.lan-san-rz-lun01': 5 session(s) opened, 65531 more allowed.
12/9 12:51:53.425 12c4 Params: iScsiParams::createKeys: >>> AuthMethod=CHAP.
12/9 12:51:53.425 12c4 Params: iScsiParams::createKeys: >>> TargetAlias=san-rz-lun01.
12/9 12:51:53.425 12c4 Params: iScsiParams::createKeys: >>> TargetPortalGroupTag=1.
12/9 12:51:53.675 12c4 Params: iScsiParameter::update: <<< Enum param 'CHAP_A': received '5', accepted '5'
12/9 12:51:53.675 12c4 Params: iScsiParams::createKeys: >>> CHAP_A=5.
12/9 12:51:53.675 12c4 Params: iScsiParams::createKeys: >>> CHAP_I=2.
12/9 12:51:53.675 12c4 Params: iScsiParams::createKeys: >>> CHAP_C=0bN3Vvf8FhC/7IxxePcQ8HrnlYrtCbQWEAU/FD88AoODk=.
12/9 12:51:53.925 12c4 Params: iScsiParameter::update: <<< String param 'CHAP_N': received 'GlobalSecret', accepted 'GlobalSecret'
12/9 12:51:53.925 12c4 Params: iScsiParameter::update: <<< String param 'CHAP_R': received '0x2b8d255bb0e2da54b85d0067f36088af', accepted '0x2b8d255bb0e2da54b85d0067f36088af'
12/9 12:51:53.925 12c4 T[2fd,1]: ***iScsiTask::handleAuth: *ERROR* Authentication failed. Wrong response returned.
12/9 12:51:53.925 ba4 C[2fd], IN_LOGIN: iScsiConnection::doTransition: Event - LOGIN_REJECT.
12/9 12:51:53.925 ba4 C[2fd], IN_LOGIN: iScsiConnection::fsmT7: T7.
12/9 12:51:54.426 12c4 C[2fd], IN_LOGIN: iScsiConnection::receive: recvData returned 10058 (0x274a)!
12/9 12:51:54.426 1380 HA: CHADevice::unregister_session: Client initiator iqn.1998-01.com.vmware:esx-rz05-2cd6406f has unregistered a session.
12/9 12:51:54.426 1380 ScsiFlt: ALUA_Filter::unregister_session: unregistering session 0x2fd
12/9 12:51:54.426 1380 Tgt: iScsiTarget::closeSession: close 'iqn.2008-08.com.starwindsoftware:san-rz01.bex.lan-san-rz-lun01': 4 session(s) opened, 65532 more allowed.
12/9 12:51:54.426 1380 S[2fd]: iScsiSession::~iScsiSession: ~Session
Oleg(staff)
Fri Dec 14, 2018 3:41 pm
We have checked CHAPs with StarWind build 12658 and VMware 6.5.
This option works as expected. We have checked with "use CHAP" option and "use CHAP unless prohibited by target".
You should configure CHAPs in StarWind and then on ESXi level.
