How to exactly check the Device Health from powershell?
serhiogo
Mon Aug 20, 2018 2:55 pm
Hello collegues!
I'm trying to diagnose the manually simulated synchronization loss case between two nodes in my Starwind Virtual SAN Free cluster via GUI and Powershell script. The GUI gives me an infomation about sync and HB loss in Device context:
But when I'm trying to check the devices via embedded enumDevicesTargets.ps1 script I see some unclear...
DeviceType : HA Image
DeviceId : 0x0000002C611AB680
File : My Computer\E\storage-mmt\storage-mmt_HA.swdsk
TargetName : iqn.2008-08.com.starwindsoftware:vsan-1-210-storage-mmt
TargetId : 0x0000002C6121DDC0
CacheMode : wb
CacheSize : 8192
CacheBlockExpiryPeriod : 5000
Exists : True
DeviceLUN : 0
IsSnapshotsSupported : False
Snapshots :
SectorSize : 512
State : 0
Partners : System.__ComObject
SynchronizationChannels : System.__ComObject
HeartbeatChannels : System.__ComObject
SyncStatus : 1
SyncTrafficShare : 50
The corresponding code fragment is...
	foreach($device in $server.Devices)
		$device
I.e. the script returns the whole unfiltered $server.Devices structure.
That's all right , according to StarwindX. The device is Healthy (State = 0) and the Partners, SynchronizationChannels and HeartbeatChannels request returns nontransparent "System.__ComObject" state. Is there a way to retrive a normal human-readable status instead of "System.__ComObject"?
Is it due to the StarwindX limitations or my PS and/or StarwindX misunderstanding?
WBR, SerhioGo.
Mon Aug 20, 2018 3:36 pm
There is no status there. Those objects contain info about interfaces, but nothing related to the status.
serhiogo
Mon Aug 20, 2018 4:35 pm
Boris (staff) wrote:There is no status there. Those objects contain info about interfaces, but nothing related to the status.
OK, is there any objects containing this status that can be accessible via StarwindX?
If not, then there's a contradiction between GUI and PS data about "Health" status, imho.
WBR, SerhioGo.
Mon Aug 20, 2018 5:00 pm
SyncStatus : 1
This is what you are looking for. 1 stands for "synchronized", 2 - for "synchronizing", 3 - for "not synchronized".
serhiogo
Mon Aug 20, 2018 5:55 pm
SyncStatus : 1
I know about it, thanx. But I'm looking for little bit other thing.
I mean that there is a difference between GUI "Health" and PS "device.State" . I'm looking for the objects the GUI presents here:
I suspect that these objects are not from one structure and are joined by some ID's like target SID etc. My question was about it's availability via StarwindX. Neither "server.X", neither "device.X" , nor "target.X" structures present it. Where it's hidden =] ?
Thank you for your patience.
WBR, SerhioGo.
Sekkmer
Tue Aug 21, 2018 7:53 am
IDevice has a function called GetPropertyValue() and witch return any property that the device has, some properties are not part of the com object but you can still get them.
you can get some partner information like this
"ha_partner_node" + node number (start from 1) + "_" + name of the property
"sync_status"
"sync_percent"
"sync_elapsed_time"
"sync_estimated_time"
for the main node, it is "ha_" + name of the property
example: device.GetPropertyValue("ha_partner_node1_sync_status")
if you want to get information about the channels ask the partners for
"sync_channels"
"heartbeat_channels"
("ha_partner_node1_sync_channels")
and you get a string all the channels to a partner (by type) the string is split by ";" and one channel each data is split by "$" IP, port, valid connection.
I have a library witch extend the StarWindX classes here is the HADeviceExt witch implement all the above-mentioned properties and many more (although it is not implementing a function witch list all the errors)
https://github.com/Sekkmer/StarWindXExt ... viceExt.cs
serhiogo
Tue Aug 21, 2018 10:17 am
Hmm, it looks like just what I need. I'll try, thank you!
Tue Aug 21, 2018 4:38 pm
serhiogo,
The parameters Sekkmer outlined should be the ones you need. Just try that and report back whether you achieved what you intended to.
serhiogo
Wed Aug 22, 2018 5:54 am
Boris (staff) wrote:serhiogo,
I've tried.
Sync loss state:
DeviceId                :  0x00000075C5F1DA40
File                    :  My Computer\D\storage-210\storage-210_HA.swdsk
TargetName              :  iqn.2008-08.com.starwindsoftware:vsan-1-mmt-storage-210
TargetId                :  0x00000075C602E880
CacheMode               :  wb
CacheSize               :  32768 MB
SectorSize              :  512
State                   :  Healthy
SyncStatus              :  Synchronized
Partner                 :  iqn.2008-08.com.starwindsoftware:vsan-1-210-storage-210
Partner Sync Status     :  Not Synchronized
Partner Sync Channel    :  10.1.0.51 : 3260 .  Synchronization channel is DOWN
Partner HB Channel      :  10.0.0.51 : 3260 .  Heartbeat channel is DOWN
Normal state:
CacheMode               :  wb
SectorSize              :  512
State                   :  Healthy
Partner Sync Status     :  Synchronized
Partner Sync Channel    :  10.1.0.51 : 3260 .  Synchronization channel is UP
Partner HB Channel      :  10.0.0.51 : 3260 .  Heartbeat channel is UP
That's what I looked for. Thanks to Sekkmer 8)
Wed Aug 22, 2018 3:35 pm
It's great it worked for you.
dgl72
Wed Mar 27, 2019 11:40 am
Hi serghio
can you post your powershell script please.
I have exactly the same requirements.
Thank you
PoSaP
Fri Mar 29, 2019 10:57 am
Hi dgl72,
I believe you can ask Serghio directly about the script. Or modify existing scripts according to your needs :)
Tue Apr 02, 2019 2:06 pm
The best way would probably be sending a private message in addition to this public one.
sechan159
Wed Mar 15, 2023 3:35 am
Based on the information provided, it appears that the System.__ComObject state is a limitation of the StarwindX PowerShell module, which may not provide a human-readable status for the Partners, SynchronizationChannels, and HeartbeatChannels properties. This could be due to the design of the module or a limitation of the underlying COM objects.
Wed Mar 15, 2023 12:23 pm
I guess the fix is a long time there which makes your comment irrelevant.
