Recommended H/W configuration for 2 Node Cluster
massoo
Wed Sep 05, 2018 10:34 am
I like the the product "StarWind Virtual SAN Free " and have worked on in my very small setup. I would like to understand the Recommended H/W configuration for 2 Node Cluster that would be running:
a. 2 Node Shared Nothing Hypervisors (VMWare ESX or MS Hyper-V)
b. Around 30 VM's ranging from Domain Controllers, File Servers, Database Servers
c. File & DB servers are of mixed usage (both write & read are of similar %)
d. IOPS max. that can be achieved from the system.
e. the Starwind S/W willl run within the Hypervisors
f. Required Networking bits for Starwind data replication between the two nodes
Please let me know.
Oleg(staff)
Wed Sep 05, 2018 1:51 pm
StarWind Virtual SAN has system requirements. You can check this information here.
The choice of hypervisor depends on your preferences.
Different types of underlying storage can give a really different performance. And StarWind performance depends on the performance of underlying storage.
The bandwidth of the synchronization channel should rely on the performance of storage.
